Question about GE Om75p31 / Samsung Microwave Magnetron Wb27x10516
MAGNETRON OMP75P-31 - GE Om75p31 / Samsung Microwave Magnetron Wb27x10516
Hmv9305/01 microwave @ 13months old the magnetron blew, authorized bosch repairman, replaced using bosch magnetron. warranty for 90 days jan of 2011 same problem, why does this happen? should i ditch...
With all due respect, what are you doing to it?
If you use it with nothing in the cavity, that will kill the magnetron otherwise it will last for years and years.
Very unusual and Bosch is a well respected name.
If there is a probem with the oven, Bosch will replace it so take it up with Bosch.
Apr 01, 2011 | Bosch HMV9305 Microwave Oven
I am also not able to locate the 0M75P(31) magnatron. I found a 0M75S. Is this compatable?
what is your full model number,, disregard any numbers on the part itself as most are not part numbers, and official ge part number would start with a W an example would be wb26x10023... i just made that up ...
to get your part number get the full model number on sticker inside, then u could go to sears.com to thier parts and service section, lokk up model number and get part number for magnetron hope this helps
Feb 06, 2010 | GE JE1540 Microwave Oven
Magnetron is broke eb verything works but no heat
HI. in most cases, this will lead to a failed Heating device(magnetron tube).It would be wise to check the Magnetron cutoff fuse to be sure of its integrity. if the fuse is blown, simply replace it. if the fuse continues to show continuity, replace the magnetron.
(((The fuse is located inside the unit along side the magnetron)))
Aug 08, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Part number question on (XX)
As long as the mounting position is the same, they are the same magnetron.
Be very careful as there are lethal voltages feeding the magnetron that can be stored in the capacitor for a very long time. It is not practical to try and test a magnetron with a multimeter as all you can read is the heater continuity.
A thermostat likewise is difficult to test but a faulty thermostat won't stop the magnetron from working.
No idea where you are so I cannot comment on a supplier.
Jul 04, 2017 | GE JE1540 Microwave Oven
Burned inside of microwave
This is the the stirrer cover, and it provides important protection for the magnetron and must be replaced.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Jan 15, 2009 | GE JEM31 Microwave Oven
Oven shuts off on cook after about 2 seconds
If the digital programmer circuit / controller does not get a feedback signal from the inverter for a period of 3 seconds, the controller will stop the cook cycle.
It may be a loose connection in the wiring between the inverter, magnetron, and/or control board, or maybe one of those components has failed.
Due to the lethal voltages used and produced in inverters, I do
not recommend that an inexperienced person work on these.
You can find an authorized Panasonic servicer here.
Your actual model number is located on a tag around the control panel frame, door or below the cooking cavity.
Jan 12, 2009 | Panasonic NN-T654SF Microwave Oven
GE Profile JE1660GB01 magnetron failure?
It pass the resistance tests and still be bad, and I suspect it is.
I would also suggest that you check the high voltage diode to be sure it's not shorted.
If the filament voltage and high voltage are both present at the magnetron terminals, and not loaded down, but there is no heat, then it's the magnetron.
As a pro with over 20 years of expereince, I have always measured the high votlage, but I will never recommend it to a non-professional. Without the right equipment and procedure, you and your equipment can be "fried". No kidding.
Here are some good links to safety & troubleshooting:
http://www.gallawa.com/microtech/cap_test.html
http://www.gallawa.com/microtech/diode.html
http://www.gallawa.com/microtech/mag_test.html
http://www.gallawa.com/microtech/xformer.html
We're happy to help and we appreciate your thoughtful rating of our answer.
Dec 17, 2007 | GE JE1660 Microwave Oven
GE JVM1650SH01 quits and asks to reset clock
Thanks musicmale -- i was gonna try the cpu board.. U saved me $$$
Just got off the phone with GE about my Jan 2005 model (not covered by the service bulletin above) They wouldn't cover the kit mentioned in the service bulletin (magnetron, stirrer and diode) but they did say the magnetron was under warranty ( even though the oven came with only 1 year warranty and its now 2 years old) They are sending me a new Magnetron for free but just in case I ordered a new Diode for $31 (WB27X1160) i din't order a new "stirrer" cuz mine is fine.
I'll let you all know if this works. in 3-5 business days.
Dan
Sep 22, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
GE Om75p31 / Samsung Microwave Magnetron Wb27x10516 Logo
91 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
