Question about Samsung MidSize Canister Vacuum Cleaner Wtih Metal Telescoping Wands Vari
Samsung vacuum cleaner SC56B0
How to take the cover off in order to get to the electrics
I have a Samsung SU3364 vacum cleaner have never been able to use the crevice tools as there is no suction when you take pipe off, only when you use it as a floor vac, any suggestions have tried every
If the vacuum is old, the intake path from the hose to the dirt receptacle may be plugged from years of dust, dirt and grime. This happened to one of our vacuums, and I had to take off the bottom guard, the belt and the sweeper bar to access the intake, and it took me about an hour to get it unplugged.
If this is a new machine, the hose may not be properly connected when you are using the crevice device. Check the manual for proper installation.
Jul 22, 2014 | Samsung 5490M Lightweight Upright Vacuum...
Vacuum bags
It would help to know your postal code in order to to find a shop that caries bags for that model. Otherwise you can get them online such as amazon. Samsung Type VP-95 are the bags and should be readily available; also evirocare make a bag for them which is package #211.
Nov 12, 2013 | Samsung Easy 1300 Lightweight Compact...
How do I take about my Dyson DC11 to replace the retractable power cord assembly
While it doesn't require a collection bag, a Dyson-brand vacuum cleaner can still suffer the problems of wear and tear that are prone to any vacuum cleaner--for example, a frayed power cord. If the power cord of your Dyson vacuum cleaner has become frayed, change it immediately to avoid a dangerous electrical mishap. You will need a replacement cord from an electronics service center, along with a few common household tools. You do not need electrical skills to complete the task.
Follow this steps on how to replaced the power cord assembly:
1 Unplug the Dyson vacuum cleaner's power plug from the wall outlet. Press the button on the top front of the plastic collection cover. Lift the cover off the front of the vacuum cleaner and place it aside.
  • 2 Trace the power cord to where it enters the back bottom of the vacuum cleaner. Remove the screws from the panel surrounding the power cord with a Phillips screwdriver. Remove the panel. Aim the beam of a flashlight inside the compartment so that you can see where the wires at the end of the power cord wrap around two screws on the motor assembly. Loosen these screws with a Phillips jeweler's screwdriver.
  • 3 Pull the power cord out of the compartment and dispose of it properly. Strip a 1/2 inch of insulation from the ends of the two wires of the replacement power cord. Run the wires into the compartment along the path of the original power cord--pushing the wires into the grooves inside the compartment.
  • 4 Tie a knot on the cord on the inside of the compartment to prevent the cord from being pulled out.
  • 5 Wrap the exposed end of each wire of the power cord around the loosened screws. Tighten the screws. Replace the panel and reattach the screws. Stand the vacuum cleaner right side up. Place the bottom of the plastic collection cover into the bottom front slot on the vacuum cleaner. Push the cover back on the front of the vacuum cleaner.
  • Jul 13, 2011 | Vacuums
    My Ergospace Vacuum took some apple juice in and now it makes strange noice and even threw out some sparks. Is there anything I can do my self or is it over with this vacuum cleaner? I opened 6 screws, but...
    Liquid plus electrical parts always ends up with the electrical parts losing. Juices, although they will dry, will leave behind a sticky residue. You'll need to replace at least the motor, but due to the other electrical components, probably be better off replacing the whole thing.
    The hidden screws are beneath the control panel. There are two tabs beneath the panel cover. Using a thin bladed screw driver release these to pop of cover. You may need to use a flashlight to be able to see the tabs and make sure they get released. If the tabs break, the cover won't stay on. Under the cover are two screw that need to come out.
    There are two more tabs in the bag well that need to be released. Remove the bag and at the top of the back of the tank you'll see two tabs. Do so with a screw driver. After this the top of the machine can be lifted off with some manipulating.
    There are electrical motor spray cleaners you can use to try to get the residue off the motor, but it's doubtful you'll be able to remove it all.
    Dec 11, 2010 | Electrolux EL4100A Ergospace Cannister...
    My mach 5 vhoover vacuum cleaner shuts itself off alsomst as though it is overheated
    No your motor is going bad. Have you ever owned an electric fan. If you can remember when the motor started going bad on it the fan would quit turning on its own.Your vacuum is doing the same thing. Please call Hoover and order a new one or go to ebay type in the make and model..
    Aug 27, 2010 | Hoover U5194-900 Mach5 Multi-Chamber...
    How do I replace the electric cord for my Simplicity Shadow Vacuum cleaner model S13L? It's a canister cleaner.
    Since the problem was with the plug on the electric cord, I replaced the plug, I cut the old plug, peel off the plastic cover on the cord, they were two wires, black & white, I purchased a new plug in a Home center, attach the wires to the new plug and it works just beautiful now, it was a two prong plug, which made it easier to fix.
    Feb 16, 2010 | Simplicity Vacuums
    Need plug c45ecue
    i went to sears web site and ordered cover # 8191782. (i don't know whybthey callmit a cover.)
    Jan 12, 2010 | Kenmore 22812 Bagged Canister Vacuum
    Hoover s3639 vacuum...cord does not rewind
    I had the same problem with my Hoover s3639. The cord rewinder started squeaking, and retracted less and less of the cord each time, until it finally stopped retracting the cord at all. Here is what I did. I hope it will work for you as well. Open the covered tool storage and remove the tools. You should see three screws. Unscrew the screws. Remove the cover. You should see the motor for the vacuum and the cord rewinder. Between the vacuum motor and the white wheel where the cord is, you should see two brass wheels that turn into each other in order to operate the cord rewinder. Spray a small amount WD-40 between the two brass wheels. This should solve your problem.
    Dec 29, 2008 | Hoover S3639 WindTunnel Bagged Canister...
    Trying to replace the mains cable on uproght cleaner mc e468,but having great trouble getting the plastic covers off
    first remove handle
    single screw rear of cleaner and slide handle horizontally rearwards
    remove access cover (2 screws) for electrical connections and switch
    Aug 09, 2008 | Panasonic Vacuums
    Samsung SC8571 VACUUM CLEANER
    Either check your local region of EBAY for any vacuum cleaner repair specialists who may be able to sell you a replacement hose/parts OR enter your postcode in Australia for this Samsung customer service:
    Dont forget to rate.
    http://www.samsung.com/au/support/repairlocation/ServiceLocationsMain.do
    Jun 13, 2008 | Samsung Vacuums
    Samsung MidSize Canister Vacuum Cleaner Wtih Metal Telescoping Wands Vari Logo
    37 people viewed this question
    Top Samsung Vacuums Experts
    woodzowl307
    ray gallant
    GARY HIVELY
    Level 1 Expert
    Are you a Samsung Vacuum Expert? Answer questions, earn points and help others
