Lg wf-t868th delay time running non stop
5 Suggested Answers
  • 4 Answers
SOURCE: lg wf-s6607tc
This is probably a lid cover open protection. Check to see if there is a magnet on the cover, positioned almost to centre (slightly to the right) at edge of the cover. There is some sort of plastic catch to house the magnet. If it is not there, place a magnet at the corresponding area on the washer where the plastic catch will touch when the lid cover close.
Posted on Sep 09, 2009
beltronic205
  • 1474 Answers
SOURCE: LG Washing Machine front loading, Model Fuzzy Logic 8.5KG,
If it has a belt remove this then turn drum by hand to see if noise is still present if it is then sounds like some thing caught in between drun inner and outer you may need engineer....Pull plug out 1st...
Posted on Mar 22, 2010
  • 6277 Answers
SOURCE: lg washing machine WF TS
'de' stands for Door Error. There is likely to be a problem with either the door solenoid/lock or the 'door closed' sensor. Both require a service engineer's attention I suggest ;-0(
Good luck,
John C
Posted on Mar 25, 2011
  • 18 Answers
SOURCE: i have a lg fuzzy logic 7.5 kg WF-T755A washing machine that has stopped spinning and also stopped agitating in washing cycle
Call LG's support line, they have excellent customer service.
Posted on Apr 04, 2013
How do I fix my LG WF-T1391TP top loader washing machine, as water does not flush out after a wash cycle, sometimes after a rinse cycle?
sounds like the drain pump could be clogged up might wanna lay it on its backside and take the motor out and inspect it for any buildup inside of its self as this can/will damage the drain pump however if there is nothing there inside the drain pump then the pump needs replacing
Aug 24, 2016 | LG Washing Machines
I have a LG top loader Fuzzy logic 6.5kg model WF-T655th spin cylce not working, the light is flashing. I have a load in the machine, how do I emppty the water out of it. Have misplace the manual.
I have a LG washing machine WTF655TH, it has stopped working, its full of water, but when you push the one button, it trips, how do i get it working again
Jan 16, 2012 | LG Washing Machines
Lg washing machine WF TS 800 after selecting quick wash, machine will delay washing and says DE, washing will then stop.
Good luck,
John C
Mar 25, 2011 | LG Washing Machines
Mar 22, 2010 | Washing Machines
I have a LG Fuzzy Logic washer model WF-T1050TP, AND IT STOPS RUNNING SAYING THE LID IS NOT CLOSED SAYING ERROR d3, BUT THE LID IS CLOSED???
the door switch sounds like it has gone bad, check with a multi meter, they can check it for u at any appliance parts store if u dont have a multi meter
Jul 04, 2009 | LG Washing Machines
LG WF-T753A Top Loader washer hot water inlet valve
Just found this whilst looking for known issues with my machine as the cold water won't stop when filling.
http://safemanuals.com/user-guide-instructions-owner-manual/LG/WF-T753A-_E
Aug 25, 2008 | LG WFT1071TP Top Load Washer
Washing Machines Logo
26 people viewed this question
Top Washing Machines Experts
