Braemar heater fault code 07 - Heating & Cooling
2 Suggested Answers
  • 3230 Answers
SOURCE: Hotpoint WT960 Fault F-07 heater relay
A few reasons for this, faulty heater, broken wire, faulty pressure switch or faulty main control board (the heater relay is on the main control board).
There is no reset for this.
Unplug the appliance and take the rear cover off.
Check the wiring to the heater and thermostat. Give the wires a good tug as they can break internally and look ok.
If you have a multimeter, test the heater, it should read around 25 ohms.
Take the top off the appliance, locate the pressure switch (has a thin tube on it), give it a few good taps with your screwdriver handle.
Finally, take the main control board out (bottom left when viewed from the rear) and one plug at a time, take them off, clean and tighten them, plug them back on.
If everything checks out ok, then it's likely the main control board is at fault.
Good Luck!!
Thanks
Posted on Oct 01, 2009
Braemar heater
IS AIR INTAKE BLOCKED BY WALLS, FURNITURE, OR DUST AND DEBRIS?
Jul 21, 2013 | Heating & Cooling
Braemar spectrolink reset error 05
I had the fault code 05 (spectrolink controller) recently on a Braemer TG420 ducted heater. The heater would start and cut out on high temp as the room fan was not starting. I checked under the house and found the cable fitted to the return air thermistor had been chewed. I repaired the section of cabling and restarted the unit and it worked fine. Fault Code 05 is to do with the Thermistor in the return air duct.
Mar 27, 2012 | Heating & Cooling
Braemar spectrolink comfort controller keeps on asking to be reset works ok for a while then goes to reset
Look for the error code on the right hand side of the display above the zone section and below the actual temp displayed.... refer to:
http://www.braemar.com.au/PDFDocuments/Section8_ServiceTroubleshoot.pdf
Jul 21, 2010 | Honeywell Programmable Thermostat Heater
Braemar ducted heating wont switch on
If a used unit check under lid for a pressure hose no thicker than a pen , black or clear, look for splits or if disconnected reconnect
Jul 12, 2009 | Heating & Cooling
Hotpoint WD860 - Fault Code F-07
F07 indicates heater relay stuck.
You need to check the heater to see if it is faulty, and fit new one if it is.
Please rate my solution.
Thanks.
Jul 10, 2009 | Hotpoint Ultima WF860 Front Load Washer
Fault codes
Fault F07 indicates the heater relay is stuck, this could be due to a faulty heater, you need to test it to be sure, if heater o/k, then main pcb could be faulty.
Please rate my suggested solution.
Thanks.
Feb 19, 2009 | Washing Machines
Hotpoint fault f-07
F07 means that the heater relay is stuck, you need to test the heater and replace if req'd.
If heater o/k then you still have a problem with the heater circuit somewhere.
Maybe a control assy
Plz rate this solution.
Thanks, and a merry xmas.
Dec 20, 2008 | Washing Machines
Heating & Cooling Logo
95 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
