Question about Sewing Machines
CHANGE MOTOR FROM 380V TO 220V MODEL OF MOTOR JMNS432 FOR SEWING MACHINE
IT IS A ELECTRONIC MOTOR CHANGED FROM 380V TO 220V DO I JUST CAP IT THE MODEL JUKI JMNS-432
SewTechWayne
  • 186 Answers
SOURCE: Juki MO-2516N motor runs in reverse
This machine as an AC motor which only runs in one direction no matter how the leads are attached.
Why do you need to reverse the motor direction?
Posted on Feb 01, 2009
SOURCE: Manual for Kenmore sewing machine, model 385.12812690
So far I've only been able to find this page. It's $8.00 to download. Considerably cheaper than a new machine!
http://www.sewconsult.com/kenmore_instruction_manual_385_oce_type1.htm
Hope it helps.
Posted on Apr 02, 2009
Zenqi
  • 208 Answers
SOURCE: Juki Sewing machine DDL-555. After 4-5 hours use feed not moving
Sounds like as the machine builds up friction from extended use, some vital part is lacking lubrication and is seizing up. A good service person will remove ALL of the covers and thoroughly air clean and oil every moving part. Sometimes these dry points are hard to find and patience is required.
You can get a sewing machine oiler with a long applicator and put a drop of oil on anything that moves, but over oiling can be messy.
Posted on Jun 17, 2009
SOURCE: Juki DDL-5530 Sewing Machine Manual
go to www.juki.com.jp login industrial sewing machine and you can doenload manual for juki machine
Posted on Aug 20, 2009
madelinesalo
  • 59 Answers
SOURCE: Juki sweing machine timing problem
the timing of your sewing machine is, check your bobbin in right position, quit tightin the tension, and the timing for tiches is just always # 1.5
Posted on Mar 26, 2010
I purchased a juki hzl-T600 used, I need foot control and owners manual can you help me
you can probably get a user manual by going google and typing in -- user manual for juki model hzi-t600 sewing machine--- and downloading any pdf versions
as for the foot control, most are either resistance controllers or electronic controllers so talk with a service dealer or a sewing machine repair shop ti get the pedal control or to find out where you can get one . the problem will be the plug fitting for the pedal control into the machine or motor
Dec 20, 2016 | Juki Sewing Machines
Why is my juki machine 8700 not moving at 3000 speed
There are several manuals available, depending on detail and complexity:
JUKI DDL 8700 Manuals
Oct 16, 2014 | Juki Sewing Machines
Error 924
hi there
regarding Error E924 at JUKI control it means Motor driver failure ( Motor driver has broken.) or you can first check motor connection if connected secure or there's lose connection. other ways try to change motor with new one or check control box only with working machine to confirm Error coming from motor or control box.
BEST REGARDS
ASHRAF
CAIRO - EGYPT
aabozid@hotmail.com
Aug 03, 2013 | Juki DDL-8700
Does The Juki 8700 sewing machine have a automatic Thread Triimmer
final answer about this questionhello all
in case of normal machine you need to add many parts to convert from manual to auto thread trimmer ( need electronic motor with control - auto thread trimmer mechanic components - hook - feed dog - etc.... ) it's very difficult to change from normal to auto thread trimmer.
best regards
ashraf abozid
Aug 17, 2012 | Juki DDL-8700
We purchased 7 Juki DDL8700 machines and every one of them is popping up with error codes ranging from: E7, E10, E003, E004, E005, E072 and E303. Please help.
hi there
concern E003-004-005 is same solution: check synchronize r need to clean or replace.
concern E7 : trimmer is jammed or timing cam for thread trimmer need to adjust other ways control need to check by electronic engineer.
concern E072 : check connection between motor and control - check sensor for motor ( inside ) - control need to check by electronic engineer.
concern E303 : check whether there is coincidence between head and model setup ( check function No. 95 and make sure it's dl78.
if you need any help please contact me.
ASHRAF ABOZID
CAIRO - EGYPT
aabozid@hotmail.com
Apr 21, 2011 | Juki DDL-8700
I have an error code on my juki ddl 8700-7 that reads e811
hi there
may i know control model ? any way E811 means :
1- over voltage when voltage higher than guaranteed one is inputted ( please check wheter the applied power voltage is higher than te rated voltag ( plus ) 10% or more.
2 - Check whether 110V/220V changeover switch is improperly set.
3 - if 400 volt is input means POWER P.C.B is broken maybe repair or need to change.
best regards
ashraf abozid
aaboid@hotmail.com
Dec 01, 2010 | Juki DDL-8700
I have Juki ddl5550 model cs-4002-6 that the
It might be your connections inside, Juki is a great mechine I would fix it.
call 303 770 6321
AAAA TEVA
Jul 07, 2010 | Juki MO-644D Mechanical Sewing Machine
Feb 01, 2009 | Juki MO-655 Mechanical Sewing Machine
Sewing Machines Logo
93 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
