Furuno gp7000f when key is turned on 115 yamaha outboard unit dies instantly I have checked for voltage drop at bus bar and found nothing significant. i have doubled up on cables to batt switch. boat is aluminium and i have not grounded unit to it
SOURCE: Garmin 525s will not turn on
I tried to reset it but it did not work. I have shipped the GPS back for a replace.
Thanks for trying to help. When I get the new GPS I will start with updating the software as described.
SOURCE: Power to Lowrance GPS
Yes you have to hook up the red wires together to the + and both black ones to the negative, otherwise the antenna won't be supply in current , and don't forget to insert behind the red wire a fuse and a switch to avoid to discharge your battery .
Bernard.
SOURCE: installation furuno GP7000F/NT
This unit has built in sonar, so no DFF1 is required. The 1KW transom mount is in stock here, with the proper Furuno 10 pin connector. That is all you need, the display, the power cord, the GPS antenna, the transducer and THE BOOK! We are a Furuno dealer in the Great Lakes
SOURCE: GP700F Airmar P66 to TM260
you must run 50KHz for deep water, so you will have to solve the interference problem to benefit from the power
SOURCE: global map 5000 not loading
Have you followed the correct testing procedure? The one from here?
http://www.lowrance.com/en/Support/Product-Support/Troubleshooting-Guide/GPS-Module-Not-Responding/
If yes and it failed then the firmware is corrupted. Since you are no longer able to boot you will not be capable of fixing it yourself - the unit must be dismantled, the firmware chip accessed directly at hardware level and rewritten with a new firmware. This is a job only the main service shop of a dealer can do, you will have to send it to them.
If your unit is out of warranty you should call them before that, otherwise you might find out that it would have been cheaper just to discard this one and buy a brand new unit.
Lowrance Customer Service: 1-800-324-1356
