Question about Maytag Washing Machines
Maytag Bravos-Water overflowing from bleach dispenser
When my machine goes to the rinse cycle, water rushes into the bleach dispenser & then overflows onto the floor.
Bad water valve. Replace it
Posted on Nov 15, 2016
  • 1294 Answers
SOURCE: Leaking water from the Liquid chlorine bleach dispenser
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped.
Posted on Jan 13, 2008
  • 1073 Answers
SOURCE: washer overflows on any water level selection
check the pressure tube from the tub to the water level switch for a hole or crack in the tube, if none found replace the water level switch
Posted on May 27, 2008
danromarris
  • 101 Answers
SOURCE: Water overflowing out of dispensers
Sounds like there is a clog in the bleach dispenser or it is bad and needs to be replaced. First thing to try is cleaning the washer out. Run about a cup of vinegar in the washer. Pour it into the bleach dispenser and the tub and all the other dispensers too. Run it on hot water on a heavy load. This will clean out all of the hoses and if there are any clogs it will fix them. This can be done every month or so to keep it clean. If this doesn't work however it means that the bleach dispenser is bad. It has a timer set to it to open up when it's time, that wire harness that hooks into it is just causing the problem. Hopefully though all it needs is a good cleaning. Let me know if you have any other questions and let me know if this was helpful. Good luck and have a good rest of the weekend.
Posted on Jan 25, 2009
beltronic205
  • 1474 Answers
SOURCE: Fabric Softener Dispenser Overflowing
Sounds like you have a blockage check/ clean remove dispenser to do
Posted on Apr 06, 2010
torres No9
  • 27 Answers
SOURCE: detergent dispenser fills with water
the black pipe behind it is blocked turn of power take off lid and youll see a soft pipe going to the tub give a few squuezes and it should clear
Posted on Jun 25, 2010
Maytag Bravos XL HE Leaks Adjacent to Bleach Dispenser, how do I fix this?
Fill it with water by hand and see what happens. Tape paper towels in the suspected area. Makes it easier to see. Part 2 ans: so the water is over powering the drain...that sucks. You are right, the valve is probably letting too much water out. I don't know if it is adjustable but I do know it'll probably cost a lot for an itty-bitty brass valve. If money is not a problem replace the valve. If you are a DIY'er, I'd try to use some sort of clamp on the hose leading into the dispenser and close it just enough to slow the flow down. Another idea is to open the drain up by cutting away some of the screen if it has one. A better source than me is to go to repairclinic.com and email them. They have a lot more experience than me. I did appliance repair as a side to handyman for 20 years & fixed just about everything for 50. I never had any formal training.
Jun 19, 2015 | Maytag Washing Machines
How do I get the bleach dispenser to drain?
Hello Denise C - There are several things that could cause the bleach to not dispense into the washer. Are you sure the liquid in the dispenser after the wash is bleach? If it is pure bleach, the solenoid that lets the water into the dispenser is not working. This solenoid is located on the back of the dispenser. It only gets voltage during the dispense time and fills the bleach dispenser with water. The bleach dispenser fills while the washer is filling for the rinse cycle.
When the washer begins to fill for the rinse cycle, the bleach solenoid is energized and water flows into the bleach dispenser cup. When the cup is full the water siphons out and bleach and water flow into the tub.
If the liquid in the bleach dispenser is pure bleach you may need a technician to diagnose and repair the problem. The voltage will have to be tested to the bleach solenoid and a volt meter is required.
If the liquid in the bleach dispenser is water you probably need to clean the dispenser cup. Scum will build up in the siphon tube and stop the liquid from going into the washer tub. The incoming water will dilute the bleach and overflow the dispenser cup and run into the tub.
Remove the insert from the bleach and fabric softener compartments. Clean the bottom of the insert and the bleach and fabric softener compartments. Reinstall the insert and put the drawer back inside the washer.
To test the siphon action slowly pour water into the bleach compartment. When the water level goes above the maximum line stop pouring. The water should all drain out. You may also test the fabric softener compartment the same way.
I do hope this information proves to be helpful.
Jan 01, 2013 | Frigidaire Affinity ATF7000E Front Load...
Maytag bravos washer- bleach compartment wont drain during wash cycle
The solenoid that turns on to dispense the bleach is bad, or you have a clogged tube that goes from bleach dispenser to tub.
Apr 29, 2012 | Maytag Bravos MTW6600T Top Load Washer
Fabric Soft and Bleach despenser on MAYTAG TL FAV6800 won't drain
I'll see if I can help. Can you just clarify if by won't drain. Does it look like no water flow is flushing the the Bleach and Fabric Softener dispensers?
The Fabric Softener dispenser could be clogged but I suspect the dispenser’s valves are not opening to flush the dispenser’s. If the Fabric Softener dispenser is clogged you can flush with White Vinegar solution and clean exit port with a pipe cleaner. I do not suspect a clog with the Bleach dispenser.
You could go into Service Mode and turn on the water valves for the dispensers to check if water is sent to the dispensers.
If you have no water flow to the Softener dispenser here is the non technical troubleshooting I would take. Go into Service Mode (page 14 of the Service manual) by Pressing Enviro Plus and Spin Only keys (simultaneously) for three seconds or until the console beeps.
Now go to page 16 to Service Manual and enter Board Output Test by pressing the Delicates key. This will lock the lid. Now press the Wrinkle Control Key Pad on the console. The Control Board will send 120VAC to the bleach dispenser water valve. Did you hear the Solenoid hum? If so and you have no water flow diverted to the Softener dispenser the solenoid valve may be stuck closed. If you did not hear the solenoid valve hum the solenoid field coil may be open. Do the same process for the Bleach dispenser water valve with Bulky Items Key Pad.
Final technical troubleshooting as a technical owner of the machine would be to take my DVM and verify 120VAC from the Control Board to the Bleach/Fabric Softener dispenser valves.
See page 36 lower left hand corner is the Bleach/Softener dispenser valve.
Here is the Service Manual for reference. Sears Parts Direct for reference.
The Part Number for the Dispenser Valve is 25001043 you can order from this site or search the internet for best price.
Good luck…….Rich
Mar 09, 2010 | Maytag Neptune FAV6800AW Top Load Washer
During the rinse and spin cycle, water is sprayed everwhere
There may be too much water and not enough clothes in the washer. If that is the case the water rises up the side of the tub when spinning and overflows the inner tub. Usually it goes into the outer tub but it can spurt out through bleach dispenser and run down the inside of the cabinet or hit the lid and splash out. Set water level (Xsmall, small, medium, large, Xlarge) appropriate for amount of clothes.
Aug 11, 2009 | Washing Machines
Adding bleach to front load washing machine
Put you bleach into the machine whist it is filling using the left part of the drawer.
Jul 03, 2017 | Maytag EPIC MFW9700S Front Load Washer
We have a Maytag front load washer Model MAH 4000 AWW
tHE PROBLEM IS YOU NEED TO CLEAN YOUR SOAP, SOFTENER AND BLEACH DISPENSER, REMOVE THE BLEACH AND SOFTENER DISPENSER TRAY, AND YOU WILL FIND THAT IF YOU HAVE BEEN USING LIQUID SOFTENER, THAT IT HAS GUMMED UP AND CLOG THAT AREA AND IS CAUSING SPILL OVER. WHEN THE WATER IS POURED INTO THE TRAYS TO DISPENSE THE BLEACH AND OR SOFTENER.
Mar 18, 2009 | Maytag Neptune MAH7500A Front Load Washer
Bleach is spilling directly on to clothes
I have the same problem and here is the reason and the solution. When you add bleach it sits in the dispenser until the rinse cycle. During the rinse cycle the machine pours a lot of water through the dispenser. The bleach is diluted and washed out with all this water into the tumbler and you clothes are rinsed with bleach. Sometimes when this rinse happens, the water does not completely drain from the bleach dispense. It sits in there. If this happens, the next time you add bleach, there is too much liquid in the dispenser and it leaks out onto your clothes.
Solution: Before you add bleach, take the whole dispenser out and see if there is a lot of water still standing in the bleach dispenser section. If there is a lot of water, spill it out into a sink. Then fill the dispenser with your bleach and it will all work out the way it should. I was having your same problem until I discovered this. I have never had the problem since.
Let's give a toast to Bright Whites!!
Nov 07, 2007 | Washing Machines
Detergent dispenser
As far as I am aware, there IS NO dispenser for bleach, you have to put bleach in drum before adding clothes and starting cycle. The far right compartment is only for "pre-wash" cycles, and if no pre-wash is selected, water will run through ALL compartments at the rinse stage..... Oshie
Feb 28, 2007 | Bosch Nexxt Premium WFMC6400UC Front Load...
Washing Machines Logo
915 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
