Question about Dell Dimension™ B110 PC Desktop
Beeping PC tower beeps all the time how do I make it stop?
sandrew
  • 2961 Answers
SOURCE: At Start up, beeps several times, won't boot.
This could be an overheating processor problem,dependant on the motherboard and what the beeps mean. The fan speeds up to cool it down, there may be dust collected in the heatsink on top of the processor, check it and gently brush off dust. Check that the vents on the side are atleast 6 inches clear of anything for good circulation. To see if it is an overheating thing, remove both sides of pc and run it in an open space to see if the same thing happens. While you have the side off just check your memory and other peripheral cards are all seated correctly and not loose.
Posted on Jan 22, 2007
proton77
  • 1183 Answers
SOURCE: Dell Demision 8200 just beep
Kindly follow the troubleshooting steps on the following steps
http://tinyurl.com/dgb5x5
Chances are that you have a loose memory modules
Thanks
Proton
Posted on Mar 12, 2009
antiochpc
  • 1314 Answers
SOURCE: "my computer will only beep no screen,it beeps
Hi
You likely have a bad memory module. First, try removing all the memory and putting it back in again. This is called reseating. If you still get the errors, then try removing one stick at a time and testing it with each stick (provided, of course, you have more than one stick installed). If you only have one stick installed, remove it and turn on the computer and it should beep at you as well. That memory stick will need to be replaced.
Thanks and please take a moment to rate this solution as fixya. Thank you.
Posted on Mar 14, 2009
  • 58 Answers
SOURCE: "my computer will only beep no screen,it beeps 5,2,2,1 times
Try this:
http://support.dell.com/support/edocs/systems/dim8400/SM/adtshoot.htm#wp1052933
ItsDeadJim
  • 78 Answers
SOURCE: when i turn on mt pc it beeps 9 times and noyhing
What you are hearing is a "post error code".
The codes vary depending on the manufacture.
For instance if you have a Dell 2400 trying searching the web for "Dell 2400 post beeps".
Although I believe 9 beeps is commonly a CMOS error.
If so, you can try clearing the CMOS.
You will have to know how to get to the Computer BIOS screen to set things if you do clear/reset the configuration.
Posted on Jul 20, 2010
The tower turns on but does not boot the monitor
There could be a problem with the connection to your monitor.
Dec 21, 2013 | Gateway ATXSTF MNT Pro S P4 1500 Tower...
Tower is beeping two times what does that mean
If it's not turning on? - Most times its the memory. Open case and reseat DIMMs. Take static precautions!
Oct 12, 2012 | Computers & Internet
ACER Aspire 5100-U5201A Desktop makes a series a beeping sound when I use it. What could be the issue?
It may be bad ram, remove one stick of ram memory and power up the computer, repeat process making sure there is a stick of ram in the machine at all times. If the beeping stops, the one in your hand is bad.
Jul 28, 2012 | Acer Aspire Computers & Internet
Dell studio slim beeps twice and monitor says dvi not found. how can I recover it. Thanks,
What is the exact model of your Dell Studio, A beep code can mean any hardware failure. Post the model of your Studio here and we will post what your beep code means.
Thanks for using Fixya.
Aug 06, 2011 | Dell Studio Slim-Tower Desktop Computer
While booting the tower, it is beeping 5 times (instead of one time) - short break - beeping 2 times. there is no signal towards the screen...
Those are beep codes. Going to need to figure out what kind of motherboard it is, and look it up here: http://www.computerhope.com/beep.htm
The sound of hardware failure is too happy, imo.
Jul 25, 2011 | Fujitsu Siemens SCALEO 600 (FSP:83C005617)...
My computer tower wont stop beeping
Re-seat the memory.. more than likely they have unseated themselves during the dust cleaning. Beeping is usually caused by memory.. Beeps are usually a series like Morris code long..short beeps.. if re-seating the memory doesn't work, try swapping and removing different sticks and differnet locations on the motherboard, most motherboards have 2-4 memory banks or known as dimm slots.
Jan 16, 2010 | Ultra Products Ultra M923 Full Tower ATX...
Tower pushing out air and beeping and can't turn on PC
the beeping is post codes. they are telling you something is wrong. the code is a code for what is wrong like 3 beeps 4 beeps 1 Beep then repeatsthat code is 341. first thing i would do is pull out you ram and reseat it. that is the most common problem.
Jun 23, 2009 | Gateway 838GM (RB838GM) PC Desktop
Computer tower started beeping
If you added more memory this may make your tower beep.
If so I WOULD REMOVE THE ADDED MEMORY AND THEN RESTART
Jan 12, 2009 | HP Pavilion a305w (DM181AR) PC Desktop
Beeping tower annoying
did you check your processor fan? . i had a computer in which th eprocessor fan was jammed and was not working and it was beeping. i fixed the processor fan and the beep was gone
Aug 16, 2008 | Microsoft Windows XP Home Edition
It wont stay on
probably bad memory, 256MB DDR (PC 2100)
Jan 21, 2007 | E-Machines T2642 PC Desktop
Dell Dimension™ B110 PC Desktop Logo
mukhtar21 shaikh
mukhtar21 shaikh
