PANASONIC TH-L32C3X SERVICE MANUAL
OK POWER SUPPLY BUT BACK LIGHT INVERTER CIRCUIT WILL SHUTS OFF
Posted on May 22, 2014
  • 191 Answers
SOURCE: VIZIO LCD 26 INCH model# VW26L HDTV10F NOT TURNING ON
unplug ur backlight inverter plug &power on to see ,if it doesnt on , change ur mainboard
Posted on Nov 10, 2008
MNfisherman
  • 11896 Answers
SOURCE: Does anyone have a panasonic TH-42PX50U Service
www2.panasonic.com/consumer.../model.TH-42PX50U
www.nodevice.com/manual/.../panasonic/th.../get29233.html
www.panasonic.user-manuals.com/list-of-manuals-292-5104.html -
You can copy and paste any of these links into your address bar to bring you to your manual
Posted on Aug 25, 2009
  • 63 Answers
SOURCE: Panasonic Plasma TH-42PX60U - power light blinks 12 times
Bad capacitors...! Remove rear panel cover from tv. Most require a star screwdriver. Look for bulging caps in power supply board. (3300uf 10v ) caps need to be replaced with 3300uf 16v. Identify the bad caps.... Caps are bad when they are bulged/bulged and raised. A good Cap is flat X top not raised or buldged. I have pics of what bad caps look like on these boards. Email me if you would like to to see them. Caps cost abywhere from 1-2 dollars or you can buy them in lots of 10 or 12 on ebay for around 8 bucks. Caps need to be soldered on. Do it yourself (if confortable) or take it to a tech/pc repair shop in your local area. Do do that unplug all the wire harness from the board and unscrew the boarda nd take to your teck to solder on the new caps.
You can fix this for about 20 bucks if you have someone else solder or 40 cents if you buy the caps on ebay and replace the 2 bad ones yourself. If one is bad and the other is not replace them both.
The caps go bad because they need to be a higher voltage. 10 insn't enough..... 16 is plenty and don't go any higher than that.
Good Luck
Gunny
Posted on Feb 07, 2009
  • 8457 Answers
SOURCE: i have a plasma panasonic viera TH-42PV60A stand
Not power supply,it the backlight video board it dead.
Posted on Nov 23, 2009
Testimonial: "cool thanks alot"
  • 8457 Answers
SOURCE: TH-50PZ80U POWER INDICATOR LIGHT KEEPS BLINKING
Power board it dead,take the tv aparts.Check for Capacitors parts for puff up or burst open.Know how to solders?replaced these capacitors in the power board.Or replaced the whole power board.Tries Shopjimmy.com,Ebay.com.
Posted on Jan 19, 2010
Panasonic led tv model no c320x14-E3-B tv tv start few second picture goes and sound OK but no raster
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electro-medical.blogspot.com/
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Dec 26, 2016 | Panasonic Televison & Video
Panasonic tv model Th-42pd60u turns on after awhile picture disappears but you can still hear the sound
Oct 01, 2016 | Panasonic Televison & Video
My LCD Panasonic th l32c22d TV there is sound but no picture ? What should I care
Oct 08, 2015 | Panasonic Televison & Video
I have a panasonic tv, TH-21FAB when I open no picture but I can hear the sounds and the channel only 11 and 13.
Some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement.
Jul 30, 2015 | Panasonic Televison & Video
TH-42PZ80U Panasonic Plasma, red light flashes 10 times
Panasonic said "A" board,
A board SOS Detect (Explanation)
10 Blinks SOS: The voltage regulators IC5400 and IC5401 in the A board generate SUB9V and SUB5V. The 9V and 5V from these ICs are monitored by IC1100. Any abnormality on the SUB9V or SUB5V lines, triggers the shutdown circuit and the MPU shuts down the unit. The power LED blinks 10 times.
But need to measure the connection SC2, if it short, it will be the SC board.
The knowledge obtain from: Real case of repair by myself.
Information from Panasonic training manual.
Apr 27, 2010 | Panasonic Viera TH-42PX80U Plasma TV
Panasonic TH-42PD50U RED ON LIGHT BLINKS BUT WON'T STAY ON
Normally, when this happens, the TV goes into " Protection Mode " because of a failing circuit board. Most likely the TV has a power supply related problem. It's possible that it maybe a bad capacitor or transformer on the power supply board. The most common thing to go out on flat panel TVs is the circuit board that supply power to the screen. Commonly called a Backlight Inverter Board. But, I can't say it's 100% the problem because I can't actually look at the tv over the internet. I can only make guesses with the symptoms.
You have a few choices:
1. You can try leaving the TV unplugged for 30 minutes so the TV can reset itself.
. If you have some electronic experience, if you can find and purchase a Service Manual over the internet; It will help you diagnose the source of the problem and fix it by soldering in the new part. The Service Manual will give you red light blinking codes, circuit diagrams, test points, and part# lists. Usually, cost under $20. And most cases the new part cost less than $15.
3. Pay a TV shop to do the repairs. It maybe costly, but get an estimate of how much they will charge. That way you can decide if it worth repairing or replacing the whole TV.
I hope I shed some light on the subject for you.
Jul 13, 2009 | Panasonic VIERA TH-65PV500 65 in. Plasma...
My panasonic plasma tv model number th-42px77u won't turn on
Most likely the TV has a power supply related problem. It's possible that it maybe a bad capacitor or transformer on the power supply board. The most common thing to go out is the circuit board that supply power to the screen. Commonly called a Backlight Inverter Board.
If by chance the TV is still under warranty, go that route.
If not under warranty and If you have some electronic experience, if you can find and purchase a Service Manual over the internet; It will help you diagnose the source of the problem and fix it by soldering in the new part. The Service Manual will give you circuit diagrams, test points, and part# lists. Usually, cost under $20. And most cases the new part cost less than $15.
Jul 08, 2009 | Panasonic TH-42PX75U 42 in. Plasma...
Panasonic Model TH-50PX60U (Screen shutting off..)
Most likely the TV has a power supply related problem. The most common thing to go out is the circuit board that supply power to the screen. Commonly called a Backlight Inverter Board.
If not under warranty and If you have some electronic experience, if you can find and purchase a Service Manual over the internet; It will help you diagnose the source of the problem and fix it by soldering in the new part. The Service Manual will give you red light blinking codes, circuit diagrams, test points, and part# lists. Usually, cost under $20. And most cases the new part cost less than $15.
Jul 04, 2009 | Panasonic TH-50PX60U 50 in. Plasma HDTV
Blinking red light of death
The most likely the TV has a power supply related problem. The most common thing to go out is the circuit board that supply power to the screen. Commonly called a Backlight Inverter Board.
If not under warranty and If you have some electronic experience, you can purchase a Service Manual over the internet and diagnose the source of the problem and fix it by soldering in the new part. The Service Manual will give you circuit diagrams, test points, and part# lists. Usually, cost under $20.
Jun 28, 2009 | Panasonic TH-42PZ77U TV
We bought the Panasonic TH-50PZ700A TV in August 2008. Tonight we were watching the a program in the TV and suddenly the picture disappear (only the sound on). After that we cannot turn on the TV. Each...
Jul 27, 2017 | Panasonic Televison & Video
Televison & Video Logo
139 people viewed this question
Top Televison & Video Experts
Electro Med Services...
