I can't print documents as portrait and it keeps printing in 2 pg in one paper landscape!
SOURCE: Won't print in landscape mode
at the adobe print preview screen, does the preview agree with your desired print? if yes, then is "choose paper source by pdf page size" checked on? and is "Auto-rotate and center" checked on?
SOURCE: HP Color laserjet 4700 is printing in landscape
check paper settings in paper handling to set
at plain paper/ letter. or reset factory defaults.
check paper size on tray if app, set to standard or
letter ,not custom
do cold reset . must reinstall network info afterwards.
SOURCE: my sp 35 printer prints the card in portrait
Maybe you need change page orientation direct on the software that you use for print and design your cards.
SOURCE: HP C7180 printer prints 1 p. LANDSCAPE, next p. PORTRAIT, etc.
I had the same problem. I uninstalled the printer on the offending computer, rebooted, reinstalled and it ironed itself out.
SOURCE: Tally 6212 - Landscape Documents Printed Vertically
You do indeed have problem-- the printer is doing what you are telling it to do changing the print from Portrait to Landscape on a dot matrix printer has the same effect as that on a Laser printer, it rotates the print by 90 degrees.
The correct solution of to define a custom size of paper which is the same size as the paper you are printing on.
If you are using Windows 2000, XP, 2003 etc you can create a Custom Size paper in the following way;
One you have created the custom size form you should be able to select this by name in the printer driver properties and the software package you are using.
