Cayman rh thinkcentre A-8326
I WANT TO DOWANLOAD SOUND DRIVER FOR WINDOWS 7 32BIT IN CYMAN RH THINK CENTRE
2 Suggested Answers
joecoolvette
  • 5660 Answers
SOURCE: I need the beep codes for a think centre A52 it has a Cayman-Rh motherboard
IBM BIOS Beep Codes,
The HMM (Hardware Maintenance Manual) states any beeps past 3-1_ mean bad chips on the motherboard. Means motherboard replacement. Just out of curiosity are there any bad capacitors on the motherboard? Post back in a Comment. 1) http://capacitorlab.com/visible-failures/index.htm 2) http://www.aliexpress.com/store/product/Desktop-Motherboard-for-IBM-945G-A52-8297-CAYMAN-RH-Free-shipping/208174_485306445.html
Posted on Nov 23, 2012
Power windows wont roll up or down on 2006 Cadlliac cts
With the electronic's involved ,your best bet would be to take to a qualified repair shop . The door 's have electronic control module inside that control door lock's an window operation . Hooking up a professional or factory scan tool an viewing input data an checking DTC'S - diagnostic trouble code's would be the first step any professional technician would do . You probably have no idea what these are ? Messing with these systems can render your vehicle unuseable if you do not know what you are messing with .
Power Windows System Components
The following components are used to control the power windows:
• Driver door module (DDM)
• Passenger front door module (PDM)
• LH rear door module (LRDM)
• RH rear door module (RRDM)
• Driver door switch assembly (DDSA)
• RH front power window switch
• LH rear power window switch
• RH rear power window switch
• LH front power window motor
• RH front power window motor
• LH rear power window motor
• RH rear power window motor
• Class 2 serial data link
• DR MOD PWR C/B 30 Amp circuit breaker
• DRIVER DR MOD 10 Amp fuse -- DDSA and DDM logic, DDM internal driver operation.
• PSGR DR MOD 10 Amp fuse -- PDM logic and internal driver operation.
• REAR DR MOD 15 Amp fuse -- LRDM and RRDM logic and internal driver operation.
Power Windows Operation
The vehicle is equipped with power windows controlled by the door modules. Each passenger door window can be operated, either from a power window switch built into the driver door switch assembly (DDSA) , or, from a power window switch mounted locally on its associated door. The driver door window can be operated only from the driver door power window switch built into the DDSA.
When the driver door module (DDM) receives a driver door window switch request from the DDSA, the DDM examines the request and inspects to see if it has received any messages from any of the other vehicle modules prohibiting the movement. If no prohibitive messages have been received, the DDM then applies power and ground to the driver door window motor to move the window as requested.
When a passenger door module, passenger front door module (PDM), LH rear door module (LRDM), or RH rear door module (RRDM), receives a window switch request from, either the DDSA or the window switch mounted locally to its door, the passenger door module examines the request and inspects to see if it has received any messages from any of the other vehicle modules prohibiting the movement. If no prohibitive messages have been received, the passenger door module then applies power and ground to its associated window motor to move the window as requested.
So do yourself a favor an take it to a qualified repair shop.
Nov 22, 2017 | Cars & Trucks
Nov 23, 2012 | Computers & Internet
My sound driver not a work properly . my computer start to no sound
Try reinstalling the audio driver.
You can download the drivers from Gigabyte WEB support site,select your model motherboard to download :-http://www.gigabyte.com/support-downloads/support-downloads.aspx
Dec 19, 2010 | Gigabyte GA-8I945GZME-RH Motherboard
I have no sound card
RH click on my computer and go to manage,
Click on device manager and look for any yellow x's at the sound area.
if there are any, RH click on them and click on uninstall.
Then go to the top of the tree and RH click and click on Rescan.
The drivers will be reloaded.
If there is still a yellow x on anything, most likely you have a hardware issue.
Apr 06, 2010 | Microsoft Windows XP Professional SP2
I instaled windows then the audio driver doesn't work
May be problem on your audio setting,i mean front panal audio setting jumper
Jan 19, 2010 | Gigabyte GA-8I865GME-775-RH Motherboard
What is the best cpu to go in to a lenovo bora-rh mobo?
Goto http://www,crucial.com
Click on - free memory scan - allow the activex control to install if prompted. The program will perform a quick scan of you system and provide you with reccomended compatible memory options. Crucial is who I use and they have a no fuss retun policy.
Also, for CPU upgrades - checkout http://www.pricewatch.com - Ultimately you have to make the decsion - cost vs. performance - Good Luck - Hope this helps
Mar 16, 2009 | IBM ThinkCentre A51 PC Desktop
Computers & Internet Logo
284 people viewed this question
David Payne
David Payne
