Mg5250 paper jam
Paper is backed up between front and back rollers. Error message says turn off and back on. Done that. Nothing happens. Cant access from the back. Cant reach into the front....
  • td1967
    td1967 Jul 16, 2013
    There should be a button on the panal that shows "clean" or a pic like a water drop.press that.
    Master:
  • 966 Answers
If u turn off and on without removing the paper wwill get you back where u were. So go to the problem area again and remove the paper and now turn it on.
Posted on Jul 16, 2013
  • ingridlee
    ingridlee Jul 16, 2013
    I can't access the jammed paper. Any way to purge it out?
    New Friend:
  • 3 Answers
Do auto clean should help paper come lose
  • ingridlee
    How do I run auto clean?
SOURCE: 'paper jam' error on canon pixma ip4300
ring canon support on 0844 369 0100
or try
support.canon-europe.com
they suggested i do a roller cleaning - but i cant find this option ?
Posted on Aug 20, 2008
mickspaceNET
  • 115 Answers
SOURCE: HP LASERJET 4 PAPER JAM 13
Rollers do not turn on!
Rollers are driven by a motor.
How is the printer telling you this information? (does the PC give an error, or the printer flash lights)
Does the paper make it out of the machine?
Is this "Rollers in the Back" the Fuser Unit?
is The Fuser unit is going bad,
if you open the back top cover, where it gets real hot, where the paper exit's, you should see two rollers, one orange, one either brown or black.. if that orange roller is damaged, has crease's, or covered with black toner, if the paper jams here alott, you probably need a new fuser unit. there is a pm kit available which includes the fuser and rollers, transfer, etc, which this site might have
http://www.all-laser.com/cgi-bin/webc.cgi/Menu_HP_maint.html
Posted on Oct 23, 2008
SOURCE: No paper pickup press
a solution was found to this at http://www.devincollier.com/2009/02/14/hp-laserjet-3050-no-paper-pickup-solution/
there is a spring that has become unsprung.
Article has pictures
Posted on Jun 18, 2009
  • 685 Answers
SOURCE: Hp c4380 snarls paper / jams every time
Try this...
Posted on Jul 23, 2009
SOURCE: Brother MFC-9420CN Paper Jam B!!!
open and check for paper in the back. sometimes a corner may have been caught in there and will give you the error.
jb
Posted on Apr 29, 2010
Machine says paper jam and to remove paper No paper in machine Cant clear error codes
Disconnect the power cord from the back of the Canon Inkjet Printer. This is an important step when working inside ANY electronic device.
Unhinge the back access panel of the printer. It seems repetitive to say this, but this door will be in the BACK of the printer.
Look through the opened back panel and look for paper. Remove any and all paper you find jammed there.
Close the back access panel. Make sure that it latches into place and looks the same way that it did before you opened it.
Find the front or top access panel. This is the panel you would lift to change ink cartridges. Open this access panel. If the carriage that holds the ink cartridges moves, then you forgot to unplug the printer, go back and do that now. Look for paper that may be jammed in this area of the printer.
Remove any paper you find jammed here. When pulling from the front there will be resistance from the paper feeder. Pull slowly or the paper will rip and create a more stressful problem.
Close the front access panel. Make sure that it falls or latches back in place. It should look the same way that it did before you opened it.
Plug the printer's power cord into the wall outlet, and attempt to print again. If the printer prints the job, then you have successfully removed the paper jam.
or
Paper jam error.
How to correct, fix: Remove the jammed paper. If paper jams frequently occur, check the following:
1. Confirm there is no foreign material inside the machine.
2. Confirm only recommended paper is installed.
3. Confirm paper is installed properly.
4. Confirm the maximum number of sheets in the auto sheet feeder is within the paper limit mark.
or
How To Reset Canon Printer MP160, MP180, MP460
How to correct, fix: Reseat ink cartridge for Printer (MP160 / MP180 / MP460) Issue: ERROR LED: E, 1, 4
How to correct, fix: Press ON/OFF switch to reset the multifunction device Reset the device when it is not functioning properly. If the device is not functioning properly or to clear memory, reset it. On the operator panel, press and hold the <ON/OFF> button for one second. (The display will go blank.) Note: It may be necessary to unplug the power cord if pressing the ON/OFF button does not shut off the printer. Wait approximately ten seconds and then press the <ON/OFF> button again. Wait until the device has completed its cycling process before submitting another job request.
Turn the machine off, and remove the power cord from the electrical outlet. Wait approximately ten minutes then plug in the power cord and turn the machine on. If the problem is not resolved, the machine may require service.
It just may be that the so-called roller cleaning operation may calibrate the timing
Jul 23, 2015 | Canon PIXMA MP160 All-In-One InkJet...
I have a HP LaserJet 1312nfi that is giving me a FALSE paper jam message. I repeat - FALSE PAPER JAM IN BACK DOOR. False false false. I have uninstalled it on my computer and nothing. I have opened it...
Hello Chris! Welcome to FixYa!
If you are facing False Paper Jam error in your HP Laser Jet 1312nfi but If you cant see any obvious paper jams, try to look closely into the rollers or the inside. There could be some tiny paper shreds stuck within those rollers. Or there could be a tiny piece of paper blocking the printer's sensor and thus giving you a false paper jam error.
The rollers should be cleaned if the paper fails to feed smoothly into the unit. All document and media rollers should be cleaned using a lint-free cloth lightly moistened with water.
1. Turn Off the printer and unplugged power before cleaning the rollers. This will allow the rollers to be turned by hand in most cases.
2. Remove the rear access door to access the rollers. Clean any dust and debris from the rollers.
3. Open the back of the printer and check metal paper rollers (not the rubber rollers) in the interior of the printer. They should be clean and move freely. If these are not bright and shinny or have buildup on them, they should be cleaned. Also clean any dust and debris off of the rubber rollers.
4. Close the back cover and reattach the rear access door.
5. Plug the power cord back in and power the unit up. It should reinitialize for about 20 seconds.
6. Print another extended self-test page.
After following these steps carefully, False Error message will be disappeared.
I hope this solution helps you
Let me know if you have any confusion in your mind.
Sir, Your Rating as FIVE Stars for this solution and words of appreciation will be esteemed
Thank You for taking my service
Concerned: Muhammad Uzair
Jan 10, 2012 | HP Officejet Pro L7680 All-In-One Printer
Message appears "Paper jam".
Paper jams can be true or false. A false paper jam occurs when the error message displays, but no jammed paper is in the product. The following solutions apply to both true and false paper jam errors.
Print a self-test report Use the following steps to print a self-test report.
  1. Load plain white paper in the input tray.
  2. Press Setup , and then press 2 . The Print Report menu displays.
  3. Press 1 to select and print a Self-Test Report
Solution one: Clear the paper jam Step one: Remove loose paper from the tray Remove any loose sheets of paper from the input tray and the output tray.
Step two: Clear the jam from the back of the All-in-One
  1. Figure 2: Remove the rear access doorc01562020.gif
  2. Gently pull any jammed paper out of the rollers inside the product.
  3. Carefully remove any scraps of paper that are still stuck in the product.
  4. Reattach the rear access door. Insert the two posts on the right side of the door into the holes on the product, and then push the door in until it snaps into place.
  5. Reconnect the power cord to the back of the product, and then press the Power button (c01602202.gif ) to turn on the product.
Step three: Clear the jam from the front of the All-in-One Follow these steps to remove the paper jam from the front of the product.
  1. Without opening the cartridge access door, check the tray for jammed paper that you cannot remove from the back.
  2. If you see jammed paper, gently pull it out.
Step four: Print a self-test report
  • If the issue persists , continue with the next solution.
Solution two: Make sure that the carriage can move freely Follow these steps to make sure that the carriage can move freely. Step one: Check the paper path
  1. Check for any paper or object that might be stopping the carriage. Figure 4: Example of paper stuck in cartridge access areac01950807.gif
  2. Remove any paper or objects you find.
  3. Reach inside the product, and then manually move the carriage.
    • If the carriage is stuck on the right side , move the carriage to the left side of the product.
    • If the carriage is stuck on the left side , move the carriage to the right side of the product.
    • If the carriage is stuck in the middle , move the carriage to the right.
  4. Remove any paper or obstructions found.
  5. Make sure that the carriage can move freely across the width of the product by gently pushing the carriage to the left, and then to the righ
Step two: Print a self-test report
  • If the self-test report does not print , continue with the next solution.
Solution three: Clean the rollers and the rear access door Dust, paper fiber, and other debris might accumulate on the paper feed rollers and cause paper jams and paper feed issues. Follow these steps to clean the paper feed rollers inside the product. Step one: Clean the rollers
  1. Press the Power button (c01602202.gif ) to turn off the product.
  2. Disconnect the power cord from the back of the product.
  3. Press in the tab on the left side of the rear access door, and then pull the door away from the product to remove it. Figure 6: Remove the rear access doorc01562020.gif
  4. Lightly dampen a clean, lint-free cloth with bottled or distilled water, and then squeeze any excess liquid from the cloth.
  5. Press the cloth against the rollers and rotate them upwards with your fingers. Apply a moderate amount of pressure to remove any dust or dirt buildup. Figure 7: Rotate the paper feed rollersc00212278.jpg
  6. Make sure that the paper feed rollers on the rear access door are clean, free of paper bits, and rotate freely.
  7. Clean the surface and the rollers of the rear access door the same way you cleaned the large rollers inside the product.
  8. Replace the rear access door. Insert the two posts on the right of the door into the holes on the product, and then push the door in until it snaps into place.
Solution four: Service the product
Aug 08, 2011 | HP PSC 1610 All-In-One InkJet Printer
How to clear paper jam
How you clean the paper jam depends on where it is located and how large the piece is. If you turn off the printer and turn it back on, then press the "ok" button when it says that there is a paper jam - it will rotate the paper inside forward all the way and then retract backwards. Watch the front of the machine and try to grab the paper when the rollers bring it forward. To get it using this method you have to be really quick. If you dont catch it before it goes backwards then press the ok button and try again.
If you are unable to see the piece of paper when the rollers rotate forward, then unplug the machine from the power source and press and hold the power button for 45 to 60 seconds. Then turn the machine around so the the back is facing you.
There should be an unlockable paper access tray on the back of the printer that has two plastic hinges to depress while pulling outward to remove it. Remove the hatch and see if you can find the paper that is stuck in this area. If so, grab it and remove it.
Jul 17, 2011 | Canon MG5250 Printer
While printing 2 or 3 lines it shows paper jam message. Can't print even a page!!!
make sure you don't have any small pieces of paper stuck in the printer s.gif s.gif s.gif
Paper jams can be real or false. The unit may report a paper jam when there is not any jammed paper, however, the solution to a real paper jam or a false paper jam is the same. WARNING: Jammed paper must be removed using the rear access door and the power cord must be disconnected or a carriage jam or mechanical damage may occur. Do not remove jammed paper from the front of the unit.
  1. Turn off the HP product and turn it so the back of the unit faces you.
  2. Disconnect the power cord from the back of the all-in-one. The power cord must be disconnected to allow the paper feed rollers to turn freely.
  3. Locate and open the rear access door by pressing in on the left side tab and then pulling the door toward you. Figure 1: Removing the rear access door c00108288.jpg Inspect the pressure rollers on the rear access door and verify that they are clean and turn freely. Clean the rollers if needed with a soft towel lightly moistened with water. If the rollers do not turn freely, replace the rear access door.
  4. Inspect the pressure rollers on the rear access door and verify that they are clean and turn freely. Clean the rollers if needed with a soft towel lightly moistened with water. If the rollers do not turn freely, replace the rear access door. Click How to buy on this page to order replacement parts.
  5. From the rear access door opening, remove the jammed paper.
  6. Remove the remaining paper from the paper supply tray. Discard any paper that is damaged or crumpled and then re-stack and reload the paper into the paper supply tray.
  7. Reinstall the rear access door.
  8. Reconnect the power cord to the unit and turn the unit on. If a carriage stall occurs after clearing the paper jam, resolve the carriage stall.
Jan 10, 2011 | HP Deskjet F4100 All-In-One InkJet Printer
Won't print because of a paper jam, however jam has been cleared and it still won't print.
Try this:-
Once some printers give the "paper jam error msge" you most go through the motions of clearing paper jam before they will respond even if there is no paper jam.
So I will suggest you turn of printer/open the covers (back and front if applicable). close them back firmly. Turn printer on again and try to print again.
It problem persists, then try this:-
Dust has a way of preventing the sensors from detecting paper. Also it prevents the rollers from having a firm grip on the paper while picking paper; sometimes this could trigger this type of error message. I will suggest you get a long handle brush and try to reach as far inside the printer as possible and brush (from the back and front). If you have a blower you may also use it to blow well into the interior of the printer (If you do not have a blower the brushing will still do if you do it well.) This, if properly done should do it. Brush especially the rollers etc.
Dec 18, 2009 | HP OfficeJet 4215 All-In-One InkJet...
Using HP 1100d Office Inkjet printer. Can't get 'out of paper' light to turn off. I have added paper, pressed the reset button, but light stays on, and printer will not operate.
Please read over the following information and follow step by step.
Issue Either before or during a print job, the message ' Paper Jam ' appears on the product control panel display. The product does not output paper or complete the print job. Solution Follow these steps to resolve the issue. Step one: Remove any loose paper
  1. Remove any loose paper from the paper tray and output tray. CAUTION: Do not remove jammed paper at this stage.
  2. Press the Cancel/No button on the product control panel to clear the paper jam message.
  3. If the paper jam message cleared, try the print job again.
  • If these steps resolved the issue , there is no need to continue troubleshooting.
  • If the issue persists , continue to the next step.
Step two: Clear the jam from the back of the printer
  1. Press the Power button (c01345237.gif ) to turn off the product.
  2. Unplug the power cord from the back of the product.
  3. Remove the rear access door: Turn the knob one-quarter turn to the left and pull the door away from the product. Figure 1: Remove the rear access door c01489996.gif
  4. Gently pull the paper out of the rollers. CAUTION: If the paper tears when removing it from the rollers, check the rollers and wheels for torn pieces of paper that might remain inside the device. If any torn pieces of paper remain inside the device, then more paper jams are likely to occur.
Step three: Clean the rollers While the rear door is removed from the product and the power cord is disconnected, clean the paper rollers.
  1. Wipe the paper rollers with a lint-free cloth that is lightly moistened with distilled or bottled water. Rotate the rollers with your fingers to clean all the way around. Figure 2: Clean the paper rollers c00246512.jpg
  2. Allow the rollers to dry completely.
  3. Replace the rear access door. Gently push the door toward the product, and then lock it in place by turning the knob one-quarter turn to the right or locked position.
  4. Reconnect the power cord to the back of the product.
  5. Press the Power button (c01345237.gif ) to turn on the product.
Step four: Reload paper and test the printer Load a stack of plain white paper in the paper tray and try the print job again.
  1. Press the Cancel/No button on the product control panel to clear the paper jam message.
  2. Lift the output tray.
  3. Pull out the front paper guide on the paper tray and slide the side paper guide as far to the left as it will go. Figure 3: Slide out paper guides c01489992.gif 1 - Front paper guide 2 - Side paper guide
  4. Load a stack of plain white paper, print-side down into the paper tray. Make sure the paper stack is no higher than the top of the front paper guide.
  5. Adjust the side and front paper guides to fit snugly against the paper stack. Figure 4: Adjust the side and front paper guides c01489993.gif
  6. Lower the output tray.
  7. Disengage the photo tray: On the output tray, pull the slider (visible through the output tray) away from the product until it stops. Figure 5: Disengage the photo tray c01489994.gif
  8. Try the print job again.
Step five: Service the printer If you have completed all the steps listed above and are still experiencing a problem, service the product. Have a good day,
Jun 18, 2009 | HP Inkjet 1100d Printer
Paper jam
Fiend your solution direct from hp. Here is your solution...
http://www.hp.com/printer/prob676ijt65/solution
334
Jun 29, 2008 | HP Officejet 5610 All-In-One InkJet...
or try
Jun 24, 2008 | Office Equipment & Supplies
jasbo
jasbo
