Question about Refrigerators
Frig liner is cracking
The liner in my 2 year old side by side frig is cracking. the repair men that the protection plan we have put epoxy glue on them, they said they do no harm to the frig it is just cosmetic. the epoxy is cracking plus there are more cracks appearing. model # 106.54584400
  • 3 more comments
  • judyfay Aug 28, 2007
    This is a kenmore refrigerator
  • judyfay Sep 17, 2007
    Is the cracking a defect? It is cracking on the outside wall to the front of the frig. I have a 5 year protection plan, and they have been out to fix it 3 times and there is more cracks appearing. If it is a defect and is it causing the frig not to perform properly?
  • judyfay Sep 18, 2007
    the repairman said he has had others with cracks but further back. Where they put a partial liner in, but this is about 2 to 3 inches inside the frig so they cant use that. The shelves on this frig are attached to the back wall of the frig not on the sides. Only the drawers are. Cracks are up alot higher than that and to the front.
  • Anonymous Nov 30, 2007
    MY FRIGERATOR IS LESS THAT 2 YEARS OLD. KENNMORE SIDE BY SIDE SEARS MODEL 106.56579400, THE RREPAIR MAN SUGGESTED PATCHING ALL 3 CRACKS WHICH ARE 12 INCH ES LONG. NOT ACCEPTABLE!! NOW IA M CALLING ONE SOURCE CORPORATE DEPT, WHICH IS SUGGESTING THE SAME THING AND NO REPLACEMENT BECASE THE FRIG IS FUNCTIONAL. THESE CRACKES WILL CONTINUE TO OCCUR.
  • mantilly Apr 02, 2008
    I had a kenmore that did the same thing. Sears was happy to exchange it but i have to talk to the sales people. I told them it was cosmetics how about i take a baseball bat to his car, that it was just cosmetics. ;-) that it dont hurt the car at all. hehhehehehhe. But what i did was go back up to the store and act like buying one and ask them is a cracked appeared on the inside wall would it be covered, they will say yes ... then tell them to exchange your fridge now... :) best of luck...
The Kenmore units are made by Whirlpool and Kitcheniad. I have a Kitchenaid with the same issue. They want to drill holes in my fridge and cover the cracks with tape.
Posted on Feb 29, 2008
I have the same problem on my 3 year old Kenmore Refrigerator. I cleaned out the refrigerator and noticed the cracks. I don't know how long they've been there. I called the service guy out and he said it's a known problem. He said the plastic wasn't poured right into the mold. He told the only solution is a silicon type caulking or a patch. The patch involved cutting pieces of liner from a sheet and basically glueing them over the cracks. BOTH SOLUTIONS are unacceptable. I am beginning the process of complaining (lot of good it will do). If this is a known defect, SEARS should stand by their product and make it good.
Posted on Dec 27, 2007
  • 291 Answers
I have used hot glue guns before on liners.. On used appliances I was selling.. cracks was already there. where a is it cracking... trying to think of a cause.
Posted on Aug 28, 2007
  • Mike Johnson
    Mike Johnson Sep 17, 2007
    Never heard of one just cracking on its own... Just from too much weight in door shelves or closing on overly pack fridge ect... I would talk with the Ken. customer serv. or repair person that come out and see if this is something they have had problems with in the past... i personaly have not had a problem with this issue
SOURCE:
My problem is with a tyco Shellshocker, One of the plastic plates that holds the legs on has cracked and then broke off, is there anywhere I can get a replacement part or anywhere I can take it to be...
It is a very poor design with even poorer quality plastic. In other words, planned obsalescence. It's tough to tell that to a kid (or accept it myself) so I bought some 2 part epoxy made especially for plastic. It comes in a dual syringe to allow you to mix what you need and cures stiff in 5 minutes (24 hours until hard). Don't get the one that mixes as it dispenses, because you might need to repair in phases. Take it apart to the point where you can see the broken pieces, mix the epoxy and apply liberally around the crack and "feather" up the sides. Make sure you do not get glue on any moving parts or in a place that will prevent reassembly. Mine works great, now.
Aug 30, 2011 | Tyco Radio Control Shell Shocker
We have a French farmhouse which is 170 years old. Broken Mantle.
If your mantle is stone I would suggest drilling 2-3 holes diameter should be relevent to the thickness so as not to split the stone. do this on both sidees of the mantle. Use a branded epoxy such as araldite and bond steel rods into the holes in the stone mantle bridging them together, any fine cracks can be filled with a fire cement and wiped clean.
Hope this helps
PB
Nov 14, 2009 | Crafts & Hobbies
Hairline crack in bottom of Hayward skimmer. Can it be repaired or reinforced without replacement as there is an access issue? Perhaps a thin PVC plate glued over the crack?
There are several brands of two part epoxies out there that work under water for this type of repair. Your local pool store should have something that you can mix and apply to seal the crack.
Oct 11, 2009 | Hayward Liner Pool Skimmer Sp1089 Deluxe...
Leak in formed pond
It worked for one season on mine. As the crack got older it became longer and wider. Mine was due to not sinking the pond all the way into the ground which caused stress from the weight of the water causing it to crack more. The second season I used a water epoxy putty I bought at home depot in the glue dept. It is greenish blue and turns white after mixing and can be used underwater if necessary. I filled the gap and then placed the repair liner like you are showing over the top and sealed the edges with a black waterproof silicone. This also worked for a season. Now the crack is even larger and wider and nothing I am doing this year is holding! I can't seem to find one the same size and shape or I would replace it. My next attempt is going to be a plastic welding kit, but I haven't tried it yet. Good luck.
Jun 05, 2009 | Epdm Lp1, /Pvc Liner & Preformed Pond...
Whirlpool Refrigerator Internal Liner Cracks
If it is a Kitchenaid brand, the liner is covered under full factory warranty for up to 5 years. (See your warranty guide page). I am the Svc Mgr of an Authorized service center and relayed to one of my customers this morning, that if they took photos after the repair was made and call customer service, they will tell you where to send them. If...and they will agree the repair is un-sightly, you get an exchange. I am not sure it will work with the Whirlpool brand even though they are in the same family ** all made by same company, Kitchenaid cost more and comes with a longer warranty.... hope this helps. Florida
Mar 06, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirlpool ED5VHGXML10 Side by Side Door shelves cracked
HI thanks for your question. its the door liner, that's broken, if you can repair with some epoxy puddy, only problem with epoxy puddy , it smells. so the door liner is to be replaced. thanks the appliance doc. please rate my answer. thanks.
Oct 07, 2008 | Whirlpool GS6NBEXR Side by Side...
There are hair line cracks in the side wall panel of the inside lining of the refrigerator that run parallel to one of the shelves. Any thoughts? Kitchen Aid S/S REFRIG. KSRG25FKSS
im thinking you got a cracked refrigerator liner!! heres the problem with that, its strictly a cosmetic issue, in years past kit aid would consider that a non-field repairable issue and change to refrig out for you.now they've come out with a repair, consisting of an epoxy kit that we go out and epoxy the crack(s) for you, although still noticeable far less than a cracked liner. if necessary and enough cracks in wall they have an epoxy liner kit that will cover entire side wall of the refrig, all depends on the affected area. ive done quite a few epoxy repairs, never a complete panel, but the few epoxy repairs ive done the customer seemed satisfied with the result..again strictly cosemtic issue so ifyou leave it alone oyou will be endangering absolutly nothing exept an unsightly crack.
Mar 17, 2008 | Refrigerators
Crack in coffee machine
if is a plastic or similar material you can fix whit epoxi glue. is it in two different tube you only have to mix de glue en the hardener. to get very tough stuf. be sure to well preparing surface by sanding to get more grip on surface.you can make littel hole on each side of de crack to get a better grip for the epoxi.
Jun 30, 2007 | Gaggia Baby Espresso Machine
Refrigerators Logo
905 people viewed this question
Top Refrigerators Experts
Marvin
Marvin
Gil Shultz
