Question about Behringer C-3 Professional Microphone
Behringer C3 internal wiring
I have a Behringer C3 on which the 4 internal wires have broken off the XLR plug. The wires are red, orange, brown and black. Which wire goes to which pin?
2 Suggested Answers
SOURCE: Wire Colour coding for Behringer C1 Microphone
had same problem,checked with new mic,
red/black=pin1
orange=pin2
brown=pin3
Posted on Apr 09, 2013
How do I wire up a A.O. Smith 3/4hp PB4 Booster Pump for 230V operation?
Here's some more info diagrams for you http://www.electricmotorwarehouse.com/aosmith/AO_CONNECT.PDF L1 is one hot wire L2 is the other hot wire. L1 can not be connected to a L2 wire and L2 can not be connected to a L1. Ground only to ground.
May 27, 2014 | AO Smith 1.5 hp Swimming Pool - Jet / Well...
I have a Behringer 1202fx and I'm going to use it with a pair of Harbinger APS15. The line inputs on the APS15 are unballanced R&L RCA and XLR. The Behringer 1202fx mains are 1/4" unballanced...
Personally I would run the RCA outputs to the RCA in on the APS.
If you insist on using XLR from the APS to the board (like through a snake etc) I would higly recommend using XLR to 1/4" adapters. These things have wonderful little transformers in them (yes, wire wound transformers) that do the 1/4" to XLR conversion really nicely so that you can run your signal through the snake or just so that you don't get the hum and distortion that can be associated with unbalanced signal transfer.
You want a HI-Z unbalanced to LO-Z balanced adapter.
Not always easy to find, but if you absolutely cannot locate any, I have a couple in stock.
I suggest you look around though, because mine aren't cheap!
Feb 27, 2011 | Behringer Xenyx 2222fx Premium 22 Input...
Wiring an interconnect
Radio Shack sells an XLR to 1/4" jack converter. The you'll need a female double RCA to 1/4" plug in series with it
Apr 19, 2010 | Behringer EUROPOWER EP2500 Amplifier
It is likely that the brown goes to pin 1 (ground/shield phantom -) as well as the black.
Red is likely to go to pin 2 (across from 1)(signal +)
and the orange to pin 3 (signal -)
Apr 15, 2010 | Behringer C-1 Microphone
Wiring a TPH553 Surface Mounted Jack by RCA.
TPH553 T568A T568BPin 1 - BL White/Green White/Orange Pin 2 - OR Green Orange Pin 3 - BK White/Orange White/Green Pin 4 - RD Blue Blue Pin 5 - GR White/Blue White/Blue Pin 6 - YL Orange Green Pin 7 - BR White/Brown White/Brown Pin 8 - WH Brown Brown
REF: wikipedia
Feb 17, 2010 | Computers & Internet
Wires in the microphone at the point where you connect to the lead have come appart and i need to solder them back on, Black, red and white wires. Which in which order do i solder them onto the connecter...
There are many standards of microphone connectivity with 3 pin XLR (cannon) style plugs. It depends on where in the world you are as to the favoured standard,
Your microphone usesthe following::
Pin
1 ground (white) 2 +ve or hot (red) 3 -ve or return (black)
Another way to work out what wires connect to what, is to remove the cover of one of your XLR-XLR microphone cables exposing the connections it favours, plug the connector into the mics scoket , and use the connections to the cable guide you in resoldering the connections back on.
The same connections can be veiwed in the user manual here
Please rate this solution. Cheers
regards robotek
Jul 15, 2009 | Behringer XM1800S Professional Microphone
Wiring on a RCA RJ-45 wall jack
the RJ45 wallplate is not meant for ethernet. It's an 8P8C connector for a phone. Will it work as a network jack? Maybe. I wouldn't use it, but if you really want to try, wire it thusly:
1 Blue --- Orange/White
2 Orange --- Orange
3 Black --- Green/White
4 Red --- Blue
5 Green --- Blue/White
6 Yellow --- Green
7 Brown --- Brown/White
8 White --- Brown
I'd still recommend a CAT5 wallplate with a CAT5 jack.
Apr 11, 2009 | Computers & Internet
I need color codes
Constant 12V+ Black/Yellow
Switched 12V+ Red/White
Ground Black/Light Blue
Illumination Orange
Dimmer Pink
Antenna Trigger Orange/Red
Antenna Right Rear
Front Speakers 4" Doors
Left Front (+) Dark Green
Left Front (-) Brown/Red
Right Front (+) Purple
Right Front (-) Dark Blue/Red
Rear Speakers 6" x 9" Rear Deck
Left Rear (+) Brown/Yellow
Left Rear (-) Brown/Light Blue
Right Rear (+) Dark Blue/White
Right Rear (-) Dark Blue/Orange
Feb 19, 2009 | 1996 Dodge Intrepid
Ethernet cable
568-B Wiring
Pair Wires RJ-45 pins
1-White/Blue White/Blue 5
Blue/White 4
2-Wht./Orange White/Orange 1
Orange White 2
3-White/Green White/Green 3
Green/White 6
4-White/Brown White/Brown 7
Brown/White 8
568-A Wiring
Blue/White 4
2-White/Green White/Green 1
Green/White 2
3-White/Orange White/Orange 3
Orange/White 6
Brown/White 8
RJ-45 Pins are with the spring tab down and read left to right. Do you have an RJ-45 Crimping tool?
Just use 568-B or 568-A on both ends of the same cable.
Jul 05, 2008 | Computers & Internet
Behringer C-3 Professional Microphone Logo
69 people viewed this question
Top Behringer Audio Players & Recorders Experts
 Grubhead
Grubhead
Michial Gueffroy
Alvan Dawkins
Alvan Dawkins
Level 1 Expert
Are you a Behringer Audio Player and Recorder Expert? Answer questions, earn points and help others
