Question about Exercise & Fitness
Free spirit mm2184
The plug end came out from the bottom of my machine. Can you help me out. There is a white prong, and a black prong and a green one. The plus came off where the prongs are attached. They get attached to a plug end. A single head and two together .. What goes where? Liz2251@hotmail.com. Please respond..
    Top Expert:
  • 12,223 Answers
See the diagram attached. God bless you
Posted on Jul 17, 2013
I want to put a new GFCI outlet on the end of my intex pool pump to plug into the wall b/c the fuse has been blown. Where can I get one?
They make what is basically a very short extension cord with a gfci at one end. Plug you motor cord into the receptacle end. If the motor cord end needs to be replaced, put a new plug on it.
Watch the polarity. The white wire goes on the wide prong, the (usually) black wire goes on the narrower prong and the green wire goes on the bottom prong.
Aug 29, 2013 | Intex Pool & Spa
Can you take a dryer that has a 4 prog plug and put a 3 prong plug on it?
Yes, you can put a 3-prong plug in place of the 4-prong plug.
The 4-prong plug has red, black, white, and green/yellow wires while the 3-prong plug has red, black, and white wires. The only difference is the green/yellow (ground) wire of the 4-prong plug which is attached to the dryer cabinet. All you have to do is connect the wires of the 3-prong plug in the same way the same wire colors are connected with the 4-prong plug then connect the terminal on the cabinet, where the green/yellow (ground) wire of the 4-prong plug is formerly connected, to the white wire of the 3-prong plug.
Feb 04, 2011 | Maytag Dryers
I am trying to change a 3 prong dryer plug to a 4 prong
You are correct, the green wire is ground. You may be able to connect to the same location as the green wire from the unit.
The white is neutral and the red and black are both 110V (your unit uses 220V).
Here is a link to a picture. I hope it helps:
http://repair2000.com/cord.html
Sep 15, 2009 | Westinghouse WWS833ES Super Capacity Top...
I need to switch my three prong power chord to a four prong
your terminal block on the dryer will have three screws in a row and there will be a green screw on the outer skin next to the terminal block cover - your four-wire cord will have a white wire, red, black and green wires - white wire goes on the center screw of the terminal block, red wire goes on one of the other screws of the terminal block, it doesn't matter which, black wire goes on remaining terminal block screw, green wire goes to the green screw
Aug 17, 2009 | Dryers
Frigidaire self cleaning stove mod FEF369cgsb ser vf94422321 was originally wired direct and it shows 4 wires. Now I want to use a plug and outlet, 3 prong. How do you connect the 3 prong plug? thank you...
Vivian
the original wiring probably had a red, white, black, and green wire. It is 240 volts. The red is hot, carrying one leg of 120 volts. The black is also hot, carrying 120 volts. The white is neutral, and the green is the ground.
I am against altering this, but you can wire the red and black each to a hot leg, and wire the white and green to the bottom ground. This then introduces a ground wire to your neutral bar in the circuit panel, which is not the best way to do it, but will work.
Best to get an electrician to wire a 4 wire cable to a four prong outlet, and then use a four wire pigtail with a 4 pronged plug.
Lots of people modify it, they ground the green wire to the stove, where the wire originates,and to the box with the outlet in it where it hooks onto the plug if it is metal. Then you have a part ground. And that is assuming you have a cable with wires sticking out to wire to a plug.
Boils down to your decision. If the above isn't the case, get a four pronged outlet and wire the red and black to the top two prongs, the white to the neutral, and the green to the metal box it sits in.
Sirwriter
May 16, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Changing from 3 prong to 4 prong cord
Mar 19, 2009 | Dryers
I am converting a 3 prong dryer to a 4 prong plug. The wires inside the dryer are black/yellow, white and blue. The wires on the plug are white, black, red and green. I am assuming the green is the ground...
on plug white is neutral, black is power , red is power, green is ground. black/yellow and blue are power and white is always neutral ie. (white to white) black to black/yellow, blue to red. green to grounding screw on machine
Jan 04, 2009 | Estate TEDX640JQ Electric Dryer
Hooking up a 4 prong plug to dryer
easy enough, black and red go to either end terminal behind dryer(makes no difference which, the white MUST go to the center terminal, and teh sreen ground must be hoooked to the ground strap, probalby already a green wire screwed there already as well
Apr 05, 2008 | Maytag Neptune MDE5500AY Electric Dryer
REPLACING DRYER 4 PRONG PLUG
This is common issue. Due to some building codes the 3-prong configuration is no longer used in homes. The wiring is similiar with one exception. The 4-wire plug uses an additonal (WHITE) NEUTRAL wire.
Here's a brief explanation of how the plugs are configured:
Dryer 3 prong wire configuration:
RED - 120 VAC
GREEN - GROUND
BLACK - 120 VAC
Dryer 4 prong wire configuration:
RED - 120 VAC
GREEN - GROUND
BLACK - 120 VAC
WHITE - NEUTRAL
BOTH plugs provide the SAME source voltages to your appliance:
220 VAC - provided across the RED and BLACK leads are what drives your heating circuitry.
120 VAC - usually tapped of the BLACK wire is used to run the drive motor and timer on MOST dryers.
The wire terminal block in the back of the dryer should have a black, white, and red wire running to it from the dryer wiring harness. With the 4 prong plug, simply attach the BLACK, WHITE and RED wires at the terminal block ensuring that you match the RED and BLACK wires as they are configured and attach the WHITE wire at the remaining terminal lug. Make sure you screw them all down securely. Attach the remaining GREEN wire to chassis (dryer frame) ground. I hope ths helps you.
Feb 14, 2008 | Dryers
Exercise & Fitness Logo
29 people viewed this question
Top Exercise & Fitness Experts
Howard
Howard
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
