Question about Saeco Royal Professional Espresso Machine
What is sensor error 02 for saeco royal office up
JohnnyBeans
  • 223 Answers
SOURCE: royal coffee bar
You have the go into the menu and change the setting on the "direct water supply" option to off. Your machine comes from the factory set to use direct water feed. This option tells the machine water supply to use.
Saeco Parts and Cleaning supplies
www.cerinicoffee.com
Posted on Dec 19, 2007
  • 1089 Answers
SOURCE: saeco royal digital part 0701.R05.050 broke how
HI
Its called a thumbscrew. You have pulled the nut that was molded into it out. Don't use the key to install the new one. That is why they call it a thumb screw. Finger tight. Should be able to get it from one of the online vendors. http://www.partsguru.com carries it. Wholelattelove. 1st line.com
Posted on Oct 26, 2009
Testimonial: "thanks "
  • 1089 Answers
SOURCE: my saeco royal professional has no power, no lights. What's up?
Hi
First I would check the switch on the bottom left side of the machine and make sure that it has not been turned off.
If it is on you may have a fuse out on the board. It is a very special fuse. It is a 35Ma timed lag fuse When we change them we put in a 50Ma Timed lag fuse with no problems, because the 35MaT is hard to find.
Posted on May 08, 2010
  • 1089 Answers
SOURCE: how to decalcify saeco royal exclusive coffee machine
Hi
Auto descale: To automatically descale your machine, press the scoop button or menu button if you have one, and hold it down until you enter the menu. Use the arrows on the left to scroll down until you come to Descale. Press enter and the machine will enter the mode to descale your machine. The process takes about 45 minutes. You don’t have to do a thing except mix a full water tank with descaling solution and have a container under the steam wand when your start. To start the descaling process, simply turn the steam knob. When the process is over your machine will say "Descale finished". Remove your water tank and rinse it out. Refill it with fresh water. Replace on the machine and start the descaling process over again to rinse your machine. Go back into your menu and scroll up or down 1 to signal descale and enter. Choose "Yes" and push enter so the machine will tell you when you need to descale again.
Posted on Jun 14, 2010
  • 1089 Answers
SOURCE: Saeco Royal Machine says "ventilate", but when we
Hi
For the Royal Pro there is a button that has a drop sign(water drop) on it. You have to push the drop button to flow water from the steam wand. This should clear the ventilate but if it doesn't check my other tips for "Ventilate"
Posted on Aug 03, 2011
My Saeco Royal displays Dreg Drawer full after about 3-4 cups of coffee. i have cleaned the drawer. where do i find the Dreg drawer sensor to clean it.
hi,
this is normal as there is no switch or sensor. In fact the Royal as well as the Magic and others are counting the number of coffees that you have made between two removals of the dreg drawer. For this counter to reset, you have to remove the dreg drawer while the machine is ON, and remove it for about 10s minimum.
Retry and tell me if it is better.
Hope that helps,
M.
Mar 16, 2016 | Saeco Royal Digital Espresso & Coffee...
Cappuccinatore and steam does not work
Does water come out of the wand when you press the hot water button (top left)? Try ventilating and descaling the machine. More details about each can be easily found by googling.
How to descale:
https://www.youtube.com/watch?v=W20FJlKKCO0
How to ventilate:
https://www.youtube.com/watch?v=7sZWJ9z9xTA
http://www.purebean.com.au/office/coffee-machines.nsf/office-coffee-machines/saeco-royal-cappuccino-ventilate-message-showing
Jul 24, 2014 | Saeco Royal Professional Espresso Machine
I need an owners manual for the Saeco Royal Cappuccino machine? SUP016R manufactured in 6/2006
Scroll down this page:
http://www.saeco-usa.com/en/products/household-automatic-machines/1/automatic/0/royal-coffee-bar/17/royal-coffee-bar.html
You can download the manual for your Saeco Royal in a PDF format.
Hope that helped! Thanks for using FixYa.
Jun 10, 2010 | Saeco Royal Cappuccino Espresso Machine
Cleaning of saeco royal cappucino machine
The user manual shows you how to clean your machine. If you don't have it you can download it from the Saeco site:
Apr 09, 2010 | Saeco Royal Cappuccino Espresso Machine
Personal User Code
usually the code was programmed as all 1's... Try take and it should work..
For saeco parts or cleaning supplies please visit www.cerinicoffee.com.
Mar 31, 2008 | Saeco Royal Professional Espresso Machine
Water tank empty
the sensor is not working.. try to identify the sensor inside the tank and change it..
Dec 29, 2007 | Saeco Royal Professional Espresso Machine
Saeco Royal Professional Espresso Machine Logo
375 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
83bj60
Level 1 Expert
Shehu Pro
Shehu Pro
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
