Question about Refrigerators
Replace ice maker Model 795.71059.010
I have a new replacement for this ice maker but did not get instruction. Can you help?
  • 183 Answers
SOURCE: IC6 ice maker
No, completly deforst the freezer for 24hrs this will resolve the problem, i know its frost free, but still try to defrost this usaully resolves this fault Regards Advisor
Posted on Aug 21, 2007
SolutionGuy
  • 331 Answers
SOURCE: water leaking
Tarena, it's been my experience with Amana that tells me you have a failed water inlet valve.
Here's how it works; Water comes from the wall into the fridge to the valve I'm talking about. Now this valve works like this... When you put a cup in the dispenser area to get cold water a switch sends 120 volts to the valve and it opens up allowing water to flow through it. When you remove the cup, power is shut off at the valve... the valve is supposed to close all the way, if it didn't there would be water dripping from the dispenser area, right? (Like a leaky faucet) If the valve is bad, it won't open at all. (Like a blown out light bulb)
The ice maker is similar. When it "harvests" ice and it drops into the ice bin, the IM will send 120 volts to the valve (for 5 seconds or so) to re-fill the ice mold so it can make another batch. Now when the power is removed from the valve, it's supposed to shut off all the way. If it didn't, there would be water dripping into the ice maker fill tube (in the freezer behind the ice maker). drip, drip drip... one after the other.
Let's assume that the ice maker valve didn't close all the way. What would happen then? As these drops of water enter the freezer compartment and are heading down the ice maker fill tube toward the ice maker, they don't make it all the way 'cause they FREEZE in the tube! One drop at a time, week after week. ('course you never notice it, 'cause it's in the freezer) Now... the ice maker is still trying to make ice, so every 45 minutes or so it sends 120 volts to the valve to get more water. But the water fill tube has ice in it because of the water drops that have accumulated there. This goes on over time and eventually the water fill tube becomes completely BLOCKED with ice due to those water drops.
Now what happens? The ice maker is still trying to make ice, but the fill tube is blocked... it can't get water through it. But when the water valve opens up to allow water to the ice maker, where does it go? Since the fill tube is blocked, all that water pressure builds up in the water line (tube) that feeds the ice maker and eventually it blows out! (you can verify this... pull the refrigerator out from the wall, look at the water line going to the ice maker. There's a connector back there for the tube to fit into. This is what's blown out.) Now the tube is just dangling there and not hooked up to the ice maker any longer. Since the ice maker is still running, every time it asks for water it sprays out and onto the wall and floor back there through this dangling tube.
The repair? Replace the valve. It's easy. The part number is 67005154 and it lists for about $21.00. You can find one at any appliance parts retailer. (you'll see where the valve is located... it's where the water line hooks up behind the fridge.) UNPLUG YOUR FRIDGE WHILE YOU WORK ON IT!!!
Just replacing the valve is only half the job. You'll still need to remove the ice build up in the ice maker fill tube. Do this by pulling it straight out the back of the refrigerator and putting it under warm running water. Then re-install it and hook the water tube back up to it.
On some models, you can not remove the fill tube. If you can't get it out the back, you'll have to do it from the freezer compartment behind the ice maker (a little more work, but still do-able). It's easiest by removing the ice maker.... pull the ice bin out and set it aside. Then remove the 3 screws holding the ice maker. You don't have to disconnect the wires, just try to get it out of your way the best you can. Now take a hair dryer and thaw out the fill tube until the ice slides out of there. Then rebuild it.
There ya go! Job time? about an hour. Part cost? about $21.00. Knowing that you fixed it yourself? Priceless.
Posted on Oct 15, 2007
SOURCE: Sub zero 532 ice maker
When my repair tech came out, he showed me that the fill tube sometimes retracts toward the rear of the freezer. He simply pulled it forward with a pair of needle nose pliers until it rested in the delivery reservoir. This placement allows the detector to know when the tray is full and shut off; thus not overfilling the freezing tray and/or splashing additional water onto the freezer wall and into the ice cube drawer.
Posted on Jun 30, 2008
  • 54 Answers
SOURCE: need install instructions to replace water tank
there is no online instructions that i am aware of.
Posted on Jul 03, 2008
vanni7
  • 163 Answers
SOURCE: water dispenser and ice maker not working
Hi!! tony , yes you have a bad water valve its located on the bottom back of your frig..Replace your water valve..Good luck..
Posted on Jan 03, 2009
Replace water inlet valve for ice dispenser with new. When icemaker cycles it dispenses through the water dispenser instead of tube going to ice maker. I have switch lines around but can only get water...
The ice maker is what tells the water control valve to open so it may be correct now and the thermostat in ice maker may be defective. Part 27 or 627985 down below where it says Whirlpool Ice Maker Parts Breakdown and in that photo is the ice maker thermostat. If your ice maker has been used for many years the complete ice maker may be better to replace. Ice maker Model=> 4317943
Or click here=>Point and Click Then enter model or part number into search feature. If you have questions please ask, Thanks, Sea Breeze
Whirlpool Model ED5GTFXKQ02 Ice Maker Parts Breakdown
Dec 17, 2010 | Whirlpool Refrigerators
Need to replace Ice Maker in bottom freezer
Good day,
3 screws hold the ice maker in place. On some versions the 2 top screws are replaced with clips, but it is self explanatory.
The cover is a tight fit, but un clips from the bottom first. You re-install by snapping it in place with the palm of your hand.
The wire pulls straight out of the front of the ice maker and then you wiggle the rear off its mounting hole.
HOWEVER,
What you described is classic of a bad water valve. Especially the overflow issue. I would change the valve first, and if it still has issues then replace the ice maker.
Apr 07, 2010 | Amana AFD2535DES French Door Refrigerator
Need to replace the ice maker part # 2198597. I need the instruction manual. If anyone can email to me that would be great mdelahan@comcast.net
there may be a seperate pump for the ice maker in the back at the bottom .itmay be cloged due to calcium or other debries check there first.as far as the ice maker,usally it just takes a few screws or a 1/4 in.socket to remove and then a unplug the connection. that motor may need to be checked as well.hope this helps
May 28, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Kenmore ice maker filled with ice, but not dumping. light blinking next to ice maker switch
sounds like your ice maker heater may not be working, as there is no way to repair the heating element but to replace it with a new ice maker, you can probably jump the ice maker by removing the front cover of it
here is a link with more instructions good luck
http://www.davesrepair.com/DIYhelp/DIYicemakertips.htm
May 27, 2009 | Whirlpool GD2SHGX Refrigerator
Ice won't drop. HELP! my drink is hot!
If ice maker is on and ice is in tray I believe the thermostat inside the ice maker is defective. The ice maker can be repaired but the waste of time and possibility that other problems could be hiding I believe I would just replace the ice maker with a new one. Go to link below and enter the model of your refrigerator. This will take you to several models like yours. Sometimes it's just less expensive to replace with a new one. The model of your side by side is GSS20IEP and the replacement part number is WR30X10093
Click on link below, I will help you repair or replace your ice maker, Just let me know, Thanks Sea Breeze
http://servicepartstec.blogspot.com/
May 26, 2009 | GE GSS20IEP Side by Side Refrigerator
Ice bucket broke on my edgestar, IP210TI, ice maker
call Edgestar support at 1-866-319-5473. i had the same probvlem with my ice maker and had no problem ordering a replacement with installation instructions
Feb 13, 2009 | EdgeStar Titanium Portable Ice Maker
Ice maker won't stop dripping
If your i/m is dripping you most likely have a crack in the ice mold, you should replace the ice maker.
Jan 01, 2009 | Sub-Zero 650 / O Bottom Freezer...
Replacement ice maker
Sounds like you may have gotten a wrong kit, or a mislabled kit. Take it back and ask the salesperson to correct the error. Ask them for some advice if they try to say it is the right one. They made a profit on the sale so they need to make it right with you.
If you get nowhere, which is likely to happen, post me back and I can help you come down legal on them.
If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Jun 19, 2008 | Hotpoint FFU00 Side by Side Refrigerator
Refrigerators Logo
136 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
