Amana ap148d Unit shut off and is blinking "STOP". What do I do?
  • 5 Answers
SOURCE: the only thing I need is a online manual
Don't bother. Couldn't find it either. If you have a Stop error try draining the water from the pan. its not sealed so be careful if you pick it up. I had that problem Amana was NO help. Started right back up!
Posted on Aug 03, 2009
  • 5 Answers
SOURCE: i have an amana portable electronic air conditioner wont turn on
try draining the water. Mine did the same thing. Started right back up. There is alot of water be careful.
SOURCE: i hav a amana ap148d and it shut off and the
you have to drain the unit. there is too much condensed water in the tray. it will do this if you run it in dehumidify mode a lot. the drain is on the bottom of the unit in the back with a rubber stopper holding the water in. its to the left of the power cord. it does this so the unit wont overflow with water all over your floor
Posted on Aug 05, 2009
  • 4 Answers
SOURCE: Amana AP148D-RB, Air Conditioner Parts
Not sure if you have fixed yet, but I had the same problem on my AP148D. There are 2 fans, 1 for the condenser (base of unit) and 1 for the evaporator (top of unit). My condenser fan disintigrated. Go to his web site and you will find a parts list for this model, and a distributer list http://service.haieramerica.com/Models.aspx?CID=231
Call this number and they have the parts in stock : 800-313-8495, mine shipped overnight. The parts are :
AC-8000-27 Wheel-blower condenser $21.81
AC-8000-26 Wheel-blower evaporator $21.81
I suspect you will need the first part. Hope this helps. Be careful to note where all the screws come from when dismantling !!!!
Posted on Jan 13, 2011
evanusa
  • 197 Answers
SOURCE: I have an Amana AP148DS
No, unfortunately there is not a way to disable the light unless you are to disassemble the unit and remove the light.
Posted on Jun 10, 2011
How do I recharge unit
call a service repairman probably needs the recharge fitting added as they do not come from factory with them on
Jul 20, 2015 | Amana 14,000 BTU Portable Air Conditioner...
I have a protable AC #AP148D from Amana I want to empty the water from the pan. where is the pan locate and how can i get to it
The pans are usually at the bottom of the unit. It may be a plug not a pan you remove to drain it.
Aug 02, 2011 | Amana Portable Air Conditioner
I cant find the booklet that goes with my Amana Portable Inroom AC. Model # ap148D
The Amana portable a/c units have their documentation at Haier America. The direct link to the manual you want is here: http://crm.haieramerica.com/PUBLIC/User%20manual%20AP148D.pdf . If you want to buy the manual, go to http://www.partstore.com/Model/HAIER+AMERICA+TRADING/Haier/AP148D/Other+Cables,+Cords+%26+Wires.aspx . Scroll down to the All Parts section and then find the Use and Care Manual for $4.56. (It is a special order.)
I also found a link to the manual for the AP148DS here: http://homeappliance.manualsonline.com/ex/thread/view/idThread/295978 . However, you need to be a registered user (free registration) to access the link. Click on the Get This Manual button and the registration/login will pop up. This may be a similar enough manual to help you use the A/C.
I hope this helps.
Jul 07, 2011 | Amana Portable Air Conditioner
I have an Amana AP148DS POrtable air Conditioner. Is there a way to turn off the LED light?
Jun 10, 2011 | Amana Heating & Cooling
I have an Amana AP148D, can I run it without an external drain hose? It says self evaporating, what does this mean?
Self evaporating simply means there is a drain pan with a heater device installed that will evaporate and condensate that drains from the unit into the pan.
You do not need the external drain pan unless the unit makes more water than the drain pan and drain pan heater can handle.
Jul 11, 2010 | Amana Heating & Cooling
Mar 02, 2010 | Heating & Cooling
The only thing I need is a online manual instructions for amana ap148d so I can print.
Jul 27, 2009 | Amana Portable Air Conditioner
I hav a amana ap148d and it shut off and the screen displays stop and wont turn bak on
Empty the water pan. It not sealed so dont slosh it around. Mine did the same thing. Amana rep was an ***. Wouldn't give me an inkling of what to do. So i started to fiddle around. There was a lot of water in it Be careful. I brought mine to the tub and drained it for close to 2 min. Started right back up!
Jul 18, 2009 | Amana Heating & Cooling
I have an amana portable electronic air conditioner wont turn on
Jun 30, 2009 | Amana Portable Air Conditioner
Heating & Cooling Logo
69 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
