Question about Philips Magnavox 51MP392H Rear Projection Television
51mp6200d 37 Software updates for the TV via USB port. Are they available?
2 Suggested Answers
ladywinn
  • 5138 Answers
SOURCE: no sound, no picture` MAGNAVOX 51MP6200D/37
SSB board its the one over next to tuner.
Posted on Sep 25, 2009
I HAVE A VIZIO TV MODEL M3D550SR ITS SAYING IT HAS TO UPDATE FIRMWARE 3.12.17 IT STARTS TO UPDATE ONLY GOES TO 37% AND STOPS CAN I GET THE FIRMWARE AND DOWNLOAD IT TO A USB AND MANUALLY UPDATE IT
Yes. You should never do those updates via internet because you can toast the system with a bad download. Check your manual. You may have a _specific_ USB location on the TV for firmware updates.
Mar 12, 2016 | Vizio Televison & Video
Vizio bluray vbr220 firmware update where ?
2 ways to update Vizio BR vbr220, see page 41 of manual
1. via USB
2. via internet
Via USB
1. Download the software from www.vizio.com to the root directory of a USB thumb drive.
Notes:
The USB storage device should be 1GB or larger with at least 100MB of free space and
formatted FAT32. NTFS and other file systems are not supported.
The USB storage device must not have other .iso or .dat files in the root directory.
2. Connect the USB storage device to the USB port on the front of your player.
3. Follow the on-screen instructions to update your player.
Via Internet
When a new software update is available, a message will be displayed on the Home menu. To
update the software:
1. Connect your Blu-ray player to your home network
2. Press the B (green) button.
OR
a. Press < or > to select Settings and then press SELECT.
b. Press < or > to select System. The System menu opens.
c. Press \/ to select Update Via Network and then press SELECT.
May 31, 2014 | Samsung BD-P1200 Blu-Ray Disc Player
Hdmi ports are not working
Have you gone to the philip's website. There is a firmware upgrade available. Simple to install if your tv turns on. You just need a USB drive to load the software on.
http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?ctn=47PFL7432D/37&slg=EN&scy=US
Feb 28, 2014 | Philips 47PFL7432D/37 TV
The TV automatically switches to the Menu option by itself
Reset the TV first and see whether it help you. To reset it, unplug it from AC mains wall socket, and replug it after 5 minutes or so. If this do not help you, the main system memory IC to your TV should be checked. Might need replacement.
Jun 08, 2012 | Philips 37PF7320A 37 in. HD-Ready LCD...
This is not really a problem but is the serial port the only only option to connect a PC? What about USB or Firewire?
The USB ports for TVs are usually for accessing drives to play photos or videos. Unfortunately the PC will not communicate directly with the TV via USB. A device in between connecting to the TV via USB and using the other TV ports makes the PC communicate with the TV.
Apr 03, 2011 | Hannspree XV37 HDTV 37 in. LCD TV
No sound on 90 HD Digital Channel
You need to get in touch with Lg and they will help you. All you need is for them to either post you a usb with software or they can email it to you and you can put it on a usb and put it on your tv via usb port and update the software on your tv.
The frequency for the new channel is not on your tv but they will give you the software to update so it works.
Jul 02, 2010 | LG 47LC7DF 47 in. LCD HDTV
Usb ports on processor does not work
Click Start
Click Control Panel
Click Classic View
Click System
Click Hardware
Click Device Manager
Expand the "USB Serial Bus Controllers" branch.
Any "yellow" or "red" icons indicate that the device-driver software for your USB ports is not installed, or it is incorrectly installed.
Since your Shuttle motherboard uses a VIA chipset, VIA says:
For Win2K and WinXP, due to licensing agreements, a VIA USB2 driver package cannot be distributed online. Driver support for VIA USB 2.0 controllers requires Windows XP SP1 (Service Pack 1), Windows 2000 SP4, or system upgrade through Windows Update.
So, just run Microsoft Windows Update, and look in the "Optional Hardware" section for available downloads for the USB 2.0 ports on your motherboard. Select and download and install the update.
Dec 10, 2009 | Shuttle MV43VN Motherboard
Bottom half of the screen goes black frequently.
You can start here: http://www.support.philips.com/support/catalog/catalog.jsp;jsessionid=87CE21B6A8264B83B8D00501ADACA8BF.app107-drp1?_dyncharset=UTF-8&country=&categoryid=FLAT_TV_CA_US_CARE&userLanguage=en&navCount=1&groupId=TV_GR_US_CARE&catalogType=&navAction=push&userCountry=us&title=Flat+TV+(plasma%2C+LCD)
Enter the exact Model Numbere in the search text field.
First verify the exact Model Number of your TV. Mine is a 42PF7220A/37.
go to:
http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?ctn=42PF7220A/37&scy=us&slg=en
On this page I found listed under "Software2.gif & drivers" the Firmware Upgrade Software 42PF7220A/37 v1.5.0.0
I downloaded the compressed file and extracted it to a USB Flash Drive2.gif.
After you extract the file you will have 2 files...."autorun.upg" and a "readme.txt".
Make sure the USB Flash Drive2.gif has only one file on it (autorun.upg)
Make sure the TV is turned off.
Put the USB Flash Drive in any of the USB ports on the TV.
Turn the TV power on with the Power Button on the righthand side of the TV.
The TV will display an Update screen.
Let the TV run through all 3 processes.
Turn the TV off and remove the USB Flash Drive.
Power the TV back up.
Hopefully the Updates fixed the problem.....
Jul 27, 2009 | Philips 42PF7220A 42 in. Plasma Television
LG 37LG30 HDMI no sound problem
This is more probably a software fault within the TV. They need instructions for HDMI inputs & a no sound is a related fault. I would get in touch with your dealer to arrange the TV to be updated to cure this problem. Hope this helps.
Apr 11, 2009 | LG 37LG30 37 in. LCD HDTV
TV turns off for no reason and comes back on
Apparently this is a firmware (software) problem that has been fixed via a software upgrade. You can download it from Philips' web site, copy it to a flash drive, and load it into your TV via the USB port. I did, and this problem has not returned.
Apr 25, 2008 | Philips 37PF7320A 37 in. HD-Ready LCD...
Philips Magnavox 51MP392H Rear Projection Television Logo
27 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
