Question about Compaq Presario 1681 PC Notebook
I am having a problem with a Compaq Presario 1681 i was given. It refuses to boot saying that there is a disk in when there isent. I have already attempted to adjust the boot order and that has not fixed it. I know the cdrom drive works as this model has a built in cd player that works seperate from the computer itself.
    Brigadier General:
  • 6,966 Answers
If I may add to jmorgan, there is a possibility that the laptop no longer recognizes the hard disk.
Posted on Aug 28, 2007
    President:
  • 317 Answers
Put your windows installation cd in the drive, then reboot. Press any key to boot from cd. Then select R to enter recovery console. Follow the prompts. Once in the recovery console, you should have a C:\ prompt. When there type "fixmbr" without the quotes. Once that finishes type "fixboot" and then let that finish, you'll probably have to type a "y" for yes stating that you want to do these options. Then finally type "chkdsk". This should solve your problem, if not let me know, you'll probably need to do a repair install.
SOURCE:
No bootable device - insert boot disk.
press F8 continuously after you turn on the laptop, then you will see a bios screen. Look if hard disk is detected in bios
May 20, 2012 | Compaq Presario CQ60-220US PC Laptop
My compaq presario c700 will not boot and it's saying that there is no bootable device, insert boot disk and press any key, however, i do not have a boot disk
Your Compaq did not detect the hard disk, that is why it is asking for a bootable device such as a boot floppy disk.
Check the BIOS configuration to see if the hard disk is detected, if not then re-seat the hard drive and boot up the Compaq again.
If it still does not boot up, then the hard disk is probably faulty.
To get the Compaq operating again, replace the faulty, install Windows operating system on the new hard drive, plus the Compaq's device drivers and your programs.
Jan 09, 2011 | Computers & Internet
My compaq doesn't boot-up on startup. it'll go thru the compaq screen then it boots to windows 98 screen. after this screen it pops up with "Compaq Computer Corporation" at top of screen, on the bottom...
If this machine has a recovery partition you can restore it to it's original condition. If it does not, then you will have to install windows again from the installation disks. If it came with no disks then you'll have to purchase the disks. Before you do that see if this computer will run xp by looking to see that it meets the system requirements for that. Good luck.
Aug 26, 2010 | Compaq Presario 7478 PC Desktop
My Inbuilt Camera isent detected.
Go to Compaq and download the inbuilt camera driver.
Feb 03, 2010 | Compaq Presario Notebook
Still wont boot
Disk boot failure is usually a sign that your operating system has become corrupt in some way.
If you've got your Windows disc, put that in the CD rom, then boot the computer.
There's a "repair" option that you can select, instead of re-installed Windows.
That *should* fix the problem.
It's also (thought unlikely) possible that your hard drive has died completely.
Mar 19, 2009 | HP Compaq Presario SR1303wm PC Desktop
Compaq logo
It appears that the hard disk drive is not being seen in the Bios. Ensure that both the power and data cables are connected to the drive and the controller. try booting again.
Jan 24, 2009 | Compaq Presario 5000 PC Desktop
Where is the hard drive on presario 1681
Most model Compaq have the hard drive mounted behind a plactic panel on the RH edge or LH edge of the laptop. There is a screw that locks the panel in place. After you remove this screw then slide the panel down to unlock it and then pull the hard drive out.
Jan 22, 2009 | Compaq Presario 1681 PC Notebook
Error message
What was your coworker doing on it? I would say you need to at least do a disk check. You can do this through windows repair console or in Vista you can boot to the disk and have it check boot up problems. Very easy.
Dec 05, 2008 | Compaq Presario Notebook
Open Questions:
See all Compaq Presario 1681 PC Notebook Questions
Compaq Presario 1681 PC Notebook Logo
112 people viewed this question
Top Compaq Computers & Internet Experts
Ekse
Thomas F. Schneider
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
