Question about Furuno 1650W/NT Gps Chartplotter C Map Nt Charts
Power down on engine start - Furuno 1650W/NT Gps Chartplotter C Map Nt Charts
    New Friend:
  • 132 Answers
You need a "House Battery" to run your electronics off of. Running the Fishfinder on the start battery is not a good idea. If not practical, the operator must power down the unit during engine start. It is getting low vltage during crank.
John Barry 8947-746-0100
Posted on Oct 16, 2013
  • Links_Man02 Jul 13, 2014
    Or perhaps your cranking battery is getting old and needs to be replaced. I run HDS-7, HDS-8 and LSS2 off my cranking battery.
Engine powered down going up hill then recovered, PTO stopped, now engine will not turn over
safety switch,unhook the ground wire from coil,if it starts then a safety switch is bad,also might need a new ign switch.
Apr 21, 2015 | Garden
Odd experience: engine powered down going up hill, then almost stalled. PTO will not engage, now engine will not start or even turn over.
I had a similar experience and I had to replace the PTO.
What size motor do you have and what brand is it?
Apr 21, 2015 | Cars & Trucks
My escalade flashed a warning light to reduce the engine power it then shut down and wouldnt start
Your Escalade has put itself into "limp home mode", it is protecting you from destroying the engine or transmission. I would take it to autozone or Pepboys let them scan it for a stored code....it could be several different things.
Mar 21, 2014 | 2002 Cadillac Escalade
Driving along lights dimmed, instrument panel died, loss of power then engine cut out & wouldn't start. Starts with a jump but when i turn key to heat glow plug, instrument panel goes mad
I assume there's a problem with alternator. Check the grounding to engine, check continuity of a positive wire between alternator and battery. the energizing voltage should be checked as well. Might be the bad connection between battery and vehicle body grounding. Diesel cars are sensitive even in a little loss of connection and rust in the connection points.
Feb 18, 2014 | Cars & Trucks
Idle up and down not good power
which engine, there are many opted engine, name one.
did you say the engine lacks power? under what conditions.
Parked
moving.
hills,
wideopen throttle weak?
what?
btw : no idle works right if the engine runs bad.
lean fuel the ISC cant control idle ,
same for misifire.
idle is the last thing to work right in EFI.
is engine misfiring, and if so did it before the tune up or after./?
Jan 27, 2014 | 1997 Jeep Grand Cherokee
My engine coolant temperature warning light came on, it started losing power and shut down. Now it won't start now. What is wrong with it?
if you dove it for a while wen the light came on you may have lost some engine coolant and now the engine may of over heated and sized up and now it wont work
Aug 03, 2012 | 2009 Chevrolet Cobalt
Lawn tractor lost power while in use engine slowed down
Check for spark, if spark is present, then remove air cleaner and pour some gas down carb. not to much, then keep away while starting. If motor starts and runs then shuts off you have a stuck needle and seat or fuel pump problem.Also check oil level.
Mar 06, 2010 | Craftsman Garden
Starts OK but after about 15 or 20 minutes starts losing power and after moving throttle up and down for five minutes or so to keep going dies After cooling for twenty or thirty minutes will start and go...
When your ignition coil get to engine temp. it will begin to lose its power, therefore your engine will eventually shut down, when it cools it will start up again,
Good luck
Jul 02, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Won't start
try jump starting. the battery may not have enough power to start the engine
Sep 26, 2008 | 1996 Pontiac Sunfire
Furuno 1650W/NT Gps Chartplotter C Map Nt Charts Logo
70 people viewed this question
Top Furuno Boating Experts
Colin Stickland
Colin Stickland
Shehu Pro
Shehu Pro
Steve
Steve
Are you a Furuno Boating Expert? Answer questions, earn points and help others
