Question about Vornado 280CS Stand (Pedestal) Fan
Motor replacement I need a replacement fan motor for a tornado Model 280 CS. Where can I buy one?
Marvin Model 1220. I have several of these fans and each one has issues with fan blades either not turning or slowing down and eventually stopping. I took one of the fans apart and found that the bearings...
I own a Marvin model 1220 box fan since 10 years ago. The stand broke on the hooks part. I need the buy the same, please help me on this. It is out of stock in the Internet. This fan is fantastic, but need to keep it clean so the blades don't slow down do to dust
Aug 12, 2011 | Marvin 1210 Floor / Box Fan
I have only high speed on my ac/heat switch. have replace acdelco blower motor resistor 2 times already. works for a while and quits. whatelse do I need to check etc?.
If you have replaced the blower motor resistor block twice all ready, i would be replacing the blower motor itself. When the blower motor is drawing too much current it burns out resistors for lower fan speeds in resistor block, but doesnt blow fuse for fan. Also check for leaves and stuff in fan when removing fan.
Jul 18, 2011 | 2006 Isuzu i-280
I purchased a ceiling fan fifteen years ago and the motor is going out. I'm not sure what the serial number is, but I found CS-5201. Is this your fan and can I buy a replacement motor.
The motor is pretty much the entire fan and I have taken apart many of them but I do not see any fees able way that you would be able to get it back together if you could get a motor. I would make sure that the problem is not just the speed capacitor or the speed control switch, witch are fairly simple to replace.
May 30, 2011 | Hampton Bay 13087 70450 Carousel II...
Ac fan motor doesnt work on low speeds only on
I will assume the heater fan also doesn't work on low. You will need to replace the fan speed selector switch
Jul 26, 2010 | 2006 Isuzu i-280
How to oil a broan bathroom fan motor
The fan motor is pre-oiled and sealed so it can not be oiled if fan motor is squeeling then motor replacement is the only option. You can get replacement motors which is usually cheaper than buying a whole new fan. Will need to know the model # of broan fan. I hope this information was helpful. Please rate the information given. Good Luck and have a great day. Jeff
Apr 02, 2010 | Home
My turbochef tornado gives an error messag of
this is simple to fix but usually costly sorry to say.
F1 blower means the motor is not running when commanded.
first check the motor and verify if it spins freely - if the motor does not spin freeely remove the obstruction or replace the blower part# NGC-1025
just to clarify its the big blower behind the cook chamber not the little fan in the electrical compartment.
Dec 30, 2009 | TurboChef TORNADO Electric Oven
Motor burned out of fan/lighting unit. Old model
dominion electric might have it if you really have to have that fan but best to get new one same work you got to bring it downand work on it ...less work buy new one less head ache ....
Oct 03, 2009 | Hampton Bay 24750 Huntington III Ceiling...
The motor may have blown on the fan
Hello
Well I'm sorry to hear about your misfortune. Sometimes case fans do just give out after so long. There is little to nothing that can be done about it. No one repairs case fans your better off just buying a new one.
Post back if you need any further assistance and I will get back to you. Thank you for choosing Fixya!
Aug 15, 2009 | Vantec Tornado Case Fan Case Cooling Fan
Motor burned out. Where can I find replacement
if you can identify what type and model electric motor your fan is using, visit Grainger or Harbor Freight then ask them if they can query and match your fan's electric motor model with a replacement.
Mar 24, 2009 | Heritage Dryers
Vornado 280CS Stand (Pedestal) Fan Logo
44 people viewed this question
Top Vornado Dryers Experts
Steve
Ian Summerfield
Ian Summerfield
Mack Baxter
Are you a Vornado Dryer Expert? Answer questions, earn points and help others
