Question about Carrier 38BRC048 Air Conditioner
Condensor? No cold air and it looks like an oil leak around the condensor.
    Novelist:
  • 75 Answers
Hi, Sounds like the freon has leaked out of the unit and its time to call a repair company. The leak is probably the source of the oil. A service tech will find the leak, repair it if possible, recharge the unit and you will be cool again. Sounds like there is a lot of oil so the leak may be very obvious. Good luck. There is an ad on this site to find a local repair service company or you may want to ask a neighbor for a reputable company. kstfas
Posted on Aug 28, 2007
Should the condensor coils be warm or cold
The condensor should always be blowing warm air. When warm air comes from the condensor this is the Freon being used to take warm temperatures from inside the refrigerator. If the air coming off the condensor is the same as room temperature it would indicate that the compressor is not running, If you have other questions please let me know, Thanks Sea Breeze
How a Refrigerator Works
Jun 27, 2012 | Amana Refrigerators
Sub zero 642 refrigerator not cooling
Being a sub zero tech and actually fixing that exact model earlier today I would recommend you call a qualified service tech to come take a look. If not, I'll tell you the steps I would take to isolate the problem. 1) check to see if the refrigerator fan, also called the evaporator fan, is running. Just open the door, hold in the switch next to the light switch and listen. You'll hear it easily if it is. 2) If fan is running remove the grate up top, the one you took off to put the condensor fan motor, and see if the right side compressor is running. Don't always go with if its vibrating its running because the freezer compressor or the condensor fan can cause it to happen. Find the high side, or condensor line which is the smaller that comes out of the compressor in the back and runs up front to the condensor, and feel if its hot. Hot = good, cold = bad. Note that all this can be avoided if you have a set of freon guages because that model has access taps already on them. They are wrapped in yellow. If you have guages unscrew the cap and connect the guages. On the outside numbers the needle should be around the 25-30 on the positive side. If its in the green area, the negative, around the 10 you need some freon, and possibly have a micro-leak that needs repairing. If its down in the -20 to -30 area you have a serious leak, more than likely in the evaporator inside the fridge, and you should relay call a tech. Now if the needle jumps way up to 70 or 80 and the compressor is hot, really bad, call tech. and if it does that and is cold, the compressor is just off. Now if your still with me and stuck through this far i'll give you the cliff notes.
If the temp is 55 that mean the fan inside is running, and that more than likely the compressor. Now here are some questions to ask yourself. Are the condensor coils clean? That would raise the temperature. You just changed the condensor fan motor, did you put the blade back on right? If the air flow is blowing across the compressor in the direction of the freezedr compressor, your blowing really hot air from the condensor across the compressor and your temperature will raise badly. Fan draws air across the compressor and through the condensor. Worse case scenario you jacked the control board up inside, which I dont think is the case either. ** check that fan blade **
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Apr 29, 2012 | Sub-Zero 642
The other night my ac unit started making random clicking noise and now it is not blowing cold air, it blows room temperature air. I keep the front vent clean. it is an LG window unit.
how old is it there are capacitors that controll the fan and the compressor and if it goes bad the condensor will not kick on or the condensor could be bad you say its blowing air so rule out the fan side and look at the condensor it could be one of the two remember capacitors are high voltage batteries and shoul be properly drained with a resistor and tested with a meter before removing it doesnt have high amperage but it does contain high voltage great risk of shock please be very carefull working around them and with any electric device un plugg before working on
Jul 31, 2011 | Heating & Cooling
I'm replacing the a/c compressor, the orifice tube and the accumelator dryer. Question 1, is the accumelator dryer and the condensor the same thing? Question 2, is it necessary to use a shop vac?
CONDENSOR IS THE SMALL RADIATOR LOOKING DEVICE WITH COOLING FINS IT IS MOUNTED IN FRONT OF THE RADIATOR. THE ACCUMULATOR LOOKS LIKE A CANISTER OR LOOKS LIKE A CAN.YOU NEED TO ADD 1 ONCE REFRIGERANT OIL TO CONDENSOR AND ACCUMULATOR. YOU NEED AC VACUUM PUMP. NOT SHOP VAC. THE AC VACUUM PUMP COST ABOUT $400.00 YOU CAN BUY CHEAPER ONE FOR $60.00 YOU NEED A AIR COMPRESSOR THAT OPERATE AIR TOOLS WITH.YOU NEED VACUUM PUMP TO REMOVE ALL MOISTURE OUT THE AC SYSTEM BECAUSE MOISTURE WILL FREEZE UP IN THE SYSTEM.
Jun 19, 2011 | 2001 Chevrolet Suburban
2 year old Coleman Mach III tapping and not blowing cold air:
Make sure the condensor fan is blowing through the condensor on the roof. It sounds like the compressor is fighting high head pressures after running a bit.. After so many attepts, or if it suceeds in operating the load trips the circuit breaker.. Make sure the condensor is clean and air is passes through it from the fan. Just for clarifiication the condensor is the coil that gets hot and the evaporator is the coil yat create the cold air. Good Luck, and if you will, let me know how it turns out. Good Luck. Ned
Sep 19, 2009 | Dometic Rooftop RV Air Conditioner
2002 Expedition A/C wont cool. No cool air
check for blockage between the radiator and a/c condensor. if theres no airflow through your condensor then it will not blow cold.
Aug 27, 2009 | 2002 Ford Expedition
Ge tpx21pr side by side refig/freezer Freezer is not cold enough
If your unit is NOT a static condensor, (the type with cooling fins and tubes on the outside of the back of the unit) If the door seals are okay and sealing properly, you might need to service the forced air condensor components located at the rear lower area, usually behind a fiber board cover. Remove the cover and look for dust on the condensor fins and fan blades. If clogged, carefully brush, vacuum, or blow the dust out, opposite the direction of the fans natural air flow direction. (You don't want to lodge the debris further into the condensor fins.)..Be sure to unplug the unit first.
Jul 31, 2009 | Refrigerators
Beverage Air refrigerator not cooling well
Just a warning about r12 systems. There is no more r12 unless you have a recycled. If the shop has r12 or they might be able to use something else on it. But it does sound like a leak in the system.
Might not be worth a sealed system repair.
Jul 29, 2009 | Refrigerators
97 Grand Cherokee Ltd. air conditioner does not stay cold.
there is a new product out called red angel ac stop leak and conditioner, it is amazing , you can get it at advanced auto
Jul 01, 2009 | 1997 Jeep Grand Cherokee
Carrier 38BRC048 Air Conditioner Logo
106 people viewed this question
Top Carrier Heating & Cooling Experts
Donni Steen
Bill Long
Dennis Boxerman
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
