Question about Cub Cadet Garden
Cub cadet troubleshooting I will be cutting grass & the engine will act like it is running out of gas. I disengage the mower & pull the choke out & the engine revs back up to speed. I will cut a little more & the same thing happens again. Any ideas?
    New Friend:
  • 11 Answers
Check the oil, air filter, and run some non ethanol gas in it
Posted on Jul 16, 2013
  • 40 Answers
SOURCE: cub cadet lt1050 poor running
when you cleaned the carb was the needle replaced. also what is the compression on this engine. if a unit has low compression they will sometimes only run on full choke. is there good fresh gas in this unit. No water..(if in doubt trow it out)
Posted on Mar 12, 2009
panilling9
  • 284 Answers
SOURCE: cub cadet mower pto will not stay engaged while
be sure your battery is good and your system is chargingning the battery while run
Posted on May 26, 2009
  • 84 Answers
SOURCE: have a craftsman model :917.273621,
try the coil. the coil will produce the spark for the spark plug seeing as there is no battery, try replacing it with another of the same power.
Posted on Jun 24, 2009
  • 109 Answers
SOURCE: Cub cadet Z Force 48 inch zero turn blades won't engage
I hope this will help you...under the side panels on each side of the mower, there are "reverse lockout safety switches", they are supposed to stop the blades when both handles are pulled back. If one or both of the switches are out, the deck will not engage. Also, under the right side panel (when sitting on seat) there should be 3 relay switches, the one closest to the motor controls the PTO., if this is out, the PTO will not engage.
Posted on Jun 29, 2009
SOURCE: I have a cub cadet 1550, Blew fuse and wont disengage from gear
You have a bad wire which rubbed on the plastic housing to the engine block near the starter mower which causes a short and blows the fuse. I have the same tractor and this happened to mine also. The wire is red.
Posted on Jul 29, 2009
Why will a cub cadet lawn mower cut grass a few mi. then stop cutting?
Sounds like the electric PTO clutch is bad and needs to be replaced.The straps within the clutch brake causing it to get out of position and the clutch keeps disengaging. You can buy the clutches on line cheaper but they don't last as long.
Apr 22, 2015 | Cub Cadet Garden
Troubleshooting
need govenor adjustment and throttle adjustment have to take in 60.00
Sep 04, 2014 | Cub Cadet Garden
Have 2155 cub cadet when it gets hot spudders then dies wouldn't start until cools acts like it not getting gas what could be the problemn?
To be quite honest it sounds more like a fire issue than fuel. More times than not when a coil starts going bad the hotter it gets the weaker it gets and sometimes stops firing at all until cooling down, occasionally a plug will do this aswell, but I think your coil is going out.
Aug 21, 2014 | Cub Cadet Garden
I have a cub cadet 1000, it's approx 4 years old, i was in the middle of cutting the grass and the mower stopped running. Tractor runs mower will not come on. Is there a switch or module that nee
check the clutch on the end of engine drive shaft it is the same as a car air con clutch put power on to it and it should click so most likely the wire from switch to clutch
Apr 22, 2013 | Cub Cadet Garden
I have a cub cadet rzt 50 with a kawasaki 22hp engine it cranks and runs fine for a while and then sounds like its running out of gas, I shut the pto off and it eventually quits running, I pull the choke...
PDF]OPERATORLS MANUAL - Cub Cadet
https://www.cubcadet.com/.../CubCadetCatalogAssetStore/.../own...Cub CadetRZT Series Tractor - Model RZT50VT. Form No. 769-04647 ... Please read this entiremanual prior to operating the equipment. It instructs you how to safely and ...
Basic Troubleshooting - Zero Turn Riding Mowers (Gasoline ...
cubcadet.custhelp.com/.../basic-troubleshooting---zero-turn-riding-mowe...
Scripting must be enabled to use this site. Support Center. Cub Cadet Website ... Basic Troubleshooting - Zero Turn Riding Mowers (Gasoline Powered). Answer ID 10646 ' Published 01/22/2014 11:27 AM ' Updated 01/22/2015 02:50 AM
May 23, 2011 | Cub Cadet Street Sign- tractor lawn riding...
Jul 28, 2009 | Cub Cadet Garden
My cub cadet zero turn mower won't engage the blades with the switch.
I have a cub cadet zero turn z force 48 yesterday i was cutting lawn and i heard a clink, the mower stopped, i was ablet o start the mower again but when i pulled the pto knob to engage the blades the mower turns off by its self, when the pto lever is pulled up i can restart the mower what is causing this and how do i fix it
May 09, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Cub cadet lt1050 poor running
Mar 10, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Garden Logo
272 people viewed this question
Top Cub Cadet Garden Experts
Tim Whalen
DarkfireVA
Level 1 Expert
Matt Olenzek
Matt Olenzek
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
