Question about Home
Bathroom tile How do you replace a broken recessed soap dish in the shower
    Problem Solver:
  • 19 Answers
If I need to replace a broken recessed soap dish in the shower then I would definitely contact with a professional as they can fix this problem very easily.
Posted on Jul 18, 2013
5 Suggested Answers
  • 19 Answers
SOURCE: Installing a resin shower soap dish,
liquid nails will do the job but you can also use clear silicone provided both surfaces are dry.
Posted on Feb 03, 2009
  • 123 Answers
SOURCE: cannot find 2 tile soap dish-back wall that measure 4"hx8"wide.
contact Daltile to see if they have a replacement. If they do you will have to have contractor purchase for you as Daltile does not sell to general public
Posted on Jul 31, 2009
  • 246 Answers
SOURCE: Walk-in shower floor problem
They probably use wrong adhesive that is not hard yet and have tenedency under pressure to squeze out between grout lines. Yes they need to address the problem immediately.
Posted on Feb 13, 2010
  • 10 Answers
SOURCE: Slate bathroom tile
First clean floor down to plywood. Then buy mastic, notched trowel and tile spacers from hardware store. Lay out tile in the pattern you want by cutting them with a tile saw you rented. take out dry laid tile and mastic a small area and install til making sure you press the tile into mastic. Insert spacer and install next tile.
Posted on May 16, 2013
HOW DO I CLEAN THE FLOOR AFTER REMOVING THE TILES?
Haze remover, has acid in it so use proper gloves, talk to your local store........Home Depo
Aug 18, 2014 | Daltile Bathroom Accessories Resin Soap...
We had corner soap dishes installed in our newly remodeled shower stall. But the water does not drain off just sits. The soap dish does have a small dip in the outside rim. The contractor says it is...
I have the same problem with my stone corner soap dish. It used to drain ok but recently water just sits on the dish and mold grows. Unless we get a good solution, I plan to drill holes into the dish to let it drain.
Feb 12, 2011 | Daltile Bathroom Accessories Resin Soap...
How install the soap dish
There are a couple of designs, one is surface mount and the other is recessed. Surface mount mounts with silicone (hard to imagine it would last) and the other installed similar to a tile, but using grout. The grout install gets a hole cut in the tiles, goop everything up with grout, and goosh it into the wall, clean same as you would when working with grout.
Both designs need support until the adhesive dries.
Dec 12, 2010 | Daltile Bathroom Accessories Resin Soap...
Caulk coming off in Corian stall shower
If you have the option of not using the shower for a while, I would put a dehumidifier in the shower to **** the mositure out from below. If cost is no object, you can go ahead and pull the base. The key to the caulk is to completely remove the old caulk, clean carefully and use a silicon based caulk. Be sure to let it dry properly (see caulk cure times on tube).
Dec 30, 2009 | Daltile Bathroom Accessories Resin Soap...
Cannot find 2 tile soap dish-back wall that measure 4"hx8"wide.
May 31, 2009 | Daltile Bathroom Accessories Resin Soap...
Feb 02, 2009 | Daltile Bathroom Accessories Resin Soap...
Home Logo
76 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
