Question about Connectify
Error during connectify driver install - Connectify
I have installed connectify on my windows 7 toshiba laptop. when i start it, the connection work well on my ipad for about 5 minutes and after it s get disconnected. each time i just close the wifi access...
1- I don't know what connectify is or even why you would use it. Your router can or should be able to handle wireless communications in your WiFi network. Once you have your wifi network setup under the router then go into settings on your ipad and point it to the right network and it should connect.
2- On your toshiba it should connect on it's own as well, get the wifi connection setup the go into network connection and point it to your wireless network in the house.
Like i said i don't know why or what this other program is or even for but see no good reason to even use it.
Hope this helps
Feb 21, 2014 | Computers & Internet
How to get Connectify me with my 3G USB dongle
i kan ush docomo photan ec1688 NG 754MODEL wespro laptop
Apr 11, 2013 | Computers & Internet
Can i make a hp officejet 6110 printer wireless
SETTING UP A WIRELESS PRINTER WITHOUT A WIRELESS ROUTER - WINDOWS 7
Install Virtual Router first "Turn any Windows 7 or Windows 2008 R2 Computer into a Wifi Hot Spot."
EditByBSEditor: Virtual Router turns any Windows 7 or Windows 2008 R2 Computer into a Wifi Hot SPOT using Windows 7's Wireless Hosted Network (Virtual Wifi) technology.
The Wireless Network Create/shared with Virtual Router uses WPA2 Encryption, and there is not way to turn off that encryption. This is actually a feature of the Wireless Hosted Network API's built into Windows 7 and 2008 R2 to ensure the best security possible.
You can give your "virtual" wireless network any name you want, and also set the password to anything. Just make sure the password is at least 8 characters. http://www.brothersoft.com/virtual-router-327895.html Then install Connectify-Me Connectify is an easy to use software router for Windows 7 computers. After downloading and installing the lightweight application, Connectify utilizes your computers' built in Wi-Fi card to wirelessly share any available Internet connection: a cable modem, a cellular card, or even another Wi-Fi network. Other Wi-Fi enabled devices including laptops, smart phones, music players, and gaming systems can see and join your Connectify hotspot just like any other Wi-Fi access point and are kept safe and secure by password-protected WPA2 Encryption. http://www.connectify.me/ Then reboot computer
Aug 18, 2012 | HP OfficeJet 6110 All-In-One InkJet...
When I install connectify I lose all internet connectivity, when I uninstall it, I get normal internet connectivity back
This problem is likely being caused by something that Connectify installls called the Connectify Lightweight Filter, which you can find if you right-click on your USB modem connection and select 'properties'. There is a list which says 'Connect using the following items:" and it is in there. Un-check it, and that should work fine, at least it did for me. The bigger question, which I am looking for an answer to, is how to get Connectify to work with my 3G USB dongle, without creating this problem.
Feb 08, 2012 | Connectify
I have got a normal modem(not wireless).but i star installing connectify my internet connection gets disconnected and then when i try to connect am not able to anyone pl give me suggestion what to do
restore your pc at an earlier time by using safemode..press F5 upon boot then choose safe mode..now restore system at an earlier time using system restore..
Jul 18, 2011 | Connectify
I downloaded Connectify to share a Clear mobile connection on my laptop with my pc and Kindle. The PC sees the Connectify network and validates, but no IP address is assigned and so there is no network...
you dont say what windows version you have? have you tried creating a network bridge between the phone connection and your wireless ,as you also dont say how you have the mobile connected either, then enable internet sharing on the computer.
Apr 09, 2011 | Connectify
I get an error message------The wireless device reported an error while starting the hotspot. Please try reconnecting/reenabling your wireless device or reboot and try again. I was able to use connectify...
try to go in Control panel->Network and Sharing Center->Change adapter settings and disable "wireless newtork connection". then try start your hotspot from conectify. this worked for me.
Feb 23, 2011 | Connectify
I have installed Connectify on my Windows 7 laptop. The Connectify network shows up for the ipad and it says it's connected, but no data flows. iPad does not have a working internet connection (using the...
If you want to use the same connection from at&t ..you have to download and install the AT&T communication manager for windows & ..and after that make the connection ..
Here is the link ..
http://www.wireless.att.com/businesscenter/solutions/wireless-laptop/communication-manager/index.jsp
If you have the AT&T on a wireless router ..use the wifi .card to connect to the router ...by ..enabling the wifi ..than click on the card icon ..and scan for networks ....When the router is found by name ...click connect ..and thats all..
Dec 26, 2010 | Computers & Internet
Computers & Internet Logo
594 people viewed this question
Top Connectify Computers & Internet Experts
David Payne
David Payne
Are you a Connectify Computer and Internet Expert? Answer questions, earn points and help others
