Question about Cooper Wiring Devices 277W-BOX SINGLE POLE SWITCH & RED NEON PILOT LIGHT
Pilot light always burns light never comes on
I have a light in the garage that has the switch inside the house. The switch worked for several years and when the light was on in the garage the pilot light was on at the switch. Something happened and now the light never goes on in the garage ( I have changed the bulb and made sure it was a good one) and the pilot light on the switch never goes off. Any suggestions?
    Sergeant:
    Champion:
  • 426 Answers
Change the switch
Posted on Nov 06, 2013
3 Suggested Answers
SOURCE: Leviton Single Pole Switch with Pilot Light Model 277W Box
Depends on whether you want the pilot to glow when the circuit is live (the main light is on) or to glow when the circuit is off. (The switch can be used either way, and I have used this switch in both configurations at different places.)
The wiring diagram is on the inside of the box.
In indicates that if you want the pilot light to glow when the circuit is off, then you only need two wires (the live and the return, usually colored black and white, respectively). However, you also need a ground. The instructions say that you need the ground for safety (and probably legal code) reasons, but I suspect that, without the ground, the pilot light won't work in this configuration.
However, if you want the pilot light to glow when the circuit is on, you probably need a three wire configuration (plus the ground).
Hope this helps.
Posted on May 05, 2009
SOURCE: A light circuit doesn't work (no lights on) with
If I understand correctly you have a circuit with 4 light switches.
None of the 4 switches work, yet all 4 test for 115Vac.
Test each screw on switch to bare ground to get reading.
This problem could be loose neutral wire inside the switch boxes or anywhere along the line, or inside breaker box. Check white wires.
All 4 switches connect back to breaker box on white neutral wire that connects to neutral busbar inside breaker box.
http://waterheatertimer.org/240-v-water-heater-circuit.html#120-240
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on circuit or any do-it-yourself project.
Fixya is always less expensive than a service call.
Posted on Feb 10, 2011
My pilot goes out when burner turns off?
Is this just a recent occurrence? Your pilot light may need to be replaced or cleaned. It's also possible that your switch may need to be replaced.
May 05, 2016 | Heating & Cooling
I have a reznor heater in my garage I have to keep lighting the pilot it wont stay lit.
i have an ole reznor in my garage been workiing for ten + years no problems , mine is gas , the pilot light does go out after it switches to main burner like ten seconds later , but does light back up when thermostat shuts main off ( i had to go look to make sure) not a real big flame maybe like an inch or so , has a spoon shaped air shield around it , maybe yoours is missing ?
Mar 02, 2015 | Heating & Cooling
HOW TO LIGHT OVEN WITH A MATCH
Look up product manual on internet.
Look at label located inside oven door, and add .pdf to search parameter to help find manual.
Then read section about lighting appliance.
If power is out, then pilot will not have any gas >> if gas control is electronic.
Many electronic gas controls require electric power to operate circuit board.
In old days, you removed the bottom tray on oven to access burner and pilot orifice. Then you pushed down switch to release gas through pilot tube, and put lit match into the gas stream to light pilot. Hold down switch until pilot flame heated tip of thermocouple which caused magnetic switch to stay open inside gas control. Release switch and pilot stayed lit.
Safety concerns and vast advances in manufacturing cheapness have changed gas appliances so they are more inconvenient for do-it-yourselfers during ordinary power outage.
Cook hamburger over metal bucket with newspaper, and grease on newspaper burns enough to cook hamburger.
People always buy generators and flashlights, but nobody suggest buying barbeque briquets and starter fluid as way to keep warm and cook.
Oct 29, 2012 | General Electric GE 24-Hour Power Strip...
Leviton Decora PIR Wall Switch Sensor won't work in auto when the garage when it's hot
Heat is the enemy of electricity, especially electronics.
The public doesn't understand how global warming is going to affect electrical devices including your phone, timers, detectors, and all electrical power.
If you research operational temperatures for small electronic devices, the upper range is usually 105-120 degrees F. Some can operate up to 135 degrees F, and will fail in higher temperatures because the circuit board, chip and parts are made to withstand certain temperature tolerances.
High temperature hardened devices cost more than typical box store electronic device.
There can also be a low temperature range that affects batteries and rechargeable batteries inside devices that have display properties.
Back to high heat: Electronics are limited by high heat.
Electrical transmission along power lines is limited because of high heat. Long distance transmission is high voltage and low amperage to reduce heat caused by high amperage.
(Super conductive materials, that allow limitless transmission without loss, must be at very low temperatures (absolute zero, etc))
And then at your house, the high voltage low amperage power line is changed to lower voltage high amperage at the transformer before it enters your home.
If you get serious electrical shock, you will get burned because electricity is Hot. The power line in electrical circuit is called the Hot line. So electricity is all about heat.
http://waterheatertimer.org/See-inside-main-breaker-box.html
Unrelated to electronics, but related to global warming: Even gas water heaters inside hot attic will lose the pilot light because the heat pushes air molecules farther apart, making it harder to breathe, and causing the pilot flame not to have enough oxygen to support combustion.
People should consider if we will be able to make small fires if global temperatures get hot enough.
http://waterheatertimer.org/pdf/Attic-Ventilation-and-Pilot-Outage-in-Gas Water-Heaters.pdf
This means the short-term solution to your electronic problem is to open a window slightly in the garage.
Better yet is to install natural ventilation.
Install a vent(s) on the wall, down low along floor on shaded side of garage. Then install another vent(s) on wall near ceiling, or install a vent pipe to roof.
The combination of high-and-low vent will cause a natural flow of air through the garage. This is the same principle used to ventilate an attic.
Aug 24, 2012 | Leviton R01-PR180-1LI Decora 180 Degree...
How do you shut down
the pilot light always stays on, its designed to allow your heater to turn on by itself without you needing to light a match every time. if the pilot light is burning you have nothing to worry about. its when the pilot light goes out that a small amount of gas leaks into the room. and by small i mean smaller than a hand held lighter... if you still want to shut the entire thing down you could turn off the gas line feeding the heater or possibly the whole house, otherwise the pilot light will stay on. as far as the actual heater turning off, thats probably controlled by some sort of thermostat somewhere. if you set the temp to very cold it should stay off. if that doesn't work then you may need a new thermostat.
Dec 31, 2009 | Vanguard International VN18B Infra-Red...
My honeywell gas suspended garage heater will not come on when the t'stat calls for heat. It is a heat only unit and neither the fan nor the blower motor will come on. The Heater is getting power to it...
The pilot light has to be lit before gas valve will operate. That's a safety feature so the valve won't open and fill the garage with gas and possibly cause an explosion or fire. If you have a standing pilot and can't get pilot to stay lit, it's usually the thermocouple and it will need to be replaced. Once the pilot is lit, the gas valve comes on and heats the combustion chamber up to approx. 100° to 125° a thermostat controlled fan switch will close and bring the blower on.
Sep 08, 2009 | Mr. Heater Suspended Garage Heater
My heater will not ignite. The pilot is on but
The gasvalve has a pilot solenoid which is powered by in essence a thermocouple called a thermopile which converts heatfrom the pilot to to a millivolt output which is why you have to hold the pilot valve till it makes electricty. The main gas valve goes through a series of safety switches and through the thermostat so if any switch has a badoropen contact the heater will never fire find the bad part with a continuity tester and replace it.
Jul 18, 2009 | Jandy Lite 2 Natural Gas Pilot Light...
After a few minutes of burner heating the water, gas shuts off.
A couple of things to check:
If possible, remove the pilot gas assembly and clean the gas jet and thermocouple - they can get carboned up and stop working properly. Make sure the pilot flame and deflector is aimed properly and making the thermocouple glow red hot. If the problem persists, you may want to replace the thermocouple and also check the propane regulator.
Apr 20, 2009 | RTO Atwood Water Heater - 6 Gal LP
Remote opener
Have you tried to re-learn the remote? The instructions should be inside the opener cover.
Nov 02, 2008 | Sears Craftsman LiftMaster Chamberlain...
New water heater problems
the switch is broken, or the voltage on the power from the wall is lower than the voltage on the tank and therefore it could only powering one thing
Oct 16, 2008 | Water Heaters
Cooper Wiring Devices 277W-BOX SINGLE POLE SWITCH & RED NEON PILOT LIGHT Logo
147 people viewed this question
Top Cooper Wiring Devices Electrical Supplies Experts
ken skalski
Jim Y
Jim Y
Are you a Cooper Wiring Devices Electrical Supply Expert? Answer questions, earn points and help others
