Question about Panasonic Toughpad JT-B1 7.0 Inch Android tablet
Factory reset panasonic jt-b1
How to perform a factory reset, without logging onto the device, I'm locked out.
    New Friend:
Hold down all 3 buttons (a1,a2,a3) and power. Release power on buzz and keep 3 "a" keys pressed until reset options appear. use A2 and 3 to navigate
Posted on Jan 07, 2014
Acer Iconia One 10 B3-A30 camera is not working. Sometimes it gets flipped while using it. How do i replace the camera?
  1. Begin by switching on the device by pressing the Power button.
  2. In the next step hold down the Volume Up key for a while.
  3. While still holding the Volume Up button, press and hold the Power key for 3 seconds then release it. Continue holding the Volume Up button.
  4. Once the tablet screen turns on, stop holding the buttons
  5. From the menu choose "Wipe Data/Factory Reset" by using Volume buttons to scroll and Power button to select options.
  6. Tap "yes" to confirm the operation if you are certain you want to clear all your data.
  7. Use the Power button to accept option "reboot system now".
  8. Well done! The hard reset has just been performed.
Second method:
  1. At first, turn off the device by pressing the Power button for a short while.
  2. Afterwards go the Menu, then find and select Settings.
  3. Next chooseBackup & Reset and tap Factory data reset.
  4. Choose Reset device and select Erase everything to confirm the whole operation.
  5. Well done! You have just performed a hard reset operation!
Tutorial Reset Tablet Acer a1-810
Acer Iconia B1 - Password, Screen Lock Remove, Hard Reset
If this was useful, please share to help others and follow us on Facebook, Twitter and Google+
WARNING !
Hard Reset will erase all of your data
All described operations you are doing at your own risk.
Oct 10, 2017 | Acer Computers & Internet
I forgot the password to my Kurio interactive. How do I reset it?
Password Was Forgotten ΒΆ If you forget your Kurio log-in password, you will not be able to get past the lock screen. The only solution is to perform a factory reset. Performing a factory reset will erase everything on the Kurio and return it to exactly how it was when you took it out of the box. To perform a factory reset, unplug the Kurio and turn it off by holding the power button for 5 seconds until the screen displays "Power Off, Shutting Down..." Once the device is off, press and hold the volume down button and power button at the same time until the screen lights up with "KD Interactive." Release the power button, but continue to hold the volume down button until the "DROIDBOOT" screen appears. Then, navigate to the "RECOVERY" option and select it by pressing the power button. This will prompt a new menu, from here select "Wipe Data / Factory Reset." Your Kurio will go through a long restart phase and then welcome you to your new Kurio
Jan 13, 2017 | Tablets & eReaders
STARTING UP PROBLEM WITH MY SAMSUNG GT19100
Hi Adil,
Do you happen to know when this issue started? Usually restarting or shutting down phone resolve the issue. If not you may want to do reset ( soft or hard ).
When a Samsung cell phone becomes unresponsive or when the device slows to a crawl, a reset may be in order. There are two primary methods used to reset the phone. Users should always start with the soft reset when the phone locks up or programs slow down due to memory or software response issues. A soft reset is akin to a reboot of the machine and usually solves most problems without any loss of user data. A hard, or master, reset is required when the phone completely locks up and becomes unresponsive to any cellular signals. This second and more drastic reset deletes all personal data, preferences and settings so that the device is restored to the original factory configuration.
Perform a Soft Reset
Step 1 Press and hold the power button for 10 to 20 seconds.
Step 2 Release the power button and tap the "Power Off" option under the "Device Options" menu that appears. Tap "OK" to initiate the shutdown.
Step 3 Press the power button again to restart the device.
Perform a Hard (Master) Reset
Step 1 Tap the "Menu" key from the home screen and then tap "Settings."
Step 2 Go to "Privacy" and tap "Factory Data Reset" to review the Factory Data Reset information.
Step 3 Review the Factory Reset options. Place a check next to "Format USB Storage" to clear your device of user data, such as music, pictures and other account settings.
Step 4 Review the disclaimer and verify your changes before tapping "Reset phone."
Step 5 Tap the "Erase Everything" or "Yes" buttons to confirm the reset the phone to factory settings. The device initiates the restoration process to the original factory configuration.
Perform an Alternative Soft Reset
Step 1 Power off the phone. If the phone does not turn off, remove the back cover of the phone and take out the battery. Wait between 10 and 30 seconds and then replace both the battery and the cover to restart the device.
Step 2 Simultaneously hold down the power/lock keys.
Step 3 Release the keys when the Android screen appears.
Apr 29, 2014 | Samsung Cell Phones
SAMSUNG GT19100 STARTING UP PROBLEM
Hi Adil,
Apr 29, 2014 | Cell Phones
My Samsung intercept won't load past the flashing Samsung so I was trying to factory hard reset it and it won't even do that I attached a photo of what it says
Hi Latonya,
Apr 28, 2014 | Cell Phones
How to reset my phone password easily?
Hi Ronquillo,
Apr 28, 2014 | Samsung Galaxy Y Gt-s5360 Pink Factory...
Versus touchpad factory reset
A factory reset will erase everything.
If you want to operate without a password, expect all data and software to be stolen or tampered with. Good luck.
Dec 20, 2017 | Tablets & eReaders
Panasonic PV-DR2714 will not turn on and i lost the remote
Hello Bobby
You haven't given enough details about the fault to your Combo. What do you mean my 'power button has coninuity on board'. I assumes that you get power LED at the front of your device lights up when you switch ON the main power switch, and the unit refuses to power ON and work further. If so, just make a factory reset to this set as it will reset the memory IC. To reset the unit to its factory reset do the folloing. But to do this, the power LED on the front panel of the unit should light up. Otherwise, the fault will be to its power regulator section. To reset the unit to factory reset:
[1] Turn the Power ON.
[2] Hold down both PLAY/REPET and FF on the unit more than 5 seconds. The power will shut OFF. Please ignore "NO CASETTE" warning.
[3] Perform initial set up refering to its user manual. You can see instructions to initial setup at page [16] of the user manual to your device. OK.
Dec 07, 2011 | Panasonic PV-DR2714 27 in. TV/VCR/DVR...
If I found a garmin nuvi gps it got a locked on it how can I reset it or something
Most GPS navigation devices from Garmin has a reset function which allows user to access a Maintenance Mode screen with system information, diagnostic details or perform the reset function to restore Garmin Nuvi or other series unit to its original default factory settings.
Depending on which model of Garmin GPS unit you're using, the following routine can reset the Garmin device to original factory loaded settings, or bring up the Maintenance Mode with access to System Information and View Diagnostics screen, where users can see various logs, and of course, clear all user data (reset to factory defaults) or clear Waypoints.
In order to reset Garmin device or enter into maintenance mode, perform one of the following procedures:
Power off Garmin unit. Press on continuously the upper top left corner of screen and then power on the unit by pressing once on the Power button. You should be prompted to clear all user data, or asked if do you really want to start up in maintenance mode. Press "Yes" to reset (warning: all data will be erased and lost, so backup before proceeding) or enter maintenance mode.
Hack above works on Garmin Nuvi 660, 680 series.
Turn off Garmin device. Press down on bottom right corner of the touchscreen, and then power on the GPS unit. You should be prompted whether do you really want to erase all user data, or asked if do you really want to start up in maintenance mode. Press "Yes" to reset (warning: all data will be erased and lost, so backup before proceeding) or enter maintenance mode.
Trick above works on Garmin nuvi 200, 250, 360 750, 760 series unit. In fact, there is a video demo by user of Garmin Nuvi 360 on how to perform the hidden reset function.
Hope helps. (remember to rate and comment this answer).
May 19, 2011 | Garmin nuvi 255W GPS Receiver
Panasonic Toughpad JT-B1 7.0 Inch Android tablet Logo
371 people viewed this question
Top Panasonic Cell Phones Experts
Rommel Balcita
Nagendra Baliga
Andrew Taylor
Andrew Taylor
Are you a Panasonic Cell Phone Expert? Answer questions, earn points and help others
