PRINTER LIGHT RED ON SAVIN 3515MF
PRINTER LIGHT IS RED, WILL NOT PRINT FROM COMPUTER
5 Suggested Answers
drichards
  • 87 Answers
SOURCE: SAVIN 3515MF
open the right door. Open the front cover. Remove the toner assembly, not just cartridge. Unplug wire, pull out.
Posted on Apr 21, 2008
SOURCE: How to change and program fax numbers into Savin 3515MF copier
"user tools"
"system Settings"
"key operator tools"
"address book Management"
"Program/ Change" or "Delete"
.......and proceed to make the changes as you wish
All of the manuals can be downloaded here, but they can be difficult to follow.
http://www.ricoh-usa.com/downloads/manuals/bw/aficio1515/
Posted on Mar 02, 2009
joshryals
  • 18 Answers
SOURCE: Can I scan directly to my computer without having
If you are using XP, click on start, then go into control panel, then to scanners and cameras.
From there select your scanner and follow the directions for scanning.
With vista, click on the start button, then type in scan. There should be an option to "scan a document or picture"
Posted on Apr 07, 2009
spinal
  • 287 Answers
SOURCE: Savin 3515MF, copier and printer features are
Hello. Most likely there is some sort of debris in the optics.You can verify this by pressing the "USER TOOLS" button (usually located toward the top left of the operator control panel, although I dont usually deal with the 3515) and select "counter".Then select print counter.This will generate a copy of the meter reading of the device and this print will come directly from the engine of the device and will eliminate everything that has to do with the optics. If this print looks good(no lines) then you know that the scan glass and/or the mirrors are dirty.If this is the case then you need to turn of the copier.Now, lift the document feeder completely up so it rests in the up position. You of course will see the LARGE platen glass in front of you which you might place a document on in the event that you need to copy something that you cant run thru the automatic document feeder.BUT, look to the left of the large glass and you will see a SMALL strip of glass that is about 1 inch wide and as long as the large glass.This narrow strip of glass will cause lines on any document scanned thru the document feeder if it is dirty.The dirt may exist on top(where you can easily reach it but perhaps have to strain to actually see,or on the backside which will require the removal of the left index plate and the top edge plate (5 screws) and then the removal of the large platen glass.This will give you access to all the optics.Make sure the power is off before you jump in.Once these items are removed clean the back side of the small glass(at this point you can actually remove it for ease of access using a soft slightly damp cloth.Since you are this far,you shouls also clean the mirrors, the illumination lamp and its reflectors with a soft cloth.You may reach down and manually pull the scanner assembly to the right as it normally would move (as if it were making a copy) in order to gain better access to everything, once again using a soft cloth.There is now need to worry about the position of the scanner assembly when you are finished since when you power up the device it will seek and find its "home" position by itself.I bet you will have just solved your problem. Take care :-)
Posted on Jul 11, 2010
Black will not print on a savin clp22
Please make sure that the toner tape is pulled from the cartridge or try a new black toner cartridge.
Oct 16, 2013 | Savin GENUINE RICOH FUSER UNIT (402451)...
My Savin 3515MF doesn't believe I replaced the toner. I have replaced it a few times, so I followed the same instructions as before but to no luck. HELP!! Please and thank you!
Try cleaning any excess toner from the sensors and any glass inside the same panel as the toner bottle hopper.(the glass slides in and out). Use compressed air around the area where the toner pours into the developer but be careful not to blow out the developer.
Oct 11, 2013 | Savin Copier Supplies; Toner for 3515,...
My SAVIN 2820 SCAN FUNCTION does not connect to my home network.
If you have updated your OS to Vista, Win 7 or Win 8, update the firmware
Oct 15, 2012 | Savin Office Equipment & Supplies
Toner light and message won't go out
Hello sir; You have to replace toner senser, it located at the bottom of developer unit. have any problem please contact us, good luck!
Jul 15, 2010 | Savin Office Equipment & Supplies
Savin 9945DPE cannot Network print
Did you format the new drive through the service mode on the copier? As long as the drive is compatible then it should work once you format it.
Jan 03, 2010 | Office Equipment & Supplies
SAVIN PRINTER INITIALIZATION CODES
I need to see a sample of the data file being sent to the printer. Please create a, "Print to File" and then send the file to me.
I also need to see the formatting commands that you are sending to the printer.
Don
don.farr@verizon.net
Oct 19, 2009 | Savin 9935DP Laser Printer
Can I scan directly to my computer without having to scan via email with a Savin 3515MF machine?
Apr 07, 2009 | Office Equipment & Supplies
"user tools"
"system Settings"
Mar 02, 2009 | Office Equipment & Supplies
SAVIN 3515MF
Mar 12, 2008 | Office Equipment & Supplies
22 people viewed this question
k24674
