Remove the rubber platter mat if your turntable uses one. Set it aside.
Lift the platter straight up and off the center spindle to expose the turntable belt.
Remove the original belt and check it for wear. Generally, a turntable belt doesn't slip unless it's damaged. If it is damaged, purchase a new one.
For a Two-Piece Platter Turntable
Loop the replacement turntable belt around the cylinder located underneath the platter.
Check that the belt is working properly by turning the platter clockwise two or three rotations. It should smoothly move along the motor pulley. If it doesn't, adjust it and turn it again.
Replace the platter, and then carefully lay the rubber platter mat over it.
Turn on the turntable and check it for correct movement. If it looks like it's working, play a record to make sure all is in order.
For a One-Piece Platter Turntable
Loop the replacement belt around the cylinder located underneath the platter.
Replace the platter carefully. One-piece platter turntables are delicate, and if you force the platter down or push it at an angle, you might damage the platter or spindle.
Turn the platter so the hole in it lines up with the motor pulley.
Pull the turntable belt and loop it over the motor pulley. Position it on the pulley groove to make sure it won't slip.
Rotate the platter clockwise to make sure the belt is firmly in the pulley grove. Moving it two or three times ensures that it's in place.
Put the rubber turntable mat back on the platter.
Turn on the turntable. Play a record if it looks like everything is working to check the speed.
Most are held in place by 2 small screws, remove them and carefully unplug the cartridge from the tone arm, reverse to install new one, then check the balance the tone arm and set to correct pressure..
