Question about Audiovox FPE3206 32 in. LCD Television
Looks like no power
When you turn the TV on, the screen looks like there is no power, but the Lightbar at the bottom of the TV turns its respective colors for on and off. Was working normally just a little while ago. Tried to turn it on later, and this happened. Anyone know what might be the problem? Think the tv is shot?
  • 1 more comment
  • Anonymous Nov 25, 2007
    I am getting the same problem as this guy. The power light turns blue as if the TV is on but the screen stays the same as if it was off. This just started happening within the hour. Does anyone know what the problem is?
  • steve1957 Dec 06, 2007
    I have the same problem. I read other blogs and the only thing I found was the possibility of the buttons getting stuck. They suggested using the remote!!??
    Audiovox said it would be repaired if it was under the one year warrenty. Guess what! I missed it by a week??~~If anyone knows if it can be repaired, (less than buying new one) please post.
    Steve
  • Raevyn Apr 22, 2008
    I have the same issue. It just happened today. The warrany has just expired and now this....it figures. If anyone knows how to fix it, please let me know.
This post is basically for anyone that stumbles across it trying to fix what seems like two fairly common problems with plasma tvs. I apologize for the length of it but hope it can help others.
To start off, I got a free Audiovox FPE4216P 42" Plasma TV.
The previous owner said that there was a red cloud in the top center that after time spread across the top and down the center of the screen. Some time later, they were watching it and it was as if someone simply turned the power off. After that, there was no longer any picture - menu or otherwise.
After much research on the net, it seems that fixing plasma TVs is strongly based on the educational guess method. This compounded by the fact that replacement parts are quite scarce and generally crappy customer service provided by the manufacturer if the TV is older than 14 months basically makes many of these TVs $2000 doorstops if something goes wrong with them. Luckily, my TV uses many LG boards which seem to be used in a number of different makes and models.
NO DISPLAY ISSUE:
Once I took the set apart, I first checked the power coming into it and it checked out ok. I then found a fuse on the YSUS board that had blown, upon replacing it, I no longer had sound. The indicator light on the front would turn from red to blue for about 3 min then back to red. After this happened, the LED on the power board would light up and the there was no longer any response from the power button (led on front would only stay red). I would have to unplug the set and plug it back in to duplicate the above.
I then checked the voltages for Vs, Va and 5v on the connectors coming off the power board (using the DC setting on a voltmeter) against the specs on the sticker on the back of the display panel and they checked out.
It was recommended that I change the YSUS board since the fuse had blown on that board. This seemed counter-intuitive to me since it seemed that the power was fed into the YSUS board through that fuse first as if to protect the YSUS board.
With reluctance, I purchased a "new" YSUS board. Once I popped it in - presto! I had picture! But picture with a cloudy, sparkly red "I" beam that would show through the dark areas of images including the menu screens. It seemed that as long as there was a color over where the "I" beam ran, it was fine and there was only a problem when the image was supposed to be black.
RED DOTS - SPARKLES - SPECKLES - and possibly MAL DISCHARGE ISSUE:
I say possibly mal discharge because it seems that some label this problem as such where some describe mal discharge as another problem.
After much research on the net (again), it seems that there are two fixes for this problem: 1 - a new control board and 2 - adjusting the voltages. It seems that each fix has about a 30 - 50% success rate. With the first fix, you just pop in a new board and you could be done or you could have the same problem. With the second fix, people have said that the dots have gone but the image is now crappy or they have different color dots. Some also say that merely changing voltages will only temporarily fix it. I opted for the cheaper second fix.
My power board has two potentiometers (pots) on it (adjustable dial thingies). One for the Vs and one for the Va. I first made sure that these were adjusted to spec. I took readings off of the molex connector and grounded to the support bracket of the set.
My YSUS board has 4 pots, two are labeled SetUp and SetDn and the other two are on little circuit boards rising off the YSUS board - one of which was completely inaccessible due to it's position behind the support bracket.
I first set the TV to an empty input since the red showed best against all black. Jacking up the SetUp pot seemed to have the effect of making the black really black and essentially removing the red. SetDn didn't seem to due much and I didn't mess with the other pots. When I switched to an active source everything looked great but then I started to notice that on bright images that weren't quite white, there was blotchy pixelation and redness. It then started messing with all three accessible pots and got the image to be really good but I could still see some red and now blue sparkles in the dark areas.
I was pretty satisfied with my results but there was that one other pot that I could not get to unless I removed the YSUS board. Since I knew I would have to adjust that pot multiple times, I decided to remove the board and drill a small hole in the support bracket to gain access to the pot with the board installed. For me, this was the most difficult and frightening part. I didn't want to damage the panel itself and I also didn't want to get metal shavings everywhere. I carefully masked off the area and nearby boards with paper and when I drilled I held a piece of wood behind the bracket.
I then had access to all 4 pots and just kept messing with different balances between them. I used an empty input to check the black and numerous DVD's to look for crappy picture on lighter areas. As it turns out, the menu for the Underdog DVD really showed the light image flaws.
Now, the image is about 98% perfect. When a lighter image turns to complete black, there are some, extremely diffuse red and blue brief pixel flashes (just for a millisecond) but then the black stays black. To notice it, you have to be within 3 or 4 feet of the TV which I think is too close anyway for a 42" TV and is virtually non-existent when watching DVDs.
Here is some extra part number info with possible equivalents:
YSUS: 6871QYH953A or 6870qyh005B and possibly 6871QYH053B EAX31974801 EBR31872801 EBR32642701 6870QYH105B EAX31631001 EBR32642702 1032298-hs
Control Board: 6871qch977b or 6870qch0C6b and possibly 6870qch006b 6871QCH077B 5070-5623
Power Supply Board: 667-PH42FB6-20 or 782-PH42D8-200a and possibly 6FB0192010
Posted on Jun 21, 2008
    Scholar:
  • 21 Answers
Hi there, Im Kanth, i had the same problem, and i found a person in Mississauga, they fix all kind of problems in Plasma, they fixed my LG before a 7 months, its still running good, i came to know lots of ppls were having same problems, i sujest u to being the plasma to electronics @ Dixie and Britannia Mississauga, call them now 905 565 6595 or check there wesite for more info. http://dukeelectronic.com
Posted on Apr 22, 2008
When first turned on it was d but would get brighter now it has no picture after being on all night is it the lightbar reglator
Hey, it looks like u may have took it to far. Yes if lcd is like a shop light has inverter board which is a ballast and has bulbs in the screen assembly, so if dim to start and then gets brighter possible power supply or inverter board. Usually if bulbs go bad u can shine a flash light in the screen and see if u see any images which means the backlight is bad or bad screen. hope this helps
Apr 15, 2015 | RCA Televison & Video
I have a un75es9000f and the picture looks plaid I had some movers move it and after we hung it and turned it on it looks plaid and has a bubble on the bottom of screen any ideas of the problem
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
https://www.youtube.com/watch?v=TR2iWN6b-LY
LCD TV Repair No Power Power Supply Common Symptoms Solutions How to...
Mar 14, 2015 | Televison & Video
I have no controll for my small medion tv is it possible to turn on with out one
Looks like there should be a power button under the bottom right corner of the TV. (run your finger under the bottom edge of the TV and you should feel it). Then once the power is on, you will need to touch the standby button on the bottom of the right edge of the TV.
Jun 28, 2014 | Televison & Video
No power goin to tv at all
I saw your post, dwayne74958, and would be happy to help you with that! In order to properly assist you, there are a few questions I need to ask to better understand the situation. Could you specify what pieces of equipment work and which do not? Is the issue with the TV that it doesn't turn on at all, or just has a black screen? Do the lights on the receiver turn on when you power it up, or does it not turn on at all? What type of receiver do you have? The model number is found on the front panel in the bottom left corner.
Check behind the receiver and TV and make sure all connections, especially the power cords, are secure. If you have everything plugged in to a power strip, make sure the power strip is plugged in to the outlet on the wall and that it's turned on. If this already looks proper, you may need a new power strip. Let me know about that and I'll look forward to assisting you further!
Hope that helps!
Mar 21, 2011 | Televison & Video
I have a hp psc 2510 photosmart and my lightbar is stuck
try to turn off the printer, remove cables and then press and hold power button for 5 secs. Reinsert cables and turn on the printer. If the lightbar is stuck, it could be the LEd light itself or maybe the machine. Call hp if symptom persist..
Nov 20, 2010 | HP PSC Photosmart 2355 All-in-One Printer
The screen looks like mountains growing from the bottom turning the tv black
Hello
This is one or more capacitors going bad in the power supply. Take it to a reputable repair person or check out my website: www.micromendllc.com
Good luck
Sep 23, 2009 | Mitsubishi WD-60735 Projection Television
Looks dark
pisture tubes rejuvanation or you can try on the back bottom of tv . look for screen and focus ..turn the screen while looking at screen
Sep 25, 2008 | JVC AV-32432 32" TV
3 curved lines top & bottom/blurred picture
This indicates a convergence problem..convergence power supply probally.. however ive seen 2 other cuicits cause this ..
Sep 24, 2007 | RCA HD52W59 HDTV Projection Television
Top half of screen looks like 3D
the prob. described points to convergence amp failure. have qualified tv tech to repair..john
Nov 10, 2006 | Akai PT4298HD Rear Projection Television
Audiovox FPE3206 32 in. LCD Television Logo
854 people viewed this question
Top Audiovox Televison & Video Experts
Jaime Hernandez
Are you an Audiovox Televison and Video Expert? Answer questions, earn points and help others
