Question about Jensen VM9216BT 7" Touch Screen DVD, MP3, iPhone, USB, RGB Receiver
DVD bypass code for Jensen VM9216BT
I tried the "543210" and "1264" it does not work for this model.
  • Zane Johnston
    Zane Johnston Mar 12, 2014
    For the Jensen VM9216BT you do not need a code. Simply run a wire from the pink wire (located in the cluster of RCA Jacks and video input and outputs) to ground.
  • Zane Johnston
    Also, the code for the bluetooth is 1234.
First Insert the DVD, After the disc loads and plays you will see a blue screen telling you "it is unlawful to view video while driving" 1)Activate the brake sequence and disable the blue screen using the hand brake, the switch method or anything else to give the unit its three pulses to disable that blue screen. 2) Next, on the main remote press stop twice, then 1, 2, 6, 4. You will now see a hidden menu that says: Region Code Brake Override Macrovision (Watch all the burned and pirated movies you want if this option is off) Loader Version Model Version 3) Using the right joystick on the unit, navigate to the options of your choice, click on them to toggle on, off or which region code you want. This is what you want: Region Code: 1 Brake Override ON
Macrovision: OFF When your done, click SYS SETUP on the main remote TWICE to save the settings
Posted on Dec 31, 2013
    Problem Solver:
  • 14 Answers
1: Go into AM/FM mode
2: Hit "setup" on the remote control
3: Enter 543210 on the remote,
listening for the beep for each number
entered
4: A new menu will appear. Touch the button that has the hammer/
screwdriver on it in the upper left-
hand part of the screen.
5: Select Brake bypass to "ON" and hit
the "X" near the bottom of the screen. There is the code.
Posted on Jul 16, 2013
  •  Raul Lugo Jr.
    Raul Lugo Jr. Jul 16, 2013
    Doesnt work. I tried it many times
  •  Raul Lugo Jr.
    Raul Lugo Jr. Jul 23, 2013
    Anyone else know what might work
What video format can it read?
According to the manual, http://www.jensenmobile.com/mobile-multimedia/?sku=VM9216BT under the Support/Manuals tab, the VM9216BT reads VCD, SVCD, XVid ,AVI, MPEG 1/2 formats. Commercial DVDs will work if you match the device Region with the discs region code. (All or Region 1 in the US). The DVDs should be DVD-5 (single-sided, single layer), DVD-9 (single-sided, double layer), DVD-10 (double-sided, single layer) or DVD-18 (double-sided, double layer). Note: video CDs and DVDs, like audio CDs, need to be finalized by the drive that burned them.
I hope this helps.
Sep 03, 2013 | Jensen VM9216BT
Bypass code that works for playing video .
ground the yellow wire and then it will always play regardless of the gear its in
Apr 24, 2010 | Jensen VM9510 Car DVD Player
Can't find Jensen UV10 e-brake bypass code.
Ok what you gotta do is connect the pink e-brake wire with the black wire that is already connected to the radio as the grounding.
UV10 Works 100%!!!!
Greetings from Montenegro
Jan 28, 2010 | Jensen Car Audio & Video
Jensen uv8 bypass code didn't work
no the code should work . unless jensen put a stop to the code in the newer modles.
Jan 19, 2009 | Jensen VM9510 Car DVD Player
Jensen 9512 wont play while driving
go to www.google.com then type JENSEN CODE and there is page that tell you how.
Dec 13, 2008 | Jensen VM9510 Car DVD Player
Need bypass code for Jensen VM9311TS
Here it is how brother,insert a dvd movie,next use the toggle switch sequence to get image,next press stop button twice on the remote,then press 1 2 6 4 on the remote,you will now see a menu that says
Regon Code
Brake Override(I know you are drooling by now)
Macrovision
Loader Version
Model Version
Using the right joystick on the unit,navigate to the options of your choice,click on them to toggle on,off or which region code you want.
This wht you want.
Region Code 1
Brake Override ON
Macrovision OFF
When you are done,click SYS SETUP on the main remote TWICE to save the settings and vingo.
Nov 22, 2008 | Jensen VM9510 Car DVD Player
Pe-wee dvd codes
i am looking for bypass code for a xdvdn8190 can you please help me.
Aug 03, 2008 | Jensen VM9410 Car DVD Player
Jensen in dash dvd monitors
jensen double din dvd monitor it a uv8020 model to bypass the e brake or parking brake
Dec 19, 2007 | Jensen VM9510 Car DVD Player
How do i do to bypass my jensen vm9312
go to www.ecoustics.com then click on forum at top click car audio then multimidea. and read Teir are bypass codes for several models here.just have to look for them.
Dec 18, 2007 | Jensen VM9510 Car DVD Player
Jensen vm9311
Need to know and bypass codes for the jensen 9311 but dont have the remote...
Oct 21, 2007 | Jensen VM9510 Car DVD Player
Jensen VM9216BT 7" Touch Screen DVD, MP3, iPhone, USB, RGB Receiver Logo
717 people viewed this question
Top Jensen Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Jensen Toy Expert? Answer questions, earn points and help others
