Question about Dell Adamo 13
Black screen, board frozen
Red power button on, wont turn on or off
I have a 32 inch Samsung TV that is only two years old. When you press the power button, it sounds like it it turning on and the red light comes on but the screen is black and there is no sound.
Main board is bad since it works with both video and audio. Ur backlights are ok so that omits the inverter board. And the T con board is for video only - since you have hassles with audio and video that leaves the main board. Do not think it is the power supply since your inverter board is powering up the back lights.
Nov 11, 2015 | Samsung UN39FH5000FXZA - 39in 1080p 240...
Unit powers up but display is frozen and no nothing after that. No remote or button response except for display off.
The display microprocessor(computer within your unit) may be bad. This IC is responsible for processing any and all IR(infra red) commands from the remote, as well as scanning all the push buttons on the front of the unit. If you're interested in having your unit repair, please visit me website at audioserviceclinic.com. You may contact me there. Thank you.
Sep 04, 2015 | Pioneer X-smc3-s Music Tap Airplay Music...
I have a Plasma TV with black screen and 6 red light flashes.
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
May 19, 2015 | Panasonic VIERA TC-P55VT50 55-Inch
Samsung s3 phone wont turn on only red light stays on and a buzzing noise sounds and wont turn on need help
Shut it down by holding the power button until the screen goes black, don't tap the power off button, wait for the black screen. Then let your phone charge for a few hours (maybe over night) with power off and see if that helps.
Dec 12, 2014 | Samsung Galaxy S Iii S3 Gt-i9300 16gb...
Emerson flat screen won't power off and screen flashes blue ,green, red and black?
Sounds like the main board causing that type of symptom. You can get replacement main boards from www.tvrepairworld.com
Jan 10, 2013 | Televison & Video
Sony bravia screen just stays on black and wont go to picture.
It sounds like a main board failure but could be a power supply issue as well. The set will need to be diagnosed
Oct 01, 2012 | Sony Bravia Kdl - 60Ex700 60 inch 1080P...
My inspire seems to be locked on one screen that has a red triangle with an exclamation running through it. The phone will not shut down. It is frozen.
It is the boot rom menu for the device. Just power it off then back on. IF it comes back then your OS on your phone is toast.It means your phone is in recovery mode. Hold down the volume up and power button at the same time, then select the option to reboot by going up or down with the volume keys and pressing the power button to confirm your selection.
Dec 06, 2011 | HTC Inspire 4G Smartphone
Sony 2GB MP3 Player NWZB135 - Black. frozen screen
Push the reset button on the back of your MP3 its a SMALL hole labeled RESET. Use a small object and insert it into the hole. Press the button and turn it back on
May 30, 2009 | Sony Audio Players & Recorders
Samsung flat screen wont turn on red light just flashes..
wont turn on red light just flashes?
On my samsung flat screen tv when you are watching the televison there is no red light on the power button but when you turn the television off the red light stays on all the time? what can I do to turn this light off?
Jul 20, 2008 | Samsung LE32R73BD 32 in. HD-Ready LCD...
Dell Adamo 13 Logo
22 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
