Question about Zebra 520I Printer
520i driver zebra
Need a driver for parallel port
3 Suggested Answers
SOURCE: How to configure the Zebra S500 using a USB to Parallel adapter?
The Zebra Stripe S500 has a RS-232 SERIAL interface using a DB-25 connector . You'll need a USB to SERIAL converter, not parallel. Be sure that the baud rate and data/stop bits are set the same on the printer and interface converter. Generally speaking, use the fastest setting possible (19200 baud) unless you encounter problems.
Posted on Feb 01, 2008
jigeo
  • 57 Answers
SOURCE: Zebra LP 2844 parallel communication problem
The printer is installed on the PC using a specific port. If it's installed on the USB port, it won't work on the parallel port. Do you have this printer installed 3 different times? Need more details such as how was it installed the first time? And if it's working on the other 2 ports, why does it have to work on the parallel?
Posted on Apr 24, 2008
This printer is no support with create-a-label
If you are using CAL (Create A Label) you must have a device called a "Dongle" plugged into your parallel (or USB) port. This acts as the activation key for CAL. If there is no dongle then CAL only works in demo mode. That's why printer Icon stays grayed out. The "Dongle" normally plugs directly into the parallel port and one end of the parallel lead plugs into the "Dongle" while the other plugs into your printer.
I would suggest that you download "Zebra Designer" software from the Zebra Website..This will work without any activation.
If you use ZD you must use the correct ZDesigner driver. (Install automatically as part of ZD setup) This driver only works with ZD.
If you need to link to a database then you will have to BUY label software. Zebra Designer Pro, or Nicelabel, or Bartender....etc.
Jan 10, 2011 | Zebra LP 2844 Thermal Printer
I need to add network to 2844 printer currently USB/Serial
You need to buy the zebranet PS2 print server
P/N G46692 External PrintServer II. It will plug into the parallel port. they just stoped making them but they are still for sale at zebra resellers. here is one at random from google
resize?sq=80&uid=1127727233 ZEBRA G46692 EXTERNAL PARALLEL PRINT SERVER II
more at ZDTronic.com
ZDTronic.com $160.50
  • product
ZEBRA G46692 EXTERNAL PARALLEL PRINT SERVER II ZEBRA G46692 EXTERNAL PARALLEL PRINT SERVER II $160.50 at ZDTronic.com
May 12, 2010 | Zebra TLP 2844-Z Thermal Label Printer
Zebra TLC2844 wont print at all
Try to make the self-test first:
Power OFF
Press "FEED" and keep it pressed and turn the power ON again.
Did it print?! if Yes... There must be a cable problem or port.
Is it USB? Serial? Parallel ?
Let's say it's Parallel, go to the command line and type:
"dir >lpt1"
without the quotes and assuming it's connected to 1st parallel port
did it print?!
on serial would be "dir >com1"
or, if it shows up in "Printers", pre-define it and just type: "dir >prn"
Still doesn't work!?
Try with a different cable, or other computer.
You can use it even without installing the drivers...
Sep 14, 2009 | Zebra Eltron TLP 2844 Thermal Label...
Panasonic KX-P 1180 cannot print properly with win XP Pro SP2
when you loaded the driver did you select the correct port? many times I get calls where they hooked upto a certain plug in but chose the wrong port parallel needs the lpt1 port and if there are more then one listed it could be a higher number..lpt2...lpt3. goto the driver in printers and faxes and right click the chose properties then the ports tab and pick the port.
Jul 08, 2009 | Zebra 140XiIII Plus Thermal Label Printer
USB PORT FOR ZEBRA Z4M
It will not work with any drivers if you do not have a parallel port. You can get a pci card that has parallel port on it for use with the zebra z4m.
below is a link for the card that cost only $9.99
http://www.gogocost.com/xcart/product.php?productid=275
Feb 19, 2009 | Zebra Z4M Printer
LP 2844 not working with Create-A-Label v3.04
Oct 07, 2008 | Zebra LP 2844 Thermal Printer
Apr 15, 2008 | Zebra LP 2844 Thermal Printer
No response from 105Se
if the data light comes on and nothing prints chances are that the serial settings are set improperly. all of my printers are 25 pin serial, not parallel. i don't have one in front of me but i believe the settings are 19200, 8, 1, none. hope this helps.
Mar 19, 2008 | Zebra 105Se Thermal Printer
Zebra Z4MPlus doesnt communicate with PC
Ok,
This machine has a parallel port. Try to print via parallel cable. If it works, consider staying with it. Serial ports are a pain to manage.
If you absolutely have to do it via rs232 though....
Question 1. Has it ever printed?
If yes, Go into Windows Printers and Faxes control and select the Zebra or whatever printer that you are using. Right click on it and you should get a menu that at the bottom say "Properties", select that, then you should get a new window with tabs at the top. You want the tab for "Ports". Select it and you will see all of the different output ports that you can direct your printing. RS232 is a COM port. So start at COM1, check it and try to print. If that doesn't work, go to COM2, etc.
Last resort, If you can't get control via the printer driver program, you will have to try redirecting the print manually (now you will understand why I said to stay with parallel output).
What you have to do is redirect your printing via the dos "mode" command.
Under "Start Menu" goto "Run" and put in "CMD" and click "OK".
This opens a black square window with a cursor blinking. Type in this:
mode com1:9600,n,8,1 (enter)
mode lpt2=com1 (enter)
Tell your program to use LPT2 if you can and see if it works.
By now a parallel cable instead of RS232 should be looking really good.
Mar 12, 2008 | Zebra Z4Mplus Label Printer
Oct 30, 2007 | Zebra Stripe S500 Thermal Label Printer
22 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
