FixYa.com
Tags:
Quantum Apollo 16000 Portable Projector  Multimedia Projector
posted by jumper27 on Aug 28, 2007
My brand new overhead works great for 10 to 12 minutes and then the light goes off. The fan will continue to run and after about 8 minutes the light will come back on...frustrating when you have captivated bunch of middle school students and then the presentation is dead in the water. Any ideas?
Jim
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Aug 28, 2007
Not Rated (0)
Dyllan
Rank:Guru Guru
Rating: 87%, 115 votes
It sounds as though the unit is overheating. That would explain why the fan keeps running, and once it cools down enough it starts up again. What kind of environment are you running this in? Is there a way to put it in a cooler environment? Even having an external fan blowing on the unit could help.
Honestly, unless you've got it in a very hot environment, it also sounds like a poor design for heat dissipation. Or possibly the heat sensor is bad, and shutting it down at a lower temperature than it should.
Was this solution helpful? Show your Appreciation by rating it:
Can you Help with these Multimedia Projectors problems?
SCART Video Control box
Help! My husband disconnected... Answer This...
Screen is turning blue
My screen is turning blue so I... Answer This...
HELP ME!
We just bought a used... Answer This...
HP VP6210 won´t turn on at...
Hi, my HP VP6210 Projector... Answer This...
Sharp Notevision XR-1S...
Hello - sorry to bother you but... Answer This...
Repair Service
Find Multimedia Pro. Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
