Question about Cub Cadet Garden
Cub cadet lawn tractor
I have a cub cadet lawn tractor 1500 series - 6 yr olds it will only go forward at a VERY SLOW pace with little, or no power. It can barely make it up any type of incline. What could be causing this sudden loss of power & speed?
    Scholar:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 94 Answers
MOST likely cause is a worn/failed drive belt. I'd replace that first - be SURE to use a Kevlar belt or you'll be repeating the repair in a very short time frame.
Posted on Jun 30, 2014
defadad
  • 351 Answers
SOURCE: hydrostat trans starting to make moaning noise stops pulling
it may be full of dirt etc and has soaked up most of the oil inside the case, if the axle seals are worn and the selector shaft seal is worn I would say that is the problem, if that is the case you may be up for a new trans as I have done a transaxle just recently and the damage inside was extensive and expensive.
you will have to remove the trans and seperate the trans case for inspection
Hope this helps
Posted on May 23, 2009
  • 22 Answers
SOURCE: Electric clutch on my 4 yr old Cub Cadet 2518 was intermittent
check fuse or power it up seperatly with 12volts (battery directly into the two terminals) to see if it is a wiring fault but it sounds like you need a new clutch assembly $$$
Posted on Jun 20, 2009
  • 391 Answers
SOURCE: Lawn tractor forward movement problem
Check the adjustment from the lever to the transaxle, if the linkage is ok the transaxle may be suffering from age and has leaking internal seals.
Posted on Jun 04, 2010
  • 13 Answers
SOURCE: cub cadet lawn tractor, ran out of gas. After
I would bet that the throttle shaft is worn and has a lot of play in it on the carburator. This is very common. The best bet is to have the carburator worked on by a small engine repair shop, or get a replacement one.
Posted on Jun 10, 2010
daneinwv
  • 124 Answers
SOURCE: NEED A WIRING DIAGRAM FOR
My name is Dane and I am going to try to help you solve your problem.
Here's a link to where you can find your 3000 series service manual. You will find the schematics starting in chapter 17. Please find your correct engine configuration to match the correct schematic.
http://www.mymowerparts.com/pdf/Cub_Cadet/Cub_Cadet_Service_and_Repair_Manuals/
I hope I've helped. If you found this information useful, please leave me some THUMBS UP as deserved. Thank you! Dane
Posted on Dec 04, 2010
My 1500 series cub cadet 42" mower with hydro transmission runs good but mowes very slow. What could be the problem?
Is the tractor moving slow or are the blades moving slowly? The belt on the mower blades may be slipping. If the tractor is moving slowly look to see if the transmission needs fluid.
Aug 08, 2015 | Cub Cadet Garden
Lack of power
I had the same problem with my 2011 i1042. Turned out to be drive belt not snug enough. Installed new drive belt all OK now - plenty of power & speed, no slipping. good luck. (BTW: it was a REAL PAIN to remove and replace the belt!)
Apr 26, 2013 | Cub Cadet I1042 42" 18HP Zero Turn Tractor...
My cub cadet tractor starts but the pto clutch stays engeged and i cant shut it off(pto)
The clutch has it's own brearings in it. You have to replace the hole PTO.Sometimes you can find a Aftermarket PTO clutch. There usually A little cheaper.
Jul 10, 2012 | Cub Cadet Lawn Mower Electric PTO Clutch...
Wheres the fuse on 1500 Cub Cadet lawn tractor
Raise the hood look back by the battery at the top you will see the fuses.
May 16, 2012 | Cub Cadet Garden
Cub cadet has no power changed battery still no
Blown fuse. There is a fuse somewhere thats blown. It will be about a 15 amp in a fuse holder either back by the battery or behind the dash. U didnt specifiy the 100 number If thats a starter-gen it could be a reg- relay issue.
Oct 22, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Diagram of mower deck
Go to... http://www.partstree.com/parts/ Then click on Cub Cadet, enter the model number then all the diagram are there.
Jul 04, 2009 | Cub Cadet Street Sign- tractor lawn riding...
How do I change the drive belt on a 1500 Series Cub Cadet Lawn Tractor
Go to www.partstree.com click on Cub Cadet, enter the model number that's under the seat and that will give you a diagram.
Jun 13, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Garden Logo
121 people viewed this question
Top Cub Cadet Garden Experts
Tim Whalen
Matt Olenzek
Matt Olenzek
roeb
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
