Question about Brother MFC-5840CN All-In-One InkJet Printer
Bhl2 maintenance Can`t find a driver for BHL2-Maintenance, which ask my Brother DCP-7055
2 Suggested Answers
  • 191 Answers
SOURCE: PRINTING, COPY PROPER, SCANNIG PROBLEM
u have ti install drivers again after uninstall old drivers from computer.
Posted on Apr 06, 2009
Brother dcp-7055 self diagnostic
Go to the Maintenance Mode by pressing Pressing "Menu, *, 2, 8, 6, 4". If you done it correctly, the printer will beep, lights will flash and the control panel will read Maintenance.
After it Press 9,9 and it will reboot and start its normal reset procedure.
If it still not work, then there may be the problem with fuser or main board. Check both one-by-one. This may solve the problem.
Jan 25, 2015 | Brother Dcp-7055 Laser Print Copy Scan...
Brother DPC- 115C
It sounds like you need to update the head property...that's usually what the maintenance 7X is. These are some complicated instructions. Try to go through them and post back with a detailed description of where you get stuck (sorry, I don't have the graphics except via email) :
[ 2 ] To Update the head property information stored in the EEPROM on the main PCB:
For the MFC210C U.S.A./Canadian models, skip steps (1) through (3) below.
(1) Make sure that the machine's power cord is unplugged from an electrical outlet.
If the machine is connected to a PC, unplug the USB cable.
(2) Switch on the PC.
(3) Plug the machine's power cord into an electrical outlet.
(4) Press the Menu/Set and Black Start (Mono Start) keys. Next press the key four times to
make the machine enter the maintenance mode.
TIP: Models equipped with numerical keypads can enter the maintenance mode in the same
way as conventional models; that is, by pressing the Menu/Set, *, 2, 8, 6 and 4 keys in this
sequence.
(5) Connect the machine to the PC using the USB cable.
(6) On the PC, run the ID/head property setup utility (BrUsbsn.exe) in the folder created. The
following window appears.
(7) On the Model menu, click BH3.
6-9 Confidential
(8) In Port, select the port number assigned to the BHL2-Maintenance Printer.
To confirm the port number, follow the instructions below.
Click Start | Settings | Printers.
The Printers window appears as shown below.
Right-click the BHL2-Maintenance Printer icon.
Click Properties.
6-10 Confidential
The BHL2-Maintenance Printer Properties window appears as shown below.
Click the Ports tab.
The port number assigned to the Brother BHL2-Maitenance Printer, USB010 in this example,
is one that has been selected in Port on the BrUsbSn screen (page 6-8).
(9) In the Head Info. box on the BrUsbSn screen (page 6-8), type 12 digits (e.g., 776601D00009)
out of the 13-digit property code (enclosed with asterisks, e.g., *J776601D00009*) which is
printed on the bar code label attached to the head/carriage unit. Click the OK button.
(10) To check that the entered head property is correct (using Function code 68 in Chapter 8,
Section 8.5.16.):
MFC620CN/425CN/420CN/410CN/215C/210C and FAX2440C
Press the 6 and 8 keys in this order. Then press the 2, 5, 8, 0 keys in this order.
DCP315CN/310CN/120C/115C/117C/110C
Enter 6, 8, 2, 5, 8, and 0 by using the and Set keys.*
(*To enter a numerical code on models having no numerical keypad, press the key several times to
display the numerical code to be entered and then press the Set key. Repeat this operation for each
numerical code.)
The LCD shows the current head property information (12-digit code) stored in the EEPROM
on the main PCB.
(11) Check that the character string entered in step (9) is displayed in "XXXXXXXXXXXX."
If it is OK, press the Stop/Exit key.
If something other than that is displayed in XXXXXXXXXXXX, check the connection
between the PC and machine and go back to step (6).
Nov 03, 2007 | Brother DCP-110C All-In-One InkJet Printer
I have brother DCP 7055 it shows print unable 71 error pls suggest
I have brother DCP 7055 it shows print unable 72 & some time it show 71 error pls suggest
Dec 18, 2012 | Brother Dcp-7055 Laser Print Copy Scan...
MY BROTHER PRINTER DCP-7055 EORRER REPLACE TONER
This came from the Brother HelpDesk, yes they rang me and it worked.
Cover open Press Clear "Replace Drum?" (ignore this and quickly...) Press Start (blank screen, quickly...) Press Up arrows then switch to down arrow to 00 Press OK
Mar 09, 2012 | Office Equipment & Supplies
Brother dcp 7055 printer toner ended error
i haver Brother Laserjet DCP 7055 printer. Once i refilled its toner but now on 2nd time i refilled it the printer is gives an "Toner Ended" error & replace the toner message.... Pls help meto solve it... Thanks lucky bareilly
Jan 10, 2012 | Office Equipment & Supplies
Brother dcp 7055 error-EF
brother dcp 7055 error-EF laser
Nov 22, 2011 | Office Equipment & Supplies
Apr 06, 2009 | Brother MFC 7420 All-In-One Laser Printer
Brother MFC-5840CN All-In-One InkJet Printer Logo
76 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
