Question about PSC QS6000 Plus Handheld
QS6000 Plus barcode scanner
Changed cable from PS2 to USB. How do you convert it to recognize USB. Do I need software?
  • 1 more comment
  • Anonymous Apr 01, 2008
    scanner is not working when connected to USB on the laptop
    how do you get notebook mode
  • silvermark Apr 25, 2009
    I've just buy ps2 to usb cable use for qs6000 pkus, but it unknown driver, I dont' scanner into notebook. Do you have driver qs6000?
  • 53 Answers
You can not change a qs6000 from ps2 to usb by just changing the cable. the interface inside the unit needs to support usb, to check this look at label with the serial number and if it says "I/F=KBW/RS" your our of luck, and can only use ps2 or rs232. if it says "I/F=UW" then you can just scan 3 barcode from the manual to set the interface to usb
Posted on Nov 08, 2007
  • Robert sturzbecher Dec 07, 2007
    you could also spend $5 on getting a USB PS2 adapter, you will just have to set the scanner into notebook mode if there is no keyboard connected to it.
Drivers for ms5145
A standard PS2 to USB cable will not work with these scanners. You'll need to purchase cable # M009-3MA7C. They are expensive, so shop around for price.
Jun 06, 2012 | Metrologic Instruments Eclipse MS 5145...
QuickScan 6000 Plus cant get it to work with windows 7. If i use ps2 port, the red scanninglight dissapears after one scan. If I use an converter ps2 --> usb and plug it in usb port, it seems to work...
try the other usb ports. sometimes that works. also make sure that your other usb devices are off if possible. If you are using a usb keyboard try using a ps/2 keyboard. If you have an open usb port in the front try using that instead. I have seen this many times. Good luck.
Sep 22, 2011 | Datalogic QuickScan QS6000 Plus Bar Code...
Ive got a second hand psc qs6000 plus barcode scanner. where do download its driver.
If you are looking to program your scanner:
USB Interface
Keyboard Interface
If you are using the USB interface, make sure you are plugging the scanner either directly into the computer, or if you are using a USB hub, it is a powered hub.
I hope this helps.
Aug 20, 2009 | PSC QS6000 Plus Handheld
Windows XP does not recognize the Handheld scanner.
My guess is that the USB hub needs to be plugged in ... if for some reason the usb hub doesn't allow you to plug it in then you need to get one that you can plug in... because I believe the scanner is using more power that the usb port can power. Scanner usually need to be plugged directly into the computer or they need to be plugged into a powered hub.
I hope this helps!!!
cdixon18
The Man Inside the Machine
May 11, 2009 | PSC QS6000 Plus Handheld
QS6000 Plus with USB programing question
The document below programs the QS6500 Plus Scanner
R44-2805A Rev C
Available from
http://www.scanning.datalogic.com/sitefiles/manuals.aspx
Jan 27, 2009 | PSC QS6000 Plus Handheld
Cannot get the datalogic qs6000 to scan 39 or 128 barcode
Sounds like you need an updated driver for your POS scanner.
Other than that, try checking the scanners setting your software and make sure it is set for 39 and 128 bar codes. There is usually a setting that will specify what codes the scanner is going to read.
You can always shoot an email over to the datalogic guys and see if they have any more input on the situation.
Jan 22, 2009 | Datalogic QuickScan QS6000 Plus Bar Code...
PSC 6000 Plus not scanning
There are a few questions:
What kind of cable do you use?
USB, SERIAL, PS2
What kind of computer?
Normal computer or Laptop?
Then...
When you recieve the scanner like new you always have to program it.
First you do
Reset to factory defaults.... Never do this with working scanners
then
you have to program it.
First the Connection type
and then if needed a computer type.
After that you usually have to scan a suffix.
This means when you scan a barcode it needs to do something after.
normally it doesn't give Enter after you scan.
That is what the suffix is for.
and then you scan additional symbologies to scan
Like Code 39, UPC A etc. etc.
It needs to be programmed with the manual you recieved.
if you don't have it you can download here.
go down in the list to quickscan 6000
and programming manual.
please don't print all the pages. only what you need.
If you need more help i will hear it.
good luck.
Jan 09, 2009 | Datalogic QuickScan® QS6000 Plus...
Programming a USB PSC QS6000 Plus
Everything you need is came from your system mechanism. The only way to control your requirements is came from your programm coding.
at the start of the string sending must be filtered and rearrange from your program mechanism.
From what system you need to used barcode scanner? Are you using POS?
Hope you like my solution please rate me Solved.
best regards,
Philip
Nov 04, 2007 | PSC QS6000 Plus Handheld
IBM Powerd USB not working
Are you using a USB 2.0 port?
Try a different USB cable.
PSC QS6000 Plus FAQ
Nov 28, 2006 | PSC QS6000
PSC QS6000 Plus Handheld Logo
1,708 people viewed this question
Top PSC Computers & Internet Experts
Jax Planet
Jax Planet
Sardar Yasir
Sardar Yasir
Level 1 Expert
Tom Chichester
Are you a PSC Computer and Internet Expert? Answer questions, earn points and help others
