Question about InFocus X9 DLP Projector
Infocus x9 lamp failed error
Hello I've just changed my lamp and still get the lamp error. The infocus logo shows for about five secs and then it oes off. I've tried reset the lamp hours and opened the projector and cleaned everything I could. I don't think the fan is the error because it blows just fine. I think that it might be the color wheel, but to be honest I really don't know :-( Hope u guys can help me out!
  • 26 Answers
SOURCE: INFOCUS Lamp replacement
If the counter had expired, the projector would not even attempt a power up. You have other issues. How many blinks on the light?
Posted on Feb 28, 2008
  • 26 Answers
SOURCE: Infocus x1a projector shuts down after 30 seconds - dust problem ??
Most likely, if it is a thermal problem, your main cooling fan has quit or is stopping after a short period. The problem is, I've seen several of these do this, and in every case, it is not the fan that has failed, but the Controller Board. And that is a very expensive part.
Posted on Mar 12, 2008
cammykins
  • 149 Answers
SOURCE: Infocus 4805 blinking red light problem
My first questions is:
Is this the first lamp you have placed into your Infocus pj? If not, did you reset the hours when you did it last time? Otherwise that can also confuse the projectors internal system thinking there is NOT a new lamp in there and there for make it stop working once the clock hours are expired and over the 3000-6000 suggested hour life.
Let me know so I can help trouble shoot other possible problems.
Posted on Oct 27, 2008
  • 167 Answers
SOURCE: Can't start infocus sp7200 after changing lamp.
The end of lamp timer has reached it's limit and won't let the new lamp strike. What you need to do is Reset the end of life timer. To do this, with the projector switched off press and hold both the up and down Brightness buttons on the projector. while holding them in turn on the projector. Continue holding the buttons in for 10 to 15 seconds This will reset the end of life timer in the projector.
Cheers
Posted on Jan 16, 2010
caroldon
  • 17130 Answers
SOURCE: What causes white vertical lines on dlp projector?
Possible fault on the mother board as there are noise on the LCD display. You might need help to sort this out if the fault does not clear even after the lamp works for some times.
Posted on Nov 07, 2011
How to reset projector hours for Infocus IN72 P720
Hello
To reset lamp hours:
Menu => Settings => Service
In this window; you can select Lamp reset.
Press Enter or OK.
Oct 04, 2011 | InFocus IN72 Multimedia Projector
HI I WANT SERVICE CODE OF INFOCUS LP600 ASKC175
I am not exactly sure what service code you are searching for, what is happening with the projector? You turn it on and immediately it's looking for a code? Please let me know and I can help
Tim
Sep 13, 2010 | IBM Office Equipment & Supplies
My Infocus 4805 is just showing the INFOCUS logo and not showing the picture from the TV. all connections are correct but no signal....help
Powering On
  • If your InFocus 4805 projector is having a hard time powering on or doesn't power on at all, it could be one of two things. Due to the extreme temperature of the lamp that causes the temperature of the projector to rise, every InFocus 4805 projector has a cooling system. Check your projector's cooling solution, as it may need to be replaced. Also check the projector's fan---if the fan doesn't spin, the unit will not turn on. If the problem is the fan, you'll have to get it replaced. You can do this at the same place you bought your projector.
  • The Lamp
  • If your InFocus 4805 Projector powers on but does not project any light, the lamp will need to be replaced. All projector lamps must be replaced at some point---how often usually depends on how much use the device gets. Simply order a replacement lamp, unscrew the old one and screw the new one in. The projector will then work like new.
  • Color Wheel
  • If your InFocus 4805 projector powers on and is displaying images but the colors on the images appear warped or are not in the proper places, your "color wheel" will need to be replaced. The color wheel is a small device that essentially acts like a prism. Light is projected through it and it displays the appropriate colors on screen the way they appear in the original video source. Order a replacement color wheel that fits your model and use your instruction manual as a guide as you swap the old one out and put the new one in.
  • Aug 08, 2010 | InFocus ScreenPlay 4805 Multimedia...
    Infocus in3106 keeps showing me replace lamp message after i already did'it
    Hello there, you need to check the lamp connection properly it may not be properly fitted into position that can be the reason you get that message.
    Aug 03, 2010 | InFocus IN3106 DLP Projector
    Infocus sp5000 red led blinks once indicating lamp
    be sure and reset the lamp hours. Flash the software if you can. These are also notorious for the ballast cable on the inside of the lamp housing backing out when a lamp is removed or replaced. If you have the cover off push the cables back into place and hold them there as you install the lamp. Also look directely at your lamp in the center and move it side to side and up and down. If there are any cracks or frosty looking spots or bubbles in the mirror of the lamp that are visible, then the lamp is probably shot. If all this fails, most likely it is the power supply, or the lamp door has gotten mishapen from heat and the actuator on the lamp door isn't making full contact with the safety swith.
    Jan 29, 2010 | InFocus SP-LAMP-017 Projector Lamp for...
    Hi!My Infocus sp 7210 blows the lamp.I got new one,change fuse,switch it on and press brighteness buttons to reset counter.Projector works,funs are working too,but lamp not lights.. I have no idea what is...
    Hello, Well sorry to say but you may have a new lamp that doesn't work.
    1) There are a increasing number of bad Chinese knock offs that are made very poorly and usually fail within a few hundred hours or do not work at all. The old saying "you get what you pay for" is actually applicable here. An OEM lamp is pretty pricey I know but buying 3 or 4 cheap Chinese ones cost's more in the long run.
    2) Another possibiltiy is the power supply for the lamp has failed and your old lamp may not be dead quite yet. If you are sure the old lamp did fail then most likely the problem would be the above #1
    Cheers
    Dec 28, 2009 | InFocus ScreenPlay 7210 Multimedia...
    How do i find out if i need a new lamp for my infocus 4805. when i turn it on the fan blows for a cpl secs and the green light blinks a few times, but i dont get anything saying the lampis out
    when you power it on, do you hear a high-pitched whir? if not, you need to replace the colorwheel. it's also the colorwheel if you hear a buzzing instead. if the colorwheel does not spin, the lamp won't come on. if the colorwheel is ok, check the lamp. is the screen on the side of the lamp clogged with dust? is the inside of the lamp bulging, spotted, or foggy? if so, replace the lamp and clean out your projector with canned air. dust blocks air flow and keeps in the heat. this shortens the life of your lamp and projector. if you do need the colorwheel replaced, you could get the part from an infocus service center and do it yourself, or send it in for repair. either way, try av solutions in ny. they're really good. www.avsolutionsny.com
    Dec 27, 2009 | InFocus ScreenPlay 4805 Multimedia...
    The lamp warrning light on my infocus in24+
    If you are able to measure/show any continuity whatsoever your bulb is way past bad!!
    As these lamps do not have filaments.
    If you have replaced the lamp you can easily reset the lamp timer from the projector menu.
    This procedure can be found in the user manual as well.
    Cheers
    May 02, 2009 | InFocus Projector Lamp for IN24+, IN26+
    Lp640 infocus   1 red light blink
    lamp is not striking after 5 tries. try new lamp. if it still doesn'r work, you need to have the ballast replaced.
    Jan 06, 2009 | InFocus LP640 Projector Multimedia...
    ---------->> My Infocus Screen Play 4805 -Popped*
    Hello David,
    The best way to find the best price is to do some hunting/research. Google "infocus 4805 lamp"
    and wade through to find the best price.
    You will find instructions on the lamp replacement procedure in the manual. If you dont have the user manual browse to www.projectorcentral.com and search infocus 4805 and on their spcifications page there is a "user manual" Acrobat PDF icon.
    click on the icon to open the manual in pdf format
    Take Care!
    Jun 17, 2008 | InFocus ScreenPlay 4805 Multimedia...
    Open Questions:
    See all InFocus X9 DLP Projector Questions
    InFocus X9 DLP Projector Logo
    20 people viewed this question
    Top InFocus Office Equipment & Supplies Experts
    jasbo
    jasbo
    Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
