Question about Fisher and Paykel IWL12 Top Load Washer
Code 130 Rotor positions sensor error
I see where the tiny cables connect to a module on one end but should it unplug or how do you clean or check the connection? any photos of what I should be looking for?
  • Fisher and P... Expert
  • 555 Answers
Rotor Position Sensor Removal.
Code 130 Rotor positions sensor error - 1311bc7b-fb7c-4894-a557-b1d3106e713b.jpg
Posted on Dec 13, 2013
Fault code 130
130. (10000010) Single Rotor Position Sensor Error
The Motor Control Module has found an error in the pattern received from the Rotor Position Sensor.
Likely causes of this fault are a bad connection on the harness between the Rotor Position Sensor and the Motor Control Module,
or a faulty Rotor Position Sensor.
Primary Source: Wiring.
Action: Check for corrosion on the RAST connector of the Rotor Position Sensor and the Motor Control Module connector.
Secondary Source: Rotor Position Sensor.
Action: Check the Rotor Position Sensor with an R.P.S. tester. Replace if faulty.
Tertiary Source: Motor Control Module.
Action: Replace Motor Control Module.
Quaternary Source: Rotor
Action: Ensure the correct rotor for this phase of machine has been fitted.
Mar 14, 2014 | Fisher and Paykel Fisher Paykel Intuitive...
Hi there i have a fisher and paykel washing machine that fills but part way it will stop then carry on then later the first and 7th lights will flash it also does it while it spins
That is error code 130
130.
(10000010) Phase 1 to 6 - Single Rotor Position
Sensor Error
from the Rotor Position Sensor. Likely causes of this fault are a bad
Motor Control Module, or a faulty Rotor Position Sensor.
Action: 1. Check for corrosion on the edge connector of
2. Check the contacts on the rotor positional
sensor end of the hall harness to see if any
have been damaged. (Each set of contacts in
the socket has two wipers. If the distance
between these wipers varies between
different contacts, replace the rotor positional
sensor harness.)
Jan 01, 2013 | Fisher and Paykel WL26CW1 Top Load Washer
Fisher & paykel intuitive eco manual, bearing & seals need replacing
Error code 130 is Rotor position sensor fault.
130.(10000010) Phase 1 to 6 Single Rotor Position Sensor Error
sensor harness.)
Go to this site & select your model for parts view.
You will need Adobe reader to view PDF's
http://www.jordansmanuals.com/default.aspx?Brand=FP&Product=Washing
Oct 05, 2012 | Fisher and Paykel Washing Machines
What is error 240 on a Fisher & Paykel IntuitiveEco IWL16 Top Load Washer
240. (11110000) Phase 6 - Hall Out of Order. RPS Fault
Same as previous Hall Error faults, just an extra fault code for Phase
6. See fault codes 130 and 131 for directions.
130. (10000010) Phase 1 to 6 - Single Rotor Position
Sensor Error
sensor harness.)
131. (10000011) Phase 1 to 6 - Repetitive Rotor Position
Sensor Error
This fault is similar to fault number 130 above but differs slightly in that
it is a continuous condition.
Oct 02, 2012 | Fisher and Paykel IWL12 Top Load Washer
I have a fault code on off off off off off on on
That is fault code 131
Sensor Error
it is a continuous condition. See fault 130 for service procedure.
Sensor Error
sensor harness.)
Sep 17, 2012 | Fisher and Paykel Washing Machines
What does Cold 130 mean?
Error code 130
130.
Sensor Error
sensor harness.)
Sep 02, 2012 | Fisher and Paykel GWL11 Top Load Washer
Fault code 130 appears on my fisher and paykel intuitive eco washing machine, do I require a technician to fix this?
Sensor Error
sensor harness.)
Aug 25, 2012 | Fisher and Paykel Washing Machines
Error code 130
Position Sensor. Likely causes of this fault are a bad connection on the harness between
the Rotor Position Sensor and the Motor Control Module, or a faulty Rotor Position Sensor.
faulty.
Aug 11, 2012 | Fisher and Paykel IWL12 Top Load Washer
Error code 130
faulty.
Action: Ensure the correct rotor for this phase of machine has been fittedc61fd2ce-cf94-4234-8679-0e9d4724bed7.jpg
Jun 23, 2012 | Fisher and Paykel Washing Machines
Gw712
Fault code 130
Sensor Error
sensor harness.)
Feb 29, 2012 | Fisher Paykel EcoSmart GWL15
Fisher and Paykel IWL12 Top Load Washer Logo
53 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Gerry Harvey
Gerry Harvey
michael_t919
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
