Question about Motorsports
I had been driving most of the day with no problems & left my car sitting while it was running for about 15 min & when I got back in it to leave it was stalling like it was running out of gas but I ha
  • johnson Jan 28, 2016
    I picked interest on you after going through your short profile and demand it necessary to write you immediately. I have something very vital to disclose to you, but I found it difficult to express myself here, since it's a public site.Could you please get back to me on(drnne1984@gmail.com) for the full details.
    Have a nice day.
    Mr.Augustin Aziankou
    Scholar:
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 64 Answers
Sounds like fuel vaporization check the heat of the fuel pump it can be warm but not hot the fuel from the tank which is cold should be cooling the pump, check for air leaks or loose connections on inlet side of the pump if there is a leak on the pressure or outlet side of the pump it will be obvious. then check fuel the pump relay by swapping it with another relay.
Posted on Jun 12, 2014
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 4 Answers
What kind of car is it ? Fuel injected cars will not vapor lock. Most fuel pumps are located in the tank.I would have it pressure checked to make sure its pumping the correct psi for your make and model of car
Posted on Dec 25, 2015
    Have a nice day.
    New Friend:
  • 36 Answers
I think you will find the first answer is most probably the problem, have a close look to see if the Fuel line is either going above the engine, or close to the exhaust system on the engine, if it ran okay once it cooled down then this is the answer. Best Wishes. Malcolm.
Posted on Feb 10, 2015
  • Malcolm Campbell
    Malcolm Campbell Dec 25, 2015
    Should this be a spark plug engine this can point to either the Distributor or even the coil Check the points 1st. then see if coil is hot this can also be down to the plugs & coil Leads.
  • 3 Answers
Check for a clog in the fuel lines, when the car is not actively moving the gas settles letting anything that would clog ur lines would go right to ur pump and when u accelerate u pull it in to the smaller fuel lines and they clog
Posted on Jul 16, 2013
    Have a nice day.
a 6ya Mechanic can help you resolve that issue over the phone in a minute or two.
click here to Talk to a Mechanic (only for users in the US for now) and get all the help you need.
1986 Lincoln Town car 5.0 intermittent stalling problem, usually while driving. fuel pump?..please advise! Thx!
It appears you may have a bad ignition coil that cuts out after it gets hot. Not uncommon.
Aug 16, 2017 | Lincoln Cars & Trucks
96 Benz ran out of gas other day, got it filled up & drove home (20 miles). Next day drove about 40 miles, left car running in park for about 15 min, when I left car was stalling like it was running o
You never leave a car running, as it will
overheat the Exhaust Converter
When you run out of fuel, you sometimes
ruin the Fuel Pump
It depends on gas to lubricate it,as strange as it sounds
Check fuel pressure & volume at the motor with a gauge
Jul 20, 2013 | Cars & Trucks
Bike leaves me stranded after 15 mins
Check your ignition coils. Sometimes they fail with an open circuit, this can sometimes close up when the machine is cold and open again when it heats up. So. it will start when cold and fail when it warms up.
Apr 24, 2013 | 1982 Yamaha XJ 650
After the car runs for about 15 mins it will die when driving or after sitting for a few min. Sounds like now spark when cranking over. If it sits awhile it will restart and maybe not die again for days.
some component in the wires is heating up-things wearout in older cars--its still gettin spark but inspec plug wires and distributer for wear-ignition module cud be failin--------fuel system may hav issues like the pump or regulator--------run a scan
Aug 30, 2011 | 1995 Subaru Impreza
Okay my car started having problems starting it had a quarter gas tank and had never gave me any problems. Never has been over heated just had temp gauge replaced transmission flush and perfect inspection....
try my favorite simple fix. Get some stp fuel treatment or whatever is common for your area, read the label and make sure it removes water from the gas tank/gas pour the entire bottle in then fill up the tank. let the car run for a few minutes drive it if possible. Your problem should clear up shortly.
Jun 29, 2010 | 2004 Jeep Grand Cherokee
Driving to milwaukee and my battery light turned on. never happened before. got to where i was going, turned off the car, let it sit for a min, turned it back on and the light was off. left a few hrs...
Hi:
The battery light means that your Alternator is not charging the battery. Thankfully, your cars battery was fully charged, and I am guessing that you were driving during the day, because if you were using your headlights, you would have been in trouble.
Basically, a fully charged battery should read about 12.6 volts, and when your car is running, you should be able to measure about 14 volts across the battery, because that is the output of your alternator. You can get your alternator tested for free at a local auto parts store, such as Auto zone, as it is the most likely thing to change.
Nov 12, 2009 | 1991 Honda Accord
87 VW Cabriolet starting problems
I would start with a fuel line psi test. then have your fuel acumulator.
http://home.hiwaay.net/~langford/CIS.html
check this out and see if it helps. It sounds like you are priming the psi up when cranking then it can go. but when you let it sit the pressure drops and has to build up again. I a not a VW person myself but love tinkering, so let me know how it goes.
tepfy
May 01, 2009 | 1986 Volkswagen Cabriolet
HONDA Accord 1981 model
the fuel is bad, check your fuel lines and put new fuel in. fuel does go bad if you leave it sitting too long, next time run your car for 15-30 min once a week to prevent this
Nov 22, 2008 | 1992 Honda Accord
Motorsports Logo
628 people viewed this question
Top Motorsports Experts
chuck ringwood
chuck ringwood
Jim Rus
Jim Rus
Steve P
Steve P
Are you a Motorsport Expert? Answer questions, earn points and help others
