Question about Health & Beauty
Hair rebonding process - Health & Beauty
Anisotropic conductive film (a c f)
they use heat sealing presses in china.
Dec 06, 2014 | Televison & Video
Are the hair transplant results permanent?
The process followed in hair transplant is by taking healthy follicles from part of body which is having enough thick and dense hair, usually the back of your head. So the hair are natural and gives you best result and long term appearance.
Affordable Hair Transplant Cost In Ahmedabad at Avenues Cosmetic Avenues...
Jul 19, 2013 | Hairart Health & Beauty
I am thinking of using laser treatments to remove hair on my back. What kind of hair color is it good for?
Laser hair removal has seen best results on light skin with dark hair. It does not work well on blond or white hairs. People generally need around 8 treatments to complete the hair removal process.
Feb 18, 2013 | Health & Beauty
Topchic 12bs did not color hair
Try 2 0z of 40 volume goldwell developer to 1 oz 12bs topchic color. process at least 45 min
Jan 13, 2013 | Goldwell Topchic Hair Coloration 2 1 Tube...
Can you dye your hair after you get brazilian hair straightening?
It is not recommended to apply more than one chemical process to your hair, since it is very damaging. But when working in the salon, I would suggest that the client wait 2 weeks before having another chemical process done (perming or coloring) if that was what the client wanted.
So yes you can, but it may be very damaging to your hair.
Nov 23, 2010 | Health & Beauty
Window fell down on 2001 polo
Sorry I see that it is a Jetta, the window has 2 tabs that are glued to the bottom of the glass these will likely need to be rebonded.
Feb 22, 2009 | 2002 Volkswagen Jetta TDI
Side window is not working
sometimes the glass "bonding" comes loose from the regulator inside the door. a glass shop can usually rebond it with special glue and they work fine. hope this helps
Jan 31, 2009 | 2002 Ford Expedition
Motorzr v8 Bluetooth problem
The Bluetooth Transmitter/Reciever in the phone is probably defective. You can verify this by testing it with another Bluetooth device. If it fails with another device, then you know for sure that the phone has a fault.
The fix is to change the circuit board that has the Bluetooth processing. This fix will be expensive in relation to changing the phone if the phone is out of warranty.
Jerry G.
Jun 15, 2008 | Motorola Mobility RAZR V3xx Cellular Phone
Health & Beauty Logo
85 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
