Question about InFocus X9 DLP Projector
Infocus x9 lamp failed?
Hello I've just changed the lamp and still get the lamp failed error on my x9. The infocus logo shows up for about 5 secs and then goes off. I've opened the projector and cleaned everything I could. I think there might be something wrong with the color wheel but don't really know. Hope u guy can help me!
  • 26 Answers
SOURCE: Infocus x1a projector shuts down after 30 seconds - dust problem ??
Most likely, if it is a thermal problem, your main cooling fan has quit or is stopping after a short period. The problem is, I've seen several of these do this, and in every case, it is not the fan that has failed, but the Controller Board. And that is a very expensive part.
Posted on Mar 12, 2008
SOURCE: Bulb failures
I experienced the same thing, only to discover it was the ballast that powers the lamp. I believe INFOCUS repairs for $390.00 per the technician that I spoke with on the phone at INFOCUS.
Posted on Jul 19, 2008
cammykins
  • 149 Answers
SOURCE: Infocus 4805 blinking red light problem
My first questions is:
Is this the first lamp you have placed into your Infocus pj? If not, did you reset the hours when you did it last time? Otherwise that can also confuse the projectors internal system thinking there is NOT a new lamp in there and there for make it stop working once the clock hours are expired and over the 3000-6000 suggested hour life.
Let me know so I can help trouble shoot other possible problems.
Posted on Oct 27, 2008
projdoc
  • 2237 Answers
SOURCE: InFocus LP120 Projector shuts off automatically
overheating or power supply problem.
Posted on Sep 03, 2009
  • 567 Answers
SOURCE: my Infocus 4805 is just showing the INFOCUS logo
Powering On
  • If your InFocus 4805 projector is having a hard time powering on or doesn't power on at all, it could be one of two things. Due to the extreme temperature of the lamp that causes the temperature of the projector to rise, every InFocus 4805 projector has a cooling system. Check your projector's cooling solution, as it may need to be replaced. Also check the projector's fan---if the fan doesn't spin, the unit will not turn on. If the problem is the fan, you'll have to get it replaced. You can do this at the same place you bought your projector.
  • The Lamp
  • If your InFocus 4805 Projector powers on but does not project any light, the lamp will need to be replaced. All projector lamps must be replaced at some point---how often usually depends on how much use the device gets. Simply order a replacement lamp, unscrew the old one and screw the new one in. The projector will then work like new.
  • Color Wheel
  • If your InFocus 4805 projector powers on and is displaying images but the colors on the images appear warped or are not in the proper places, your "color wheel" will need to be replaced. The color wheel is a small device that essentially acts like a prism. Light is projected through it and it displays the appropriate colors on screen the way they appear in the original video source. Order a replacement color wheel that fits your model and use your instruction manual as a guide as you swap the old one out and put the new one in.
  • Posted on Aug 08, 2010
    What causes white vertical lines on dlp projector?
    Possible fault on the mother board as there are noise on the LCD display. You might need help to sort this out if the fault does not clear even after the lamp works for some times.
    Nov 05, 2011 | InFocus ScreenPlay 5700 Multimedia...
    My Infocus 4805 is just showing the INFOCUS logo and not showing the picture from the TV. all connections are correct but no signal....help
    Powering On
  • The Lamp
  • Color Wheel
  • Aug 08, 2010 | InFocus ScreenPlay 4805 Multimedia...
    Infocus in3106 keeps showing me replace lamp message after i already did'it
    Hello there, you need to check the lamp connection properly it may not be properly fitted into position that can be the reason you get that message.
    Aug 03, 2010 | InFocus IN3106 DLP Projector
    Hi!My Infocus sp 7210 blows the lamp.I got new one,change fuse,switch it on and press brighteness buttons to reset counter.Projector works,funs are working too,but lamp not lights.. I have no idea what is...
    Hello, Well sorry to say but you may have a new lamp that doesn't work.
    1) There are a increasing number of bad Chinese knock offs that are made very poorly and usually fail within a few hundred hours or do not work at all. The old saying "you get what you pay for" is actually applicable here. An OEM lamp is pretty pricey I know but buying 3 or 4 cheap Chinese ones cost's more in the long run.
    2) Another possibiltiy is the power supply for the lamp has failed and your old lamp may not be dead quite yet. If you are sure the old lamp did fail then most likely the problem would be the above #1
    Cheers
    Dec 28, 2009 | InFocus ScreenPlay 7210 Multimedia...
    Infocus X1 picture freezes and dissapears and then comes on again
    your display settings may be off, so change settings to factory reset and you may have to drop the resolution on your computer. you may also have a bad cable, so try a different cable.
    Jul 03, 2009 | InFocus X1-RE Projector, Factory...
    The lamp warrning light on my infocus in24+
    If you are able to measure/show any continuity whatsoever your bulb is way past bad!!
    As these lamps do not have filaments.
    If you have replaced the lamp you can easily reset the lamp timer from the projector menu.
    This procedure can be found in the user manual as well.
    Cheers
    May 02, 2009 | InFocus Projector Lamp for IN24+, IN26+
    Infocus x1a shuts down after 5 minutes
    3 red flashing is a lamp error, not the fans. the lamp has a problem striking. make sure it's pushed in and plugged in all the way. if the lamp is not that old, the power supply needs replacing.
    Feb 23, 2009 | InFocus X1 Multimedia Projector
    Lp640 infocus   1 red light blink
    lamp is not striking after 5 tries. try new lamp. if it still doesn'r work, you need to have the ballast replaced.
    Jan 06, 2009 | InFocus LP640 Projector Multimedia...
    ---------->> My Infocus Screen Play 4805 -Popped*
    Hello David,
    The best way to find the best price is to do some hunting/research. Google "infocus 4805 lamp"
    and wade through to find the best price.
    You will find instructions on the lamp replacement procedure in the manual. If you dont have the user manual browse to www.projectorcentral.com and search infocus 4805 and on their spcifications page there is a "user manual" Acrobat PDF icon.
    click on the icon to open the manual in pdf format
    Take Care!
    Jun 17, 2008 | InFocus ScreenPlay 4805 Multimedia...
    Infocus lp 530
    Hello, That should absolutely reset the lamp timer.
    This is crucial: Press and hold the volume - button, then press the source button (while still holding down the volume - button) for 5 seconds.
    Make Sure you hold them both down for 5 Seconds!
    I hope this helps you.
    Cheers
    May 09, 2008 | InFocus LP530V Video Projector 2000 ANSI...
    Open Questions:
    See all InFocus X9 DLP Projector Questions
    InFocus X9 DLP Projector Logo
    43 people viewed this question
    Top InFocus Office Equipment & Supplies Experts
    jasbo
    jasbo
    Electro Med Services...
    Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
