Question about Toshiba SD-5000
WHEN DVD IS PLACED IN MACHINE IT KEEPS TRYING TO LOAD BUT NO PLAY
IT KEEPS TRYING TO LOAD DVD AND LOADING MESSAGE APPEARS AND THEN AFTER 1 MINUTE BAD DISC MESSAGE APPEARS ON ALL DVDS PLACED IN DVD PLAYER.  COULD IT BE A PROBLEM OF DUST ON LENS INSIDE MACHINE?
  • 51 Answers
Yes that is very possible. cleaning the lens of the dvd player should happen atleast once a month. it can also be that the lens itself is scratched or the lase does not reach the disk tracks due to dust or bad handling
Posted on Mar 30, 2009
SOURCE:
When I try to load a DVD-R disk in DVD drive, I get a continuous Load message....
Hi again try another brand TDK R GOOD .cheers Hi a DVD-R IS A RECORDING disc if u have recorded on it . & u r trying to play it in another DVD with out ( FINALIZING ) it .u will get a continuous loading message hope this helps
Feb 01, 2016 | Televison & Video
Panasonic Model No. DMR-ES35V DVD Recorder error message H02
check it out this link, maybe can help you https://www.ifixit.com/Guide/Repairing+a+Panasonic+SA-HT810V+with+the+H02-H07+error/2708
Try to clean reading head from vhs player with isopropilic alcohol, maybe is dirt and give this error.
Good luck !
Dec 03, 2017 | Panasonic Dmr-es35vs DVD Recorder / Vcr...
Machine won't load disc. Keeps saying loading
Either a mechanism problem or a problem with the Optical unit inside (optical pickup) being dirty or bad.
Apr 16, 2012 | Polaroid FDM-0700A 7 in. TV/DVD Combo
"wrong disk" message appears after load time
If this happens on more than one DVD, it might be necessary to clean the lens of the DVD player. Safe commercial products are available at local drug stores for around ten dollars.
The "wrong disk" message is usually associated with Data disks, i.e. those having computer files rather than DVD movie files.
If this is an older DVD player, the DVD may have been written on a high-speed DVD writer which creates smaller data spots which may not be read correctly on older DVD players.
Barring these problems, it is probably just broken. DVD players, although not having as many moving parts as VCRs, do not last indefinitely.
Oct 06, 2009 | Televison & Video
Dvd player refuses to read any disc I load into the machine
Hello I was looking to try and help you with your DVD player, we will start by loading a music cd store purchased, no burned cds please, if the cd loads and plays then your dvd player is either out of adjustment or going bad, most dvd players, i have worked on, will load and play a music cd, but will show loading errors when trying DVD's. If the music cd dosen't load then there could be an issue with the drive or tray. If the music cd plays just fine, then your laser is either out of adjustment or going bad. You can call the manufacuter to see if there is a process for resetting the DVD player, not all DVD players have this option, if resetting the DVD player dosen't work, but music cd's do then your laser lens is dirty or going bad. At this point you have three options 1) Take it to a repair shop, 2) Get an new one, 3) Get your hands dirty if your really handy and know what your doing to clean and replace the laser. I hope I can be of further assitance and I look forward to helping in the future, Thank You and have a nice day.
Jan 14, 2009 | Televison & Video
Getting "Bad Disc" message after Loading message...
If you've had it a long time and used it often, could be the lens is dirty or something wore down and it should be trashed since newer players have more features like usb ports.
Oct 17, 2008 | Astar PD-3060 Portable DVD Player
Sanyo dvw 6000 dvd/vcr player
DVD loading mechanism doesn't load completely that's why opens after attempt of loading.
You need to open top cover of unit and inspect loading belt might be lose, tray timing can be out of phase, some wire got stuck with tray while loading etc.
Oct 02, 2008 | Sanyo DVW-6100 DVD Player/VCR
Dvd hr720
Had a similar problem after loading a suspect dvd (one I had burned myself) Could not do anything - stuck at loading. Don't remember if the fan was running. From what I have read these units are touchy to bad disks (DVD or HDD) If yours has a DVD inserted try this :
  1. Unplug and wait 10 seconds
  2. plug it back in and wait 1 minute. DO NOT PRESS ANY BUTTONS!
  3. With the machine still in the standby state, press eject on the REMOTE. It should eject without trying to read the disk.
Good luck. It worked for me.
Nov 15, 2007 | Samsung DVD-HR720 DVD Recorder
Will play cd's but cant read dvd's - NO DISC appears
Could be that the lazer is faulty.try multizoning unit. switch on unit with NO disc inside. press enter,press 84269 and press enter again. unit will switch off.
Aug 18, 2006 | Samsung HT-DB120 System
Toshiba SD-5000 Logo
554 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
