Question about Hotpoint Washing Machines
Hotpoint ultima wmd740
30 min quick wash is now taking over an hour how can i reset it , there is no error code
dazmaraz
  • 67 Answers
SOURCE: Ultima WT741G Error Codes
motor jammed/tacho detached; check motor and module connection
Posted on Jul 06, 2007
  • 5 Answers
SOURCE: Error code f08 on Wt940 ultima.
not sure if this will help but try:
First empty the machine by lowering the hose at the rear to ground level into a container. Take off the white plastic cover on rear at bottom. You will see black rubber hose connected to barrel of machine in right hand corner. Undo the silver screw on the band securing the hose. (Biggest band). You can now pull the hose down to reveal a "table tennis like" ball. Lift it out carefully and you will probably find an obstruction like a coin or similar. I found a hairgrip but it was enough to stop the ball functioning. DO NOT TAKE OFF THE WHITE HOSE CLIPS
Comment by pulmicort, posted on Feb 02, 2008 Further to my comments re clearing scrap from table tennis ball after code F4. Machine started ok but then F5 came up. Had to take the pump off and apart to reveal broken hairclip actually seized in pump. If you are handy at all this is simplicity itself.
Slide pump to left and lift and it comes clear. Take off 2 black hoses only where connected to main machine. Pull off electrical connection. Pump and hoses lift out easily. 3 screws open the pump. Clean any obstruction and reassemble. A 30 minute operation.
Posted on Apr 16, 2008
SOURCE: error message f-01 on hotpoint ultima wt741 washing machine
F01 is a motor faulty normally caused by the module,but sometimes thewiring to the motor plug that works loose as its to tight,give them alla good wiggle make sure there all in!
check this link for other error codes of hotpoint machines
http://www.hotpointservice.co.uk/hs/pages/content.do?keys=FAQ:ERROR_CODES
Posted on Dec 15, 2008
  • 4 Answers
SOURCE: hotpoint ultima tumble dryer error code f-03
i have a hotpoint ultima ctd80 which i have had the last 2 years, it has shown error codes f11, f10 and f15, every time i fix this problem by first switching off and unplugging appliance then removing small cover from back (middle with 2 screws) then larger panel that the smaller panel overlapped. once you remove these you will see the heating elements, remove the 2 screws at the back off this, remove cover carefully then at the top you will see two things (not very technical lol i am a woman), with a pin press the pin in the one with a hole, mine makes a clicking sound when i do it, not sure if it meant to but works for me. put all parts back together and thats the job done. make sure both fillters and water emptied regular, hope this helps and saves you a fortune on call outs
Posted on Jan 14, 2009
barkencoa
  • 3463 Answers
SOURCE: hotpoint ultima F-05 errorr appears on machine
Error F05 indicates pressure switch jammed on full.
Remove lower rear cover of washer.
Locate and remove large black hose fastened to drum.
Remove and clean filter inside hose.
Remove hose onto pump, and check for blockage or obstruction here as well.
This should solve the problem.
Posted on Jan 10, 2010
Error message f 03displayed
F03 - Wash thermistor open/short circuit it looks like you need an engineer out but 1 thing to try is reset the machine by switching off at plug for 5 mins then back on and try again hope this helped.
Oct 01, 2010 | Hotpoint Ultima WF860 Front Load Washer
My washing machine has an error code f5
F05 - Pressure switch jammed on full - Check pump for blackages. also you might need to get new pressure switch. also resetting the machine might do the trick switch off at plug for 5 mins and plug in and try again. hope this helped
Sep 26, 2010 | Hotpoint Ultima WF860 Front Load Washer
I have a hotpoint ultima washing machine wt965 and the display is flashing f-05
F05 - Pressure switch jammed on full - Check pump for blackages. Also resetting the machine sometimes solves the problem switch off at plug for 5 mins then switch back on and try again. hop this helped
Sep 26, 2010 | Hotpoint Ultima WF865 Front Load Washer
Showing error code F-08
We let the washer stand for 45 mins then tried to wash again and it washed another 3 times and has not shown the fault since.It is the relay for controlling the heating element and tends to stick when it gets warm.We found that letting it cool for a while and resetting itself it worked again.This might not solve the problem in the long term but it worked for now.The fault shown was F-08
Thank you
Jun 16, 2009 | Hotpoint Ultima WD72 Front Load...
Hotpoint aquarius wash system plus ultima 1200 wm72
it's a motor problem. could be as simple as the brushes or could be the circuit board at fault.
Jan 17, 2009 | Hotpoint Ultima WD72 Front Load...
Error message f-01 on hotpoint ultima wt741 washing machine
Dec 15, 2008 | Hotpoint Ultima WD72 Front Load...
HOTPOINT ULTIMA 1200 WM72 Error Code
f30 code means there is a problem within the motor curcuit,check connections at the motor and check motor brushes are not worn.
May 05, 2008 | Hotpoint Ultima WF860 Front Load Washer
Mar 18, 2007 | Hotpoint Ultima WF860 Front Load Washer
Washing Machines Logo
16 people viewed this question
Top Hotpoint Washing Machines Experts
Todd Arndt
Todd Arndt
freddyfox
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
