How do you fix an SC 548 error on MPc4000 - Office Equipment & Supplies
idriss47
  • 26 Answers
SOURCE: ricoh rex rotary sc 548
Hello wajidsn
SC548 : "Fusing Installation Error.Fusing Unit Set Error"
Posted on Jan 07, 2009
  • 1297 Answers
SOURCE: my ricoh aficio mp3010 keeps comming up with error
You need acces service progpam:
1. Press the clear modes key.
2. Enter 1-0-7.
3. Press the clear/stop key for more than 3 seconds untill the service program menu appears om the touch pamel display.
4. Enter in the service menu.
5. Turn OFF the power switch,unpluged cords,wait 10 sec,plugged cords then turn ON power switch.
Posted on Aug 02, 2009
SOURCE: code shows SC 548 how do I clear this
SC548: Fusing unit installation error - Definition - [A]
The machine cannot detect the fusing unit when the front cover and right cover
are closed.
- Possible causes -· Fusing unit is not installed
· Poor fusing unit connection
check the 2 sensors on the left hand side of the copier (as you look at where the fuser is located). These get knocked & moved out of postion,
this sc 548 usually happens when paper jam occurs and user does not properly fit the fuser... also not fiitted properly due to some foreign object in between fusing belt and the sensor...
Enter SP 5810 (SC code reset), select “Execute”, select “close”, exit SP mode then turn main power switch off and on.
to enter SP mode press yellow C button press 1 0 7 on numeric keypad and then hold down the orange C button from the menu select copier SP then type in 5801 and press # selest execute then power off and back on. Your machine should now be working. Hope this helps. if this doesnt solve ur problem then try contacting ur ricoh service tech
good luck
Posted on Aug 09, 2009
  • 161 Answers
SOURCE: Error code SC 548 on Ricoh Aficio 1022 copier. Need to reset m/c
sc 548- service call - fusing unit not set properly
the fusing unit connector may be loose.
u can reset the error by entering the service mode (careful -do not change anything )
to enter the service mode press [all clear](yellow button) ,[1],[0],[7],[clear](orange button)and keep the button pressed for about 5 sec.
go in copier options , then mode 5, then option 810
and execute(or 1 & ok)
(careful -do not change anything else)
Posted on Jan 16, 2010
  • 14 Answers
SOURCE: ricoh 820 sp c 820
An SC548 error code indicates a fusing unit installation error. I would suggest that you turn the machine off, pull the fusing unit out, inspect it for any obvious damage, put it back in, and turn the machine back on. If it still doesn't work after reseating the fusing unit, it is likely that there is something wrong with the fusing unit and I would recommend that you seek professional help.
Posted on Feb 28, 2011
Ricoh mpc 4000 sc 531
531 Exhaust fan motor error
The IOB does not receive the lock signal for 10 seconds after turning on the exhaust fan motor. • Defective exhaust fan motor or connector disconnection. • Defective IOB • Disconnected harness http://www.printcopy.info/?l=en&mod=free&chap=erc&brand=Ricoh&model=Aficio%20MP4000
May 23, 2015 | Ricoh MPC4000
Que significa error sc 863 18?
HDD data read failure- q partition
Format the hdd or replace.
Apr 11, 2015 | Ricoh AFICIO MPC4000 MPC4501 SD YLD...
How do I fix error code sc 548?
The machine cannot detect the fusing unit when the front cover and right cover are closed.
Possible causes:
Check the 2 sensors on the left hand side of the copier (as you look at where the fuser is located). These get knocked & moved out of position. SC 548 usually happens when a paper jam occurs and user does not properly fit the fuser back in place
The fuser may also not be fiitted properly due to some foreign object in between fusing belt and the sensor
From the panel, enter SP 5810 (SC code reset), select "Execute", select "close", exit SP mode then turn main power switch off, wait 30 seconds, the turn it back on.
To enter SP mode, press the yellow C button press 1 0 7 on numeric keypad and then hold down the orange C button. from the menu select copier SP then type in 5801 and press # select execute then power off and back on. Your machine should now be working.
Hope this helps.
Sep 04, 2014 | Savin Office Equipment & Supplies
Jan 15, 2010 | Ricoh Aficio 2022 All-In-One Laser Printer
Code shows SC 548 how do I clear this
are closed.
good luck
Aug 09, 2009 | Ricoh Aficio CL3500N Laser Printer
I have a Savin 9955DP/9965DP copier with a funtional service code SC548-00 is there anything i can do to fix the problem?
The SC 548 error usually occcurs in the fuser section when it ahas been reset incorrectly the drive and gears are not locking properly or the sensor has not registered the fuser correctly I would look in these areas check the seating of the fuser you can reset this in the modes with 5-810 sc reset then turn off.
Jun 24, 2009 | Ricoh Aficio 450 Copier
Service code SC 548 on a Ricoh Aficio SPC 811dn printer, what is it and how to correct?
I have sc 548 error code also. I was following your instruction, but i couldn't enter to service mode. How do i prepare it? Please write this instruction to me step by step.
Apr 23, 2009 | Ricoh Aficio 1027 All-In-One Laser Printer
Ricoh MP 2510
Fuser installation error. Fusing unit set error. Remove the fusing unit out of the machine and reinsert it. It isn't seated in there properly. Once you do that the error code will go away.
Sep 15, 2008 | Ricoh FT5832 Copier
723 people viewed this question
k24674
jasbo
jasbo
