Question about Kenmore White Electric Stove
Where to find the fuse panel in stove
The electical outlet on the top of the stove is not working and I need to know where the fuse panel is located to replace it. model number is532120970-53212.The stove was purchesd in 2004
Where are the fuses on a fridgidare range,glass top,everything works except thesettings for my stove doesnt light up
Thank you for your post, friend!
Based off what you have described the settings on your Frigidaire range do not light up and you would like to know the location of fuses. There are no fuses within your range, if the control panel is not lighting up it could be a short within your panel and that may need to be replaced. I would recommend having a professional technician out to disassemble your range and replace any electrical components. This will protect you from any personal injury and future issues with your range. Hopefully this information is helpful. -Matt
Mar 10, 2015 | Frigidaire Stove/Oven/Range Black Glass...
Where is the fuse in a sr4002?
Generally behind the back panel, some models use a fusible link rather than a glass/wire fuse, un less you know what it looks like you will need a multimeter to check for continuity till you locate it.
May 02, 2014 | Amana 30" Self Cleaning Electric Range...
Admiral ultima stove
Without knowing much about different stoves they do all have a central break out point for the electrical. I would suggest a professional look at it but if you dig in yourself trace back the burner wiring back to the source where it breaks out to the four. I am sure that is where you problem is.
Mar 12, 2014 | Cooktops
Amana Glass cooktop 2 out of 4 burners not working
it is not a fuse. as if it shorted it may blow it and then nothing .. the sw to either one burner is at fault replace the sw 's ( both and the cook top should be ok . sw cost around 25 to 40 ea ..
Jul 13, 2010 | Amana AKT3040 Electric Cooktop
My house wires from the electic stove top has 3 wires and my new bosch electric top has 4 on red, white, green, yellow?
hook the red and yellow off the new stove to the two hot phases-then connect the white on the new unit to the neutral power connection and finally the green wire can hook to the same neutral wire also as long as the power comes directly from the main electrical panel in the home, but not a sub-panel
Nov 15, 2009 | Bosch 30 in. NET7452UC Electric Cooktop
Replacing stove. What to do with blue and yellow wires?
First, please don't do your own electrical work if you are unsure about what you're doing. It's worth it to hire an electrician.
Not sure what the blue and yellow wires could be. The others are standard 220V colors, but that doesn't mean that they are connected the standard way in the panel. If you know how to remove the panel cover and look at the breakers, make sure you do that before you assume anything. If you don't know how, call an electrician.
Assuming the blue and yellow are no longer needed, and that the other four are wired properly, you should disconnect the blue and yellow wires on both ends and remove them if possible. If you can't remove them, you should insulate both ends and mark them as being disconnected.
Oct 02, 2009 | Cooktops
I have a brown brand gas stove and the oven is not coming on stove has no electical cords
hello. i can help. here is the manual for your stove. http://www.brownstoveworksinc.com/pdf/gas_manual.pdf
look on page 17 as it tells you how to light the pilot light.
Jun 05, 2009 | Brown Stove Works 23 in. TL03-3 Gas...
3 wire cook top to a 4 wire outlet
Older 3 wire connectors where Wht=Neutral Ground Return, Red=One Phase Hot, Blk=Second Phase Hot, of 220VAC stove connections.
Newer Electrical code standard has a forth wire that is bare copper for a separate safety ground return.
I suggest you but a 4 wire pig tail cable for your stove top, available at Depot or Lowes, and connect 3 wires of this 4 wire cable just like the 3 wires are now connected. The 4th bare copper safety is attached to any metal part of the stove. Find a screw you can loosen to wrap it around and tighten.
Mar 02, 2009 | Jenn-Air JED8230 Electric Cooktop
Elect Ign not sparking, but get gas, other appliance working.
I don't know, I did nothing, it just started working again??????
Jan 28, 2009 | Maytag 30 in. CSG7000 Gas Cooktop
Kenmore White Electric Stove Logo
Top Kenmore Cooktops Experts
Dan Webster
Dan Webster
jdthefixer
mcgsp
Level 1 Expert
Are you a Kenmore Cooktop Expert? Answer questions, earn points and help others
