Question about Cycling
What size tubes dovi need ? - Cycling
  • 73 Answers
Tube size is embossed on the sidewall of the tire
Posted on Jul 17, 2013
What size flourescent tubes are in the door of a dncb240 pepsi machine?
Measure the distance between the tube sockets to get the size tube that fits.
Oct 21, 2014 | Wine & Spirits
Front tire size?
With a tube type laced wheel:
WHEEL SIZE & POSITION = 21 in. - Front RIM SIZE & CONTOUR = T21x 2.15 TLA TUBE SIZE =Side Valve Tube MH90x21 TIRE SIZE = DUNLOP D402 MH90 - 21 54H
With a CHROME ALUMINUM PROFILE LACED RIM:
WHEEL SIZE & POSITION = 21 in. - Front RIM SIZE & CONTOUR = T21x 2.15 MT TUBE SIZE = Center Valve Tube MH90x21 TIRE SIZE = DUNLOP D402 MH90 - 21 54H
With a Tubeless Cast Wheel:
WHEEL SIZE & POSITION = 16 in. - Front RIM SIZE & CONTOUR = T16 x 3.00 D Rim Valve hole diameter = .035 inches MH90x21 TIRE SIZE = DUNLOP D402 MT90B16 72H
Jul 11, 2014 | 2006 Harley Davidson FXSTDI Softail Deuce
Inner tube size for a transeo gt 2.0 medium size bike
unfortunately you have to buy a new tube...The size you need is embossed on the sidewall of the tire.
Jul 10, 2013 | Cycling
Inner tube sizes
most tubes don't come in specific width sizes, so the correct on may be 20x1.25-1.75 or 20x1.5-20 etc, you probably wont need to change the tube.
Nov 26, 2012 | Dahon Speed D7
I have a Gio 500w ebike. The tube inside the back tire needs to be replaced and I cannot find the size to buy anywhere.The Gio website sells them but dont give u the size. I was also told that you can...
Hi! I have 2 Gio Scooters. I looked and looked for a tube for my tire and couldn't find a place until I realized that if you go to Ebay online you can actually buy them through Sven the supplier who sells the Gio Scooters on Ebay. You can just buy them from him and pay through paypal. Make sure the valve is curved and not straight out or it's not the right one. He ships pretty fast too:) I hope this has helped. It took me awhile to get parts. He also will ship parts, he's out of Vancouver. So Good Luck:) Do you know anything about fuses for these bikes???? Grrrr....
TTYL.G
Jun 15, 2011 | Health & Beauty
I am trying to find the right tube to change the tire.
tubes are measured based on your wheel sizes. if look on the wall of the tire it will have a size. this is the size of the tube you need to buy.
May 02, 2011 | Cycling
Hello, i have one of these bikes, and need to know what type of tube i need. it came with a flat, and i am trying to find a tube, but not sure what i need. can you tell me what type of stem it has. ...
The tube has two elements to it, the size and the valve.
The size of the tube will correspond to the size on the tire. Look right on the side of the tire something like 26 x 2.0 or 700c x 23c will be written on the tire. both of these numbers tell you what size tube
The Valve is easier: you either have a Schraeder or a Presta. The Schraeder is the same as on a car the Presta is a thin metal tube with a tip you have to unscrew.
Apr 10, 2011 | Cycling
My front tire keeps going flat do i need a new one, and if so where can i get one and what size do i need. It's a chauffeur mobility scooter.
This could be solved quite easily. Ask your local bicycle repair guy to give you a hand and repair the inner tube. I am sure that he will be delighted to assist you. Happy scooting. Regards Chris… info@mymobility.co.nz
Jun 19, 2009 | Pride Mobility Products Go-Go Elite...
Won't fill during rinse cycle
It keeps spinning or you just hear noises and it doesn't end cycle ? Following your description regarding water in tub when you start a new cycle,check for : * Switch level - The switch level is usually a diaphragm device with a small clear tube attached between the switch and the bottom of the washer's outer tub. I am not familiar with this specific machine, but if you will remove the cabinet, you will find it easily. Clear first any obstruction in the tube,In case it doesn't help, disconnect the wires from the unit (you should disconnect first machine's power cable !!!!!) and measure with a multi-meter on its tugs for continuity and disconnection while you are inhale and blow to its tube. In case it doesn't react,you should replace it. * Pump and drain host - Check that pump works and that you have no blockage on your drain line. Good luck !! (courtesy dovi)
Apr 13, 2007 | GE WBSR3140DW Top Load Washer
Washer overfilling
There are two reasons could cause washer's overfilling. - A defective water entrance valve - Water supply to the dishwasher is done through an electromagnet valve,loocated at the water pipe's enterance to the machine. A defect in the valve may mean that it's no longer able to shut off completely when the electricity has been turned off to it, and the valve may leak and drip water into the tub.You can easyly open the valve and clean it (from scale or other dirt). Be aware you should disconnect the power cable from the machine before doing it !!!!! and to close water main tap to the machine. In case cleaning doesn't help, you should replace the valve. - Water switch level - I am not familiar with this specific machine, but there are 2 types of level switches. 1)A diaphragm device with a small clear tube attached between the switch and the bottom of the washer's outer tub. 2)Floating switch that located inside the dishwasher's bottom and operate a switch. In case there is a floating switch in your dishwasher - check for its smooth movment and check as well the switch by a multi-meter (an on/off switch). Defective switch should be replaced. If level switch in your dishwasher is a diaphragm device - Open the rear panel, find the device and clear first any obstruction in the tube.In case it doesn't help, disconnect the wires from the unit (you should disconnect first machine's power cable !!!!!) and measure with a multi-meter on its tugs for continuity and disconnection while you are inhale and blow to its tube. In case it will not react, you should replace it. Good luck !!
Jul 02, 2006 | Whirlpool LSR5132PQ Top Load Washer
Cycling Logo
14 people viewed this question
Top Cycling Experts
Michial Gueffroy
John Egan
John Egan
Are you a Cycling Expert? Answer questions, earn points and help others
