Question about Breville Coffee Makers & Espresso Machines
Water in grinder
Help! I was not feeling well and accidentally poured water into the grinder instead of the water chamber. What should I do?
  • 80 Answers
SOURCE: Leaking from the water Chamber
The Krups heats the water through a horseshoe shaped aluminum tube which the heating element is wrapped around the tube in the same fashion, the tube is corroded or cracked most likely, if you poured cold water into the machine when it was hot, this will crack the tube, they are made by Cesod ? which is stamped on the element with a number on it,  and I have seen between 700 and 1100 watt elements. I have the same problem with my 7 year old krups coffee maker, Im trying to repair the tube with aluminum welding or find a new element.  It could also be the high temp tubing may be cracked.  You need tamper proof Torx bits to remove the bottom cover on some models.
Posted on Apr 16, 2008
mirran
  • 515 Answers
SOURCE: Help....we poured some water into the bean grinder/container
You have to take off the bean hopper, turn the ring on grinder anticlockwise to you see the claque. Take out the middle off the grinder and clean everything carefully.
After that you have to put it back again, when you have the middle off the grinder back you turn the ring clockwise to the end, after that you turn it anticlockwise 14 "tick".
Posted on Jul 12, 2008
RescueTech
  • 145 Answers
SOURCE: maytag washer pours water out bottom instead of filling up
Check the water pump for physical damage from the move. If the washer was laid on it's side, you may have either snapped off the pump outlet or broke the pump body. You may have broekn the body of the water inlet valve fill flume. A visual examination should provide a lot of insight as to what the problem is.
Posted on Dec 20, 2008
bozcro
  • 867 Answers
SOURCE: poured water into coffee grinder
easiest thing to do is put it outside to dry or use a blow drier to dry it up, it should be ok
Posted on Jul 01, 2009
SOURCE: poured water in my delonghi magnifica beans hopper.
Have you tried grinding a few cups of uncooked rice through the mechanism to see if this will shift the dried on coffee grounds. It worked for a friend of mine after several attempts
Posted on Mar 12, 2012
Poured water in my delonghi magnifica beans hopper.
Dec 31, 2011 | DeLonghi Esclusivo Magnifica ESAM3300...
Tip
Why the bottom half of grind chamber in Cuisinart Thermal Grinder will not...
If its jammed it will not release easily.there is a procedure to release it try this as follows:-- 1) Rinse area with vinegar/water on a cloth to break up oils
2) Fill grind chamber with ice covered in a small plastic bag - try removing again after 10 mins.
This Will Help. Good luck.
on Mar 05, 2010 | Coffee Makers & Espresso Machines
My cuisinart cbm-18 does not grind at below a 10 setting?
Hello, and thanks for using FixYa.
I'm guessing the problem is that the grinders blades, or the parts that do the grinding have become somewhat dull, (opposite from Sharp.) and no longer can get to the beans like it used to.
Cleaning the machine properly might improve its performance.
CLEANING/MAINTENANCE INSTRUCTIONS
1. Be sure plug has been removed from outlet.
2. Beans can be removed from the hopper by lifting off the lid and pouring excess beans out. Hold down the Manual button to cleanout any remaining beans.
3. The bean hopper, bean hopper lid, grind chamber, and grind chamber lid can be washed by hand with hot, soapy water or placed in the top shelf of a dishwasher. Dry thoroughly.
a. Remove the bean hopper by rotating counter-clockwise bringing the selector past grind setting 18, align the arrows and lift up. Make sure the hopper is empty.
b. Remove grind chamber by pulling toward you.
4. Remove the burr grinder, once the bean hopper has been removed, by grasping the metal handle and lifting up. Use the brush to remove grinds or wash by hand. Replace the burr grinder onto the unit and rotate until the piece is fully inserted. Push handle down and replace hopper.
NOTE: The hopper will not attach to the unit if the grinder has not been fully inserted.
5. Wipe body of grinder with a damp cloth.
6. Any other servicing or maintenance should be performed by an authorized service representative.
WARNING: NEvER ImmERSE UNIT IN WATER
Oct 14, 2010 | Cuisinart CBM18 Electric Grinder
How do you clean the baby pro bottle warmer?
Ice container, measuring containers, and baskets: Dishwasher-safe (top rack only).
Measuring containers should be placed in a dishwasher basket. Or wash in warm water
using mild liquid soap. Rinse with clear water.
Bottle Warmer unit and removable cooler: Always turn OFF and unplug before cleaning.
Wipe surface of unit as well as inside of cooler and cooler lid, and inside of warming
chamber with a damp cloth or sponge using mild liquid soap. Wipe with clear water. Air dry.
Do not immerse in water. Do not use scouring pads, solvents, or abrasive cleaners, as
these could damage the unit.
Warming chamber (optional): Mineral deposits (usually white in color) may form on the
inner surfaces of the warming chamber and can cause damage to the unit. To remove them:
1. Unplug the unit.
2. Remove the basket, and wash separately as indicated above.
3. Pour 2 oz. vinegar into the warming chamber and let it stand for an hour or two (longer if
necessary).
4. Pour out the vinegar and rinse the chamber two or three times by pouring in, then
emptying out, 3 or 4 oz. of plain tap water. Do not immerse the Bottle Warmer in water.
Wipe dry or air dry.
Aug 21, 2010 | Avent Philips iQ Bottle Warmer without...
Poured water into coffee grinder
Jul 01, 2009 | Saeco Magic De Luxe Espresso Machine
My saeco incanto doesnt dispense coffee any more only water comes out of the dispenser :( please helppppp ,it was working fine an hour ago then suddenly i start getting only water instead off coffee , P.S...
Check the coffee dregs are they wet? Or are they even there?
If there are no dregs then the grinder chamber is clogged and needs to be cleared out, remove the brew unit and you can gain access to the chamber on the left. Clean the chamber.
Jun 25, 2009 | Saeco Incanto Classic Espresso Machine
Saeco Vienna Deluxe leaking problem and grinder problem
I would repair it, it sounds like the grinder needs to be adjusted (burrs may be dull), and the leak on the bottom may be coming from the small drain hole on the back of the brew chamber. If you remo;ve the chamber you will see the white water valve that the chamber connect to, if you look below the white valve the small chamber in there will be filled with water, below that there is a small discharge use a stit stick or paper clip to clear hole.
May 07, 2009 | Saeco Vienna De Luxe Espresso Machine
Poured water into the bean hopper by accident
I wouldn't recommend it. Grinder needs to be opened up from the top where the ceramic blades are and that section needs to be cleaned out. The coffee in there will compact and mold quickly. Just unscrew the top screw by the hopper. There should be a rubber circular housing you can remove. From there set the grinder setting to the coarses setting (all the way to the right, and not 1.) Look at the blades and there should be markings in red and blue, align the red with red or blue with blue until the top blade easily detaches. Clean inside the that area and **** out all the coffee. Replace top blade, set red to blue so it locks the blade in place, replace arm and hopper.
Feb 21, 2009 | Saeco Vienna SuperAutomatica Coffee...
The bottom half of grind chamber will not release to clean
Dec 29, 2008 | Cuisinart Thermal DGB-600 Grinder
Sep 04, 2007 | Saeco Magic De Luxe Espresso Machine
Coffee Makers & Espresso Machines Logo
41 people viewed this question
Top Breville Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Colin Stickland
Colin Stickland
Delierious
Are you a Breville Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
