Question about Canon DC40 DVD Camcorder
Lense cover won't open
Consulted all Menu and Function options without success.
  • hayshake Mar 27, 2008
    I have purchased 2 canon camcorders, 1 for myself and 1 for my son. Both have developed this problem where no picture is visible when turned on, which could be the lends cover not opening.
  • mamawpam Mar 05, 2009
    Canon DC40 lens cover will not open. Worked fine yesterday.
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 206 Answers
Dirt or grain of sand in the small gear box that drives closing and opening of lens cover. Remove front assy. and if you are brave dismantle gear box to clean out. Otherwise just blow without dismanling the gear box.
Posted on Aug 28, 2007
On our panasonic DMC - SZ6, the lense cover won't open when turned on
Lens covers are delicate things. A bit of dust or dirt inside and the the springs can't do their job. When cleaning doesn't work, to repair this I remove the lens cover and shorten the springs by cutting off a bit and then reattaching them. A small bit of mollyd to lubricate helps too. never use oil or silicone.
Oct 31, 2017 | Panasonic Lumix DMC-TZ3 Digital Camera
DCS T70 LCD does work properly .I mean to say if i try to use one function another function gets started instead of desired function
Based on the information you've provided, it seems that the touch screen panel is not aligned. You can try Calibrating the touch screen to resolve the issue.
Calibration option is in the Main Settings 1 Menu of the Camera. Calibration option enables you to perform calibration when the touch panel buttons do not react at the appropriate points where you touch. You can use the paint pen, touch the X mark displayed on the screen. The X mark moves on the screen. Once the calibration option is finished successfully, the touch screen should work.
The Calibration option can be done only if the Menu is accessible.
You can also perform a power reset before performing the Calibration.
Performing a manual power reset
Turn off the camera.
Remove the battery pack.
Press and hold the power button for 30 seconds.
Allow the camera to remain without power for 60 seconds.
Reinsert the battery pack.
Turn on the camera.
This should resolve the issue.
Thanks for using Fixya.
Jan 10, 2011 | Sony DSC-T70 Digital Camera
My panasonic PTLB60NTE shuts down after couple of minutes when I use wireless mode. How can I solve this?
There is three indicators lights on the panel
1. lamp indicator.
2. temperature indicator.
3. computer input indicator.
If your projector shutdown itself without given any indication its mean that your projector function POWER OFF TIMER is on. You can off this function.
How: (two keys back side of projector one is menu second is a joystick witch have 4 arrow keys and center press is enter)
press MENU button to display the menu screen and then use joystick UP or DOWN to select the OPTION menu. press joystick to ENTER and then use joystick UP or DOWN to select POWER OFF TIMER use joystick RIGHT or LEFT to select DISABLE then press MENU two times to exit the menu.
If your projector shutdown itself with given any indication then
If LAMP INDICATOR flashing RED then lamp circuit failure its need to be repair or replace.
If TEMP INDICATOR flashing RED then the temperature inside and /or outside the projector is abnormally high.
CAUSE: The ventilation opening are covered. The room temperature is too high. The projector is located at high elevations (above 1400m)
REMEDY:clean the air filter. Remove the object from the ventilation openings or clear around the projector. Set the HIGHLAND option to ON
Jan 04, 2011 | Panasonic PT-LB60NTE LCD Projector
Reconnecting player directly to different TV
Does your TV have input options in the menu?
Dec 21, 2009 | Pioneer DV-366K DVD Player
Access Probelm with DSC-W50 camera
abrakati,i have the same problem,still unsolved.however,to access the menu i depressed the button to view 'shots' taken.while in that mode i was able to access the menu but resetting did ****.i still get the same malfunction.chris.
May 27, 2009 | Sony Cyber-shot DSC-W35 Digital Camera
No main menu on PS2
Dear Customer,
This might be due to the over usage of the reading lense without cleaning.so i request u to open the console.you would see another cover covering the lense.open tat too.with the help of tissue just try to wipe out the lense n jus turn on the ps2 without closing anythin to jus check whether everythin is workin..if the dvd works,then arrange back or put back everythin back to it's position..hope this would work...else try calling a service engineer.
please rate this solution if it meets ur needs else choose fixya.Thank you...
Dec 16, 2008 | Sony PlayStation 2 (PS2) Console
2006 Honda Accord Dome Light
lok real carefull at the lense there will bee two little slots in the lense between the cover and the trim you can use a pockett screw driver or a butter knife and pry open the lense away from the trim it well be a little stuborn but dont worry you wont crack the lense
Nov 18, 2008 | 2006 Honda Accord
Lense will not extend, or if it does it retracts after a short while. Batteries appear to be OK
After talking, without any success, to your expert I tried experimenting. It seemed like the sliding lens cover was the main reason for it to behave as it did. It turned out that the lens cover had a worn track and did not always operate the lens motor switch to open it, or pressure on the cover caused the lens to retract. All it needs is a new sliding cover.
Jul 18, 2008 | Olympus Cameras
Sony Cyber-Shot (DSC-W50) Access Problem
did you try to reset the camera or call sony?
Aug 31, 2007 | Sony Cyber-shot DSC-W50 Digital Camera
Retractable Lense Does Not Open
This thread might be relevant to your problem: http://www.fixya.com/problems-solutions/t114846,p220455/Olympus-Digital-Cameras.aspx Comment on what you saw in there when you opened it up, compared to the other user. Good luck
Jun 21, 2006 | Olympus Stylus 410 / ? 410 Digital Camera
Canon DC40 DVD Camcorder Logo
144 people viewed this question
Top Canon Video Cameras Experts
Kenneth Walker
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
